Interior Lights - 2014+ Jeep Cherokee Forums
 1Likes
  • 1 Post By wpgguy
post #1 of 8 (permalink) Old 12-04-2015, 01:34 PM Thread Starter
Interior Lights
Anyone replace the interior accent lights (specifically the floor boards) with brighter ones? Maybe LEDs? I can barely see mine even when they are all the way up.
Since I'm on the topic, how about the fog lights to match the rest of the headlights? Mine look a little yellowish.
kaysee is offline
post #2 of 8 (permalink) Old 12-04-2015, 01:37 PM
coloradotrv's Avatar
I believe you want a little yellow tint to the fog lights for improved visibility. Someone can correct me if I am wrong.
Granite Crystal
Black Morocco
3.2L Pentastar V6
Tow Package
Build Date 5/5
Reserved 5/14
Arrived 5/20
coloradotrv is offline
post #3 of 8 (permalink) Old 12-04-2015, 01:45 PM
pjames074's Avatar
The floor board lights actually are LED's stock. But, they are soldered into a circuit board. I believe someone has switched them out but it requires a bit more labor than just switching bulbs.
This thread has a lot of info on switching out all the other interior bulbs though:
Interior Bulbs (LED Replacement)
2014 Jeep Cherokee V6 | Active Drive II, Mall Crawler
Factory Towing Package | Cold Weather
Custom Katzkin Leather | Mopar Mudflaps
LED Everything (All Interior Bulbs, Taglights, Reverse Lights, Headlights, and Foglights)
Yakima Whispbars with Yakima HighRollers
Mopar Skid Plates | Bigger Tires
Tinted Front Windows to Match Rear | Muffler Painted Black
'14 Triumph Tiger 800
'00 Miata Canyon Carver
pjames074 is offline
post #4 of 8 (permalink) Old 12-04-2015, 01:45 PM
biggee72's Avatar
LED fog lights will look bright when looking at them but won't work as fog lights. Although, fog lights in factory form are typically useless anyway. LED's will look cool from the outside but won't work any better than stock. I think the color temp of LED is around 6500K. The fogs are ~3200K which would be optimal for visibility and reduced reflection.
2014 Trailhawk V6. Most options. Grand Canyon brown leather interior. - Gone
biggee72 is offline
post #5 of 8 (permalink) Old 12-04-2015, 02:50 PM
Gersh's Avatar
Interesting article I came across.
http://www.danielsternlighting.com/t...fog_lamps.html
Gersh is offline
post #6 of 8 (permalink) Old 12-04-2015, 04:01 PM
wpgguy's Avatar
I have led's installed in my fogs. Prefer it over the lamps. My LED's are brighter and I have them aimed lower to the road to improve my visibility since the stock headlights are awful. No problems.
As far as the ambient lighting, it can be done as long as you're willing to do the work. I don't have ambient lighting but I did it myself using a PWM driver and some LED's near the floor and in the above center console. I can turn them up bright or down low.
Black Cherokee Sport 4x4 i4
Current Mileage: 56,000km
wpgguy is offline
post #7 of 8 (permalink) Old 04-19-2017, 02:54 PM Thread Starter
It's been 2 years and I never decided to change the floor lights, but now I'm in the mood. Not much on soldering, but has anyone had experience with LED strip lighting? And how did you power them?
kaysee is offline
post #8 of 8 (permalink) Old 04-19-2017, 03:51 PM
PHaTBob72's Avatar
LEDs come in all different color temps, they're not all the same color temp just because they're LED. Here's some 3000K.... https://store.ijdmtoy.com/H11-9005-9...0w-cob-fog.htm
PHaTBob72 is offline
They changed the interior lights phoneguyinpgh Electronics, Audio, and Lighting 4 10-21-2015 08:00 PM
Keep radio on but interior lights off eliassan84 2014+ Jeep Cherokee General Discussion 1 05-31-2015 10:50 PM
Replacing interior lights Xtain1206= Jeepcherokeeclub.com How-To's 3 03-24-2015 10:00 PM
Now It's Interior Lights Dagnabbit Dynarider Electronics, Audio, and Lighting 8 07-21-2014 06:16 PM
Running lights not working and interior lights staying on Jsurm8 2014+ Jeep Cherokee General Discussion 1 05-30-2014 07:44 AM
