Starter replacement = left speaker not working - 2014+ Jeep Cherokee Forums
post #1 of 3 (permalink) Old 11-01-2016, 10:00 PM Thread Starter
Hello, I have a 2002 Laredo. I needed to get the starter replaced and once I turned it on it seemed like something was off with the audio. After some tests, it appears my passenger side dash speaker is not working.
it seems very odd, but it was working pre the replacement. Any validation that this could be related? do I need to replace the speaker? or is it a connection issue?
thanks a million forum friends!!
BEEPBEEPJEEP is offline
post #2 of 3 (permalink) Old 11-02-2016, 03:38 AM
Hello and welcome to the forum. However, this is a forum for the 2014 and up regular Cherokee. So I'm not sure you'll find the answer you are looking for. Best of luck.
post #3 of 3 (permalink) Old 11-02-2016, 10:30 AM
Doubt they are related unless the speaker wiring somehow routes to the engine compartment and could have been damaged in replacement...
First check would be to see if the speaker is connected. Pull the grill and speaker to see if wires are all intact. Then you can check output from the amp to the speaker either with a tester or plug in a different speaker. Swapping the speaker to another known-good position is also a test of that speaker.
HTH, good luck.
Speaker swap out in 2016 TH, 6 speaker 8.4A pt. II. Champagne InHand 2014+ Jeep Cherokee General Discussion 69 12-27-2016 08:38 PM
9 speaker vs 6 speaker system Joesass Electronics, Audio, and Lighting 20 11-21-2016 11:09 PM
JEEP CHEROKEE - 2016 Battery Replacement and Radio Replacement jatin virmani 2 Engine and Technical Discussion 11 05-07-2016 12:02 AM
Lost signal to left rear door speaker NScherry Electronics, Audio, and Lighting 2 03-26-2016 05:17 PM
Blown door speaker. Warranty OEM or aftermarket replacement? Deputymax Electronics, Audio, and Lighting 10 02-21-2016 02:04 PM
