Black Beauty - Page 6 - 2014+ Jeep Cherokee Forums
 47Likes
post #51 of 55 (permalink) Old 03-22-2017, 02:35 PM Thread Starter
peep6543's Avatar
Needed cross bars for my kayak trays and bike trays. I found a cheap-o option with similarity to the aeroblades. Bought through WM online, $51 and free shipping. Universal 48" aluminum cross bars. I wanted a little overhang so I have an anchor point for random tie-downs. Have them disassembled now and this afternoon I'm going to scuff them, clean them, and hit them with a couple coats of truck bed liner. the black strip is a removable piece of rubber that will also be removed before paint. I want them black, but I want a non-skid surface for my rack mount points to grab on to. results to follow.
GO COUGS
GO HAWKS
peep6543 is offline
post #52 of 55 (permalink) Old 03-22-2017, 08:53 PM
Mxttric's Avatar
Varies on the weather, when its colder, the 4wd tends to kick so you will see a drop in mpg. As it gets back warmer, Fwd will come back on and become more fuel efficient. If your trying to save on gas, keep revs to 2000 rpms or under.
The best preparation for tomorrow is doing your best today.
Mxttric is offline
post #53 of 55 (permalink) Old 03-22-2017, 09:29 PM
goobnav's Avatar
Welcome!!
goobnav is offline
post #54 of 55 (permalink) Old 03-22-2017, 10:38 PM Thread Starter
peep6543's Avatar
Ended up using the whole can. I was afraid the material would add a build-up on the bars so the fittings and such may not go back on correctly, but it is much thinner than I expected. I did a few coats, and a few sweeps each coat with very good coverage.
After drying 1.5 hours the tack is gone but it steel feels a bit soft. I'm letting it cure overnight before I assemble it and install.
GO COUGS
GO HAWKS
peep6543 is offline
post #55 of 55 (permalink) Old 03-23-2017, 12:40 PM Thread Starter
peep6543's Avatar
Dried, assembled and installed. Pieces went together nicely but the install was a small pain. the clamps have a max open range and they cannot fit over the rails directly from above. Instead I had to disassemble the kit and install each clamp loose at an angle (equivalent of the cross bar facing the sky). Then slide the rails through each clamp. Once they were on loose everything tightened up nicely and looks good. I like the low profile look and the texture seems very durable. The weakest point of the entire kit seems to be the mount points for the factory rails to the roof, as I have read on here several times... I will report back if any noise and significant drop in MPG.
ID:	154434   Click image for larger version
ID:	154442   Click image for larger version
ID:	154450   Click image for larger version
ID:	154458   Click image for larger version
CptCrackers likes this.
GO COUGS
GO HAWKS
peep6543 is offline
Jeep : Cherokee 4dr Sport 4W No reserve... 4x4....Runs well...A Beauty Jeep Cherokee Parts Jeep Cherokee eBay Classifieds 0 07-12-2015 02:40 PM
Jeep : Cherokee 4dr Sport 4W No reserve... 4x4....Runs well...A Beauty Jeep Cherokee Parts Jeep Cherokee eBay Classifieds 0 06-07-2015 08:50 PM
Jeep Cherokee - The Renaissance of Beauty PeteB Jeep Cherokee Reviews 4 02-12-2015 12:57 PM
Jeep : Cherokee 4dr Sport 4W No Reserve Runs Great! A Beauty 4 wheel drive Jeep Cherokee Parts Jeep Cherokee eBay Classifieds 0 12-09-2014 10:10 AM
Trailhawk Black with Black Wheels and Black Interior DanKeo New Member Introductions 20 03-23-2014 08:47 AM
