To my fellow Arizonans - Page 2 - 2014+ Jeep Cherokee Forums
 3Likes
post #11 of 13 (permalink) Old 06-21-2016, 10:30 AM Thread Starter
ua_who's Avatar
AC holds up just fine!
The brown leather gets a bit hot though.
I've driven offroad out in the desert with it almost this hot. AC pumping the whole time without any problem.
The transmission starts to heat up a bit, especially with low range. Otherwise the heat doesn't bother the TH much at all.
1.5" aussie lift, RRO step rails, rear hatch LED lighting
Damaged lower front facia - worn as a badge of honor.
ua_who is offline
post #12 of 13 (permalink) Old 07-02-2016, 02:11 AM
ua_who said "The transmission starts to heat up a bit, especially with low range." I've had my TH tranny heat up quite a bit off-road when crawling up and down hills and such. What I have found differs in that it seems to handle the temperatures better (stays lower) if I do go into low-range and limit the tranny to shifting no higher than 3rd. I suspect that keeping it in low-range forces the RPMS higher and thus forces more fluid through the transmission cooler. That is just a guess on my part but I can't come up with any alternate explanation. In the past I've had the tranny temperature go up as high as about 232° (in hi-range) with no ill effects but I try to keep it no higher than around 200° and low-range seems to help with that.
2015 Trailhawk w/ V-6. Factory trailer package includes transmission cooler.
warzim is offline
post #13 of 13 (permalink) Old 07-02-2016, 08:52 AM
I believe gears 1-4 use the dog clutches, so there is less mechanical slip. Slip is where a lot of heat is generated.
I'm sure somebody will direct me on the exact gears.
Rojhan is offline
When you drive by a fellow jeepcherokeecluber AGP The Car Lounge 16 06-07-2016 03:15 PM
Any fellow members with diabetes? biggee72 The JCC Lounge 20 04-16-2016 05:22 PM
Question for my fellow Sport owners! dylan5598 Exterior 0 02-17-2015 09:30 PM
Fellow Canadians - Mopar Owner Connect wpgguy 2014+ Jeep Cherokee General Discussion 7 10-15-2014 02:04 PM
Hello Fellow-Jeepers! Annekem New Member Introductions 7 08-08-2014 12:47 PM
