Is a sway bar release worth wild on a Cherokee TH - 2014+ Jeep Cherokee Forums
post #1 of 20 (permalink) Old 05-03-2017, 11:05 AM Thread Starter
Pondhopper's Avatar
Is a sway bar release worth wild on a Cherokee TH. With our limited travel of our suspension would there be any benefit to disconcerting the sway bar. If there is can an electronic sway bar disconnect fit under the TH? Allot of questions would arise if an electronic sway bar was available like with and torque spec of the new sway bar.
Pondhopper is offline
post #2 of 20 (permalink) Old 05-03-2017, 11:11 AM
SS_Syndicate's Avatar
There would be a benefit. The Jeep would ride better on the trail and flex far batter. However, the JK sway disconnect you have pictures will not work on a KL. It is designed to work with a totally different suspension set-up.
Due to the space availability, it is likely the only disconnecting that could be employed on the KL is manual, at the links.
What is not known is how the steering rack and CV joints will hold up to increasing the travel. Only time will tell as people start to try it. We are one of those people but want to find the limits of our current set-up first so we can comment more thoroughly on the Pros VS Cons.
SS_Syndicate is offline
post #3 of 20 (permalink) Old 05-03-2017, 12:43 PM
edge600's Avatar
Will the front swaybar not come in contact with the lower control arm and/or the steering tie rods if disconnected? It looks like it would to me, but I haven't tried yet.
edge600 is offline
post #4 of 20 (permalink) Old 05-03-2017, 12:50 PM
You would definitely need to disconnect both sides so one side drooping wouldn't drive the bar into the arm on the opposite side. One both links are disconnected it looks like ther should be room since it wouldn't move. How it would be held in a safe place will need more brain storming if/when I do it.
post #5 of 20 (permalink) Old 05-07-2017, 09:04 PM
Snowhawk2015's Avatar
Picture I sent you earlier.
Snowhawk2015 is online now
post #6 of 20 (permalink) Old 05-07-2017, 09:36 PM
edge600's Avatar
It doesn't look like it's possible to me, but without trying I can't say. At the wheel I believe it has about 8" travel but I don't know what that equates to where the swaybar is. Then you have the dilemma of keeping the sway bar from moving once it's undone.
edge600 is offline
post #7 of 20 (permalink) Old 05-07-2017, 11:22 PM
So tomorrow night get a wrench and disconnect the links, take some pictures, drive up on a rock, take more photos and report back to us.
Standing by...
post #8 of 20 (permalink) Old 05-07-2017, 11:41 PM
edge600's Avatar
Standing by...
Well I'm in Kalispell and my Jeeps in Ogden so.....
edge600 is offline
post #9 of 20 (permalink) Old 05-08-2017, 06:41 AM
Hmmm ..... Well that's not going work for me. That 2 week gig is turning into 2 months. You going get to CA before the snow flies again?
post #10 of 20 (permalink) Old 05-08-2017, 07:23 AM
We have a tire rotation due soon (likely this weekend)... I will disconnect and play in the ditches (culverts). Just about any around me put the KL on two wheels so I know they will fully stuff and droop the front fully.
Front Sway Bar Disconnect henry2513 Wheels, Tires, Brakes, and Suspension 7 06-03-2016 04:35 PM
Sway Bar Disconnect?? Meeko 2014+ Jeep Cherokee General Discussion 2 02-11-2016 03:04 PM
Sway bar links Backwoods Raider Off-Road 3 12-19-2015 08:50 AM
Sway Bar Disconnect zzjdzz Off-Road 12 05-01-2015 11:32 AM
