Wheyman's Build Log - Page 2 - 2014+ Jeep Cherokee Forums
 12Likes
post #11 of 38 (permalink) Old 03-08-2017, 09:24 PM
Palms's Avatar
Can you post some close ups of your antenna mount fan to the bull bar? Want to add to mine.
Palms is offline
post #12 of 38 (permalink) Old 03-08-2017, 09:34 PM Thread Starter
Wheyman's Avatar
So I've been debating with myself about how I wanted to do the switches. I picked up the MicTuning wiring kit knowing that it would probably be temporary. The little round switch looks and feels pretty nice and works well. I initially thought about adding it to the door panel below the fuel door release button but wasn't just really happy with the idea. Then thought about overhead in the sunglasses holder but didn't really like that either. So looking around here and elsewhere on the web thought about picking up the SPod system or just pick up MFC's kit with the console mounting. It looks like a really well thought out and designed system but with a vehicle that is so high tech I didn't really want the rocker switches. They look good but just not for me in this rig. So now looking at the SPod SE but wow do they like it. A little more searching and found the SwitchPros SP-8100 switch panel. Watched videos and read lots of reviews and besides the backlight not being the color I really want I think it will work perfect. The size of it should fit in front of the media center without much issue. Once i get it installed I'll take some pics for your enjoyment
Wheyman is offline
post #13 of 38 (permalink) Old 03-08-2017, 09:37 PM Thread Starter
Wheyman's Avatar
I will get some in the morning to post once it gets light enough. It is just a 2" piece of flat steel that I drilled mounting holes that line up with the holes on top of the license mount. A couple of @45 degree bends and another hole for the antenna to mount through. It's not grounded but when I tried to the SWR went of the meter. So without I am able to get just under 2 top and bottom and about 1 at 20.
Wheyman is offline
post #14 of 38 (permalink) Old 03-09-2017, 09:32 AM Thread Starter
Wheyman's Avatar
Wheyman is offline
post #15 of 38 (permalink) Old 03-09-2017, 12:07 PM
Palms's Avatar
Thank you sir!
Wheyman likes this.
Palms is offline
post #16 of 38 (permalink) Old 03-10-2017, 11:39 AM
pilgrim's Avatar
Looks great..wheels look better solid black. What color Duplicolor did you go with and how did you prep the wheels for painting? Already thinking about painting mine black..
pilgrim is offline
post #17 of 38 (permalink) Old 03-10-2017, 03:11 PM Thread Starter
Wheyman's Avatar
I used
Dupli-Color BCC0427 Brilliant Black
Exact match for our black paint (multi color flakes)
I think it is for paint code APX or SPX. I used a scotch bright pad to rough then up and get any residuals off of the wheels followed by alcohol wipes to make sure they were clean. Two coats of primer with three coats of paint and two coats of clear. At least 15 minutes between each coat.
Wheyman is offline
post #18 of 38 (permalink) Old 03-10-2017, 03:45 PM
pilgrim's Avatar
Thanks..good job.
Wheyman likes this.
2016 Jeep Cherokee Latitude 4x4 AD1
3.2 V6
Convienience Package
8.4 Uconnect
Sandstone Pearl
pilgrim is offline
post #19 of 38 (permalink) Old 03-12-2017, 09:14 PM Thread Starter
Wheyman's Avatar
So the weather finally cooperated enough for me to get the SwitchPros switchpod installed. I also added some rock lights but have to wait until I get the sliders installed before I can add the rest. Still a little light out so hard to get the real effect but I think they look pretty good.
ID:	152474   Click image for larger version
ID:	152482   Click image for larger version
David_Baker and Duke2015 like this.
Wheyman is offline
post #20 of 38 (permalink) Old 03-13-2017, 11:09 PM
edge600's Avatar
Those are awesome!! Wheel'n trip is less than a month away!!
Wheyman likes this.
edge600 is offline
My 3.2L TH - Ownership log JAhmed 2014+ Jeep Cherokee General Discussion 126 11-28-2016 11:16 AM
Overlanding build myfirstcherokee Interior 26 08-19-2016 04:37 PM
Is my TH order will never be build? 838Joel Cherokee Purchasing and Orders 10 05-10-2014 11:04 AM
My TH started build nmbluept Cherokee Purchasing and Orders 9 03-28-2014 09:34 PM
Is the build date actual date of build or when VIN is assigned hammick Cherokee Purchasing and Orders 1 12-10-2013 06:10 AM
