Is a sway bar release worth wild on a Cherokee TH - Page 2 - 2014+ Jeep Cherokee Forums
post #11 of 20 (permalink) Old 05-08-2017, 08:58 AM
edge600's Avatar
We have a tire rotation due soon (likely this weekend)... I will disconnect and play in the ditches (culverts). Just about any around me put the KL on two wheels so I know they will fully stuff and droop the front fully.
I'll be home for at least the weekend next weekend (Mother's Day) I'll give you a hand so I can check it out!
SS_Syndicate likes this.
edge600 is online now
post #12 of 20 (permalink) Old 05-12-2017, 05:25 PM
rski's Avatar
disconnecting the front link will not change flex in the front but it will in the rear ..the front is limited to the extension of the strut the how ever if disconnected in the rear it will then flex to the extent of the spring or shock which ever extends the furthest.. front disconnects are useless..
2016 JEEP CHEROKEE SPORT ADI...LED INTERIOR, FALKEN WILD PEAKS A/T 3W 255/65/17, REPLICA TRAILHAWK GLOSS BLACK RIMS, PATRIOT URBAN DEFENSE COLOR SCHEME (HAZARDSKY/AUSSIE/VALPACER LIFT DESIGN) ROLA VORTEX CARGO BASKET, THULE RAPID CROSSBAR SYSTEM, EXTERIOR LED LIGHTS.GOBI LADDER , BLACK 5GL JERRY CAN
GOD BLESS THE REPUBLIC....
rski is offline
post #13 of 20 (permalink) Old 05-13-2017, 07:42 AM
SS_Syndicate's Avatar
This is just wrong....
The fact that the front has a strut and the rear is coil sprung with shocks makes no difference. The rear is droop limited by the shocks in the same manner that the front is droop limited by the struts.
Flex isn't just about droop it's also stuff. Sway bars are great for road stability, but they share forces from one wheel with the other. This means that when one tire is stuffed the droop of the other side is being limited by the sway bar. By disconnecting the sway bar you allow each side of the axle to use it's full travel completely independant of the other side.
The front has a MUCH more stout sway bar and thus more drastically limits travel. It also has more travel available due to the longer axle shafts (less CV bind).
SS_Syndicate is offline
post #14 of 20 (permalink) Old 05-13-2017, 08:46 AM
edge600's Avatar
Exactly what he said!^^^^
Oh and this is my project today as well.
post #15 of 20 (permalink) Old 05-15-2017, 08:18 PM
edge600's Avatar
It defiantly flexes better without the front swaybar. And it feels much better off road as well. The front tire is 16 inches off the floor, all other tire still on concrete.
ID:	160761   Click image for larger version
ID:	160769   Click image for larger version
ID:	160777   Click image for larger version
ID:	160785   Click image for larger version
post #16 of 20 (permalink) Old 05-15-2017, 11:35 PM Thread Starter
Pondhopper's Avatar
OK how about a electronic disconnecting rear sway bar?
Pondhopper is online now
post #17 of 20 (permalink) Old 05-16-2017, 12:17 PM
Snowhawk2015's Avatar
Originally Posted by edge600 View Post
It defiantly flexes better without the front swaybar. ...
Definitely defiant!
Snowhawk2015 is offline
post #18 of 20 (permalink) Old 05-16-2017, 12:29 PM
edge600's Avatar
Originally Posted by Snowhawk2015 View Post
Definitely defiant!
Lol well English is my first language, oh wait that's not how that works ha!
post #19 of 20 (permalink) Old 05-16-2017, 12:59 PM
Awesome... It's the better ride off-road that has me the most interested. I disconnect my sway bar on our JKU-R all the time just to smooth out dirt roads.
post #20 of 20 (permalink) Old 05-16-2017, 02:21 PM
edge600's Avatar
I liked how it felt quite a bit. If say, the driver front is at full droop and turned all the way driver, the swaybar will contact the steering link. So I'm still going to proceed with my original plan.
Front Sway Bar Disconnect henry2513 Wheels, Tires, Brakes, and Suspension 7 06-03-2016 04:35 PM
Sway Bar Disconnect?? Meeko 2014+ Jeep Cherokee General Discussion 2 02-11-2016 03:04 PM
Sway bar links Backwoods Raider Off-Road 3 12-19-2015 08:50 AM
Sway Bar Disconnect zzjdzz Off-Road 12 05-01-2015 11:32 AM
