Latitude Mod/Build by tbrou6229 - Page 3 - 2014+ Jeep Cherokee Forums
 92Likes
post #21 of 182 (permalink) Old 03-16-2016, 03:14 PM
Dunx's Avatar
looks freakin amazing. I have a spare one of those led strips lying around actually. the ones where you can dial in any colour you want.
is yours actually purple? or is that just the photo hue?
edit: and yeah I would think a few small dabs of silicone on the back of that grille strip would work perfectly, and not be impossible to remove.
nice job!
2015 North "Blackhawk" mod | 3.2 v6 4x4 AD1 | Tow | Cold Weather | Comfort&Convenience | SafetyTech | CommandView Sunroof | 8.4Uconnect |
Dunx is offline
post #22 of 182 (permalink) Old 03-19-2016, 11:31 AM Thread Starter
tbrou6229's Avatar
Originally Posted by Wisconsin Mike View Post
Nice job! Just curious... Do they fade up and down like the interior lights or do they simply turn on and off?
https://youtu.be/Nf698-dpTG0
I couldn't upload a video here, but here's a YouTube link for it.
Originally Posted by Warloq View Post
Here's a second about learning where you tapped power... Wheels look good too since your bottom pic is first I've seen them mounted.
I tapped into the interior lighting in the floorboard (the yellowish LED, not the white one for the ambient lighting.) There is a red/black wire going in to this that I was able to splice in to on each side. From there I just ran wiring through a plastic grommett I found in the A-pillar and then out to the undercarriage.
Thanks on the wheels! I'm loving the look, and looking for some way to make it more permanent than the plasti-dip. May have to go with a powder coat if I can find one the right color.
Dunx and Warloq like this.
tbrou6229 is offline
post #23 of 182 (permalink) Old 03-19-2016, 11:33 AM Thread Starter
tbrou6229's Avatar
nice job!
Thanks Dunx,
The light is actually pretty white when you see it in person, but the camera always seems to capture it as blue/purple. It would be cool to be able to change the colors though!
post #24 of 182 (permalink) Old 03-19-2016, 04:00 PM
Wisconsin Mike's Avatar
That is sweet! Really nice job, there.
Wisconsin Mike is offline
post #25 of 182 (permalink) Old 03-21-2016, 02:18 PM
Wow love the lights behind the grill & under. I dont know anything about wiring, would this void my warranty if I have someone do it?
I got the Jeep back in May '15.
The last thing I need to plastidip are the roof rails.
Were they hard to remove? I'm scared to try it but I heard its simple as long as you don't mess up the cover. I'm sure once they are removed it is easy.
llChaosll is offline
post #26 of 182 (permalink) Old 03-21-2016, 11:08 PM Thread Starter
tbrou6229's Avatar
I don't think I did anything that could void the warranty; unless I was trying to get the interior footwell lighting worked on under warranty... Then I think they would have an issue since I cut wires for my power.
The roof rails were easy to remove, just be careful prying out the little covers. They only come out one way, and make sure to do it when it's warm or you could break the tabs. Then get a big flathead screwdriver for the bolts. (The bolt holes look like a 3-point bit of some type, but I used a flathead just fine. After all four bolts are out, slide the rails (not sure if it's forward or backward) and they will come right off.
If you are looking for a permanent solution, plasti-dip isn't gonna hold up long on the rails if you actually use them or strap to them. I'm considering having them painted with a good enamel, or more likely, I'll buy replacements in the grey or black.
post #27 of 182 (permalink) Old 04-13-2016, 07:15 PM Thread Starter
tbrou6229's Avatar
Just got my RRO steprails installed! They are looking awesome and like they can take just about anything. Unlike some of the other posts about RRO, I didn't have any issues with my product except that it took a while (4 weeks) for production... The parts came in perfect condition and I wasn't missing anything but one small (and very common) washer. The most painful part of the process was payment for the RhinoLining and install.
ID:	116121   Click image for larger version
madchemist24 likes this.
post #28 of 182 (permalink) Old 04-14-2016, 08:46 AM
osirisdean's Avatar
Here are some pics with the roof rails and grille dipped. Also, gotta love the black with a fresh polish. Its amazing how much depth it has!!!
dude, fantastic job all around. looks awesome! i plan on blacking mine out as well, so i may bombard you with questions if that's cool.
for starters: how easy was it to take the roof rails off? i've heard some horror stories about how the bolts strip really easily and whatnot, so that's been a worry of mine.
build date: november, 2014
osirisdean is offline
post #29 of 182 (permalink) Old 04-14-2016, 11:00 AM Thread Starter
tbrou6229's Avatar
I did not have any problems getting them off. The only things to watch out for are the covers over the bolt holes... They have little tabs on them that are easy to bend too far and break
osirisdean likes this.
post #30 of 182 (permalink) Old 07-13-2016, 02:21 AM Thread Starter
tbrou6229's Avatar
So, I've done a few more mods to my KL; nothing major but I figured it was time for an update. I really liked the matte look of the black plasti-dip on the rails, but I want to actually use them for stuff so I decided to replace them with factory painted ones. I bought the grey (Trailhawk) ones off another forum member for a good deal and installed them a few days later.
My most recent and probably most usable change was to add the OEM hitch and bezel. I was originally looking at replacing the entire rear fascia, but the bezel was less than half the price and looks pretty good. The hitch install was fairly straight-forward and there are several good posts on here about completing the install. I like the weight and strength of the hitch over the original bumper. The installed bumper (without tow package) is made of a fairly thin, hollow aluminum attached with a few bolts. The OEM hitch mounts in a manner that seems a lot more secure onto the frame and is made of a thicker, heavy steel. Removing the fascia and installing the bezel was fairly straight-forward as well, following the instructions and template provided.
While I had the rear fascia off, I decided to remove the chrome tips for the exhaust and paint them matte black to match the blackout scheme of my Latitude. Overall, I like the new look!
Now, lets see if these pictures will link right... I usually upload and attach, but i'm trying to link them from a Google account. And GO!!!
Installed Hitch
Bezel-Cutout
Bezel Installed
Finished product!
And with the (blacked-out) chrome tips)
If those don't work, here is a link to my google photos album with the pics.
https://goo.gl/photos/LECsZyuGSUnLtuvV6
Dunx, Ferdinand1 and Jeep#2 like this.
~Mods List~ (In Progress!)
The First Family Member...
See HERE for Mod List!
Last edited by tbrou6229; 07-13-2016 at 02:32 AM. Reason: Attempt 2 at pics- and attempt 3... and its still not working. Check out my album
First Mod gforce211 Exterior 0 12-21-2015 09:00 PM
2015 Cherokee Latitude build date 12/05/2014 ross New Member Introductions 8 01-19-2015 12:03 PM
Mod Party!!! Jeep Girl Capital Area 5 08-11-2014 07:58 PM
First mod! fonz88 Exterior 33 02-23-2014 10:45 AM
Is the build date actual date of build or when VIN is assigned hammick Cherokee Purchasing and Orders 1 12-10-2013 06:10 AM
