Snow Tires? - 2014+ Jeep Cherokee Forums
 10Likes
post #1 of 30 (permalink) Old 12-10-2015, 09:08 AM Thread Starter
Raylee2484's Avatar
Snow Tires?
In January I will be relocating to Burlington, Vermont. What should I be considering, if anything, in the way of snow tires. I am just looking to get around town, not adventuring into the wilderness. Thanks for your input.
2015 Cherokee Limited | 4x4 | 3.2L | Deep Cherry Red | Beige Frost Premium Leather | Panoramic Moon Roof | Luxury Group | Tow Package | 8.4AN | Born January 29, 2015
Raylee2484 is offline
post #2 of 30 (permalink) Old 12-10-2015, 03:36 PM
Check with your dealer on snow tires. You have a 4x4 so should not need anything too agressive but, if legal in your area, studs would be an added safety feature on slippery roads and ice. - Ted
('14 cherry TH V-6, Comfort/Tech/Tow)
'15 Wrangler JKU Altitude, loaded.
TedB is offline
post #3 of 30 (permalink) Old 12-10-2015, 03:54 PM
rumrunner's Avatar
daughter started college there this fall, nice area, love the roads, watch out for 89 tho lots of ppl obsessed with going over 100mph for some reason. back to your question, they drive fast in VT so I would lean toward performance tires or Bridgestone Blizzaks (they are good at highway speed and not noisy) over aggressive like Firestone Winterforce
for entertainment you might check out the craigslist for snow tires in VT. our sizes can be hard to find but I found more in VT than in MA. wut size you running now?
rumrunner is offline
post #4 of 30 (permalink) Old 12-10-2015, 04:34 PM
rumrunner's Avatar
these bad boys have been listed since before Thanksgiving. I almost drove up for them
https://burlington.craigslist.org/wto/5334570792.html
post #5 of 30 (permalink) Old 12-12-2015, 12:13 AM
andialpha's Avatar
I got Michelin X-ice from Tirerack.com. I had good experience with them in the past. Overall the winter tires are not for adventures. They have much better traction and much shorter braking distances at cold temperatures compared to all season. So even when just driving around town it's worth having them. the added cost is not very high as you don't run down the stock tires as fast.
I got also aluminum wheels from tirerack. I'm not to excited about the look but they are ok. I will remove the blue protective foil from the wheel hubs when I have time.
ID:	98626   Click image for larger version
Feb 2015 TRAILHAWK: Mango, SafetyTec, Cold Weather, Technology, Comfort/Convenience, Trailer Tow, Brown Leather, Ventilated Seats, 3.2L, CommandView Sunroof, Connect/NAV, 9 Speaker/Sub, Hood Decal
andialpha is offline
post #6 of 30 (permalink) Old 12-12-2015, 10:01 AM
rumrunner's Avatar
~ andialpha - this are really nice looking, wut size you get?
the others I posted 12/10 sold apparently but found a couple more if anyone in Burlington VT area is looking. this is my size - don't know what size anyone else is using
https://burlington.craigslist.org/wto/5353342788.html
https://burlington.craigslist.org/wto/5352346645.html
https://burlington.craigslist.org/wto/5343109493.html
post #7 of 30 (permalink) Old 12-12-2015, 10:09 AM
andialpha's Avatar
17"
This is what I got:
17X7.5 SPORT EDITION P5 ANTHRACITE
4 In Stock $112.00 $448.00
433MHZ TIRE PRESSURE SENSOR
4 In Stock $40.00 $160.00
245/65R-17 MICHELIN LATITUDE X-ICE XI2
DOWNLOAD WARRANTY BROCHURE PDF
4 In Stock $141.20 $564.80
MOUNT AND BALANCE (NO CHARGE)
4 In Stock N/C N/C
post #8 of 30 (permalink) Old 12-12-2015, 10:35 AM Thread Starter
Raylee2484's Avatar
I am currently running 225/60 R18 all weather tires. I see you have gone to 17's. A choice, or are you replacing size for size?
post #9 of 30 (permalink) Old 12-12-2015, 10:39 AM
monkeyboy's Avatar
I kinda like those wheels but thinking black might look best with the mango. Do they make in black? And, what brand are they?
Bobo the MangoTango: 2015 TrailHawk | 3.2 V6 | Cold Weather - Tow - Convenience
Scangauge II | WeatherTech Cargo mat | Backup light LEDs | JW Speaker Fog Lights | Headlight LEDs | Custom Step Rails
GOBI Stealth Rack: Ladder | Hi-Lift Jack mount | Rotopax Lox Mounts & Gas Packs | DIY Quick Fist Shovel mount | CVT 55" Awning | TRED mounts
monkeyboy is offline
post #10 of 30 (permalink) Old 12-12-2015, 10:52 AM
Do you really have *all weather tires* or all seasons ? Big difference, because the newer *all weather tires* are winter rated with the snow flake symbol. Tests show they do pretty well on snow and ice, though not quite as well as dedicated winters.
@andialpha has a Trailhawk, so the 17s are standard size. Only the Limiteds and Altitudes have 18" wheels.
In your case, you could save a little bit of money by going with 225/65/17 tires on 17" wheels ; those would have the exact same height and width as your 225/65/18 tires. Just mention you need thin wheel weights to the person who will eventually install and balance the tires on 17" wheels (clearence with front brake calipers is tight with most aftermarket 17" wheels).
snow driving on stock OEM (none TH) tires rumrunner 2014+ Jeep Cherokee General Discussion 29 12-29-2015 02:09 PM
best snow tires for Cherokee LTD 3.2 Bull34 2014+ Jeep Cherokee General Discussion 25 12-24-2015 11:56 AM
OEM tires on Cherokee Limited FWD good for snow? Neo 2014+ Jeep Cherokee General Discussion 14 10-02-2014 09:16 AM
Considering snow tires for your TH? Carpenjo Wheels, Tires, Brakes, and Suspension 27 02-04-2014 07:50 PM
Let it Rain, Let it Sleet, Let is Snow, Let it Snow!! keef 2014+ Jeep Cherokee General Discussion 6 12-08-2013 08:09 PM
