Installing RRO rock rails - 2014+ Jeep Cherokee Forums
 4Likes
post #1 of 16 (permalink) Old 03-19-2017, 10:50 PM Thread Starter
Pondhopper's Avatar
1st pic is be start.
2nd pic is removing the end plastic retainers and there is a 8 mm screw at front not pictured being removed.
3rd and 4th is after a bit of manhandling the plastic rail off its tabs.
5th and 6th it the plastic tab that hangs down after you remove the plastic rail and then me trimming it with tin snips.
7th and 8th was after washing the pinch seam of dirt i the drilled 6 hole where the tabs were and putting in the rubber nut plug using the rail as a guide with a 9/16 drill bit.
9th is me lifting the rail up with a floor jack to line the holes up. (I had to put the jack on a block because I had the TH on small ramps so I could work under it. Yes I am a big fellow)
ran out of room for more pics continued in the next post
Pondhopper is offline
post #2 of 16 (permalink) Old 03-19-2017, 10:54 PM Thread Starter
Pondhopper's Avatar
ok miss pics here they are
ID:	153578   Click image for larger version
ID:	153586   Click image for larger version
ID:	153594   Click image for larger version
ID:	153602   Click image for larger version
ID:	153618   Click image for larger version
ID:	153626   Click image for larger version
ID:	153634   Click image for larger version
post #3 of 16 (permalink) Old 03-19-2017, 11:01 PM Thread Starter
Pondhopper's Avatar
Next pic I drilled a hole 1/2" above the notch 8 to a side with a 1/4" drill bit though the pinch seam. (That was the hardest part of this is the drilling though the pinch seam as it broke 5 bits when all was done
Than I tightened all the bolts and nuts across the bottom of the TH and all the bolts going into the in tho the rubber nuts.
Now the after picture. I took me 4 hours to do it in. i don't have a shop I did it out in the drive way.
Hope you like the tutorial.
ID:	153650   Click image for larger version
ID:	153658   Click image for larger version
ID:	153666   Click image for larger version
DenGas144 and David_Baker like this.
post #4 of 16 (permalink) Old 03-19-2017, 11:16 PM
Xinarin13's Avatar
I wish mine had come even close to that correct...
"Blu"
Valpacer "Aussie" Lift
Rocky Road Super Sliders
Safety Tech Group
Comfort and Convenience Group
Panoramic Sunroof
Xinarin13 is offline
post #5 of 16 (permalink) Old 03-20-2017, 10:51 AM
Looks very nice. Good job on the install.
post #6 of 16 (permalink) Old 03-20-2017, 11:05 AM
DenGas144's Avatar
I hate to be there bearer or bad news, but it looks like you might have mounted your rock rails on the wrong sides.. They should match the lines of your Jeep better. Is there a gap on BOTH the driver and passenger side under the front doors?
ADDED: If you look at the gap in the front and the rear of your slider, the front gap is much larger than the back gap.
DenGas144 is offline
post #7 of 16 (permalink) Old 03-20-2017, 03:58 PM
Xinarin13's Avatar
If he had them on backwards, wouldn't they be off at the wheel wells?
"Blu"
Safety Tech Group
Panoramic Sunroof
post #8 of 16 (permalink) Old 03-20-2017, 04:22 PM Thread Starter
Pondhopper's Avatar
Yes the gap is the same on both sides I did not get the cover that goes over top of the rails. That gap is where a line of sealant goes along the bottom of the rocker panel. I will make something to cover the gap this weekend. See the first picture in the second set of pictures to see the ridge.
post #9 of 16 (permalink) Old 03-20-2017, 04:24 PM Thread Starter
Pondhopper's Avatar
Also I think the cut out is for the opening of the rear doors
post #10 of 16 (permalink) Old 03-20-2017, 05:47 PM
I think dengas is right. The sloped end is at the back..
Pic below is from the rockyroad page
http://www.rocky-road.com/media/2014...-side-shot.jpg
RRO Rock Rails Install john.thwaite 2014+ Jeep Cherokee General Discussion 49 10-10-2016 09:27 AM
RRO rock rails with the step Mustangwill Exterior 0 04-19-2016 09:29 AM
Rock Rails (Mopar vs. RRO) Gary Ray Owners' Garage 87 03-16-2016 04:32 AM
Install RRO Rock rails in Los Angeles (SFV) knuckls 2014+ Jeep Cherokee General Discussion 11 09-14-2015 06:21 PM
RRO non slider rock rails gundad Exterior 7 09-03-2014 04:31 PM
