Oil leak? - 2014+ Jeep Cherokee Forums
 3Likes
  • 2 Post By Desoto
  • 1 Post By indytrucker
post #1 of 7 (permalink) Old 01-11-2017, 08:02 AM Thread Starter
Oil leak?
Looks like its leaking from somewhere but im not a mechanic so not sure where. Any opinions?
ID:	146514   Click image for larger version
ID:	146522   Click image for larger version
indytrucker is offline
post #2 of 7 (permalink) Old 01-11-2017, 10:45 AM
R2D2's Avatar
Is that the Rear Diff? Seepage is pretty common. If you're still within your Warranty. The dealer can replace it. Mine was covered under warranty. My original dealer tried to get me to pay for it when they saw the seepage at 5k miles. 15k miles later, I went to another dealer and told them about my rear diff. They replaced it under warranty.
R2D2 is offline
post #3 of 7 (permalink) Old 01-11-2017, 05:26 PM Thread Starter
Its actually somewhere up front about 6-12 inches towards drivers side from oil drain plug.
post #4 of 7 (permalink) Old 01-11-2017, 08:17 PM
Clean it first
I would suggest cleaning it down there first and try to pin point where the leak is coming from. Could be just residual oil from the last oil change....or maybe something worse. Hopefully not. Keep checking your oil level.
sagravtj is offline
post #5 of 7 (permalink) Old 01-11-2017, 08:29 PM
Desoto's Avatar
Start at the top. Shine a light into the area of the Oil Filter Housing from the right side. See if there is any oil pooling up in the valley. Possible Oil Cooler leak.
Jeepster1 and Gersh like this.
Desoto is offline
post #6 of 7 (permalink) Old 01-12-2017, 09:22 AM
Gersh's Avatar
^^^What he said
Apparently it's a common issue when there is an oil leak
Gersh is offline
post #7 of 7 (permalink) Old 01-16-2017, 04:35 PM Thread Starter
Turns out it is an oil filter housing failure. Of course part is on back order. Fingers crossed doesnt take to long to get part in.
sgrim likes this.
Oil leak MRB157 Engine and Technical Discussion 13 10-02-2016 08:31 PM
Potential oil leak or sloppy tech? Flak Engine and Technical Discussion 7 06-26-2015 08:59 PM
Oil Leak ScottCT1 Engine and Technical Discussion 5 12-23-2014 09:11 AM
serious oil leak dealer can't locate. Allan nicely Rocky Mountain 7 10-25-2014 07:09 PM
Oil leak johnk107 Engine and Technical Discussion 7 08-11-2014 07:56 PM
