FOR SALE Budget Boost Lift Kit - Hazard Sky - Page 2 - 2014+ Jeep Cherokee Forums
 218Likes
post #11 of 392 (permalink) Old 07-14-2016, 09:56 PM
schira's Avatar
Originally Posted by HazzardSky View Post
I'll get invoices out in the next few days. I appreciate your patience. Work (at my main job) is especially brutal this week.
No rush, I know how that goes. Appreciate it.
Sent from my SM-G920P using Tapatalk
2016 Jeep Cherokee Trailhawk 3.2L Rhino
schira is offline
post #12 of 392 (permalink) Old 07-14-2016, 10:33 PM
Originally Posted by RiseUpBears View Post
Has any information been presented that discusses what options there are for larger tire sizes with this lift? In the past the limiting factor for larger tires was rub when turning the wheels to lock, correct?
You are spot on however the lift does not increase the clearance for any part apart from top of front tyre to the lower spring mount. 245/70 or 265/65 both fit with or without the lift, any larger requires trimming of metal or plastic to fit.
post #13 of 392 (permalink) Old 07-15-2016, 01:49 AM
Xinarin13's Avatar
You are spot on however the lift does not increase the clearance for any part apart from top of front tyre to the lower spring mount. 245/70 or 255/65 both fit with or without the lift, any larger requires trimming of metal or plastic to fit.
I didn't trim at all... I have 265 65 and Aussie lift...
"Blu"
Valpacer "Aussie" Lift
Rocky Road Super Sliders
Safety Tech Group
Comfort and Convenience Group
Panoramic Sunroof
Xinarin13 is offline
post #14 of 392 (permalink) Old 07-15-2016, 03:34 AM
Oops.. yep, typo, meant 265
Xinarin13 likes this.
post #15 of 392 (permalink) Old 07-15-2016, 11:16 AM
Thank you for the feed back...
Ghost202 is offline
post #16 of 392 (permalink) Old 07-15-2016, 09:26 PM
airishfan's Avatar
RRO said a lift kit would not work so how do this lift kit work I love to lift my TH and I interested in one
airishfan is offline
post #17 of 392 (permalink) Old 07-15-2016, 10:11 PM
RRO and all others are interested in a 2+ in lift they can sell for hundreds or thousands of dollars. They are not interested in this style of lift as there is not enough money in it.
This is simply increasing the ride height of the rear by 2 x 3/8 in spacers (one above and one below) and reloacting the position of the front strut in the knuckle. All dreamed up in Valpacers garage using bits he had in the shed.
Total net lift is around 30mm or 1.25 in, plus anouther 12mm or 1/2 in from larger tyres. Not enough for the likes of RRO or ARB etc. And its acheived with $50 of parts...
post #18 of 392 (permalink) Old 07-15-2016, 10:11 PM
Xinarin13's Avatar
RRO is wrong... it can be done, but they don't feel they can make enough money off of lifting these. It uses spacers to raise up the rear springs, and the front is as simple as moving the strut in the mounting bracket. Took me and a buddy less than 2 hours to do.
"Blu"
Safety Tech Group
Panoramic Sunroof
post #19 of 392 (permalink) Old 07-16-2016, 01:12 AM
airishfan's Avatar
thanks , did it change how it drives and did you get bigger tires and you know how much bigger you can go .
post #20 of 392 (permalink) Old 07-16-2016, 01:48 AM
Xinarin13's Avatar
When I first put the lift on, I could definitely tell it was taller... when you get in, you have to sit up a touch higher... your view out the windshield is a bit taller, and the tennis balls hanging in my garage hit early now.
Aside from that, I really cannot tell they are on there... Driving characteristics are still the same... I still drive as aggressively as before... you can hear the tires ever so slightly with the radio and air off around 35-45 mpg, but then it goes away. They might slow my acceleration down a touch, but that is probably just my imagination... which brings me to my next answer.
I did get larger tires. I have tires that are basically 1.1" taller and 1.1" wider (265/65R17 Goodyear Wrangler Duratrac). They are the "largest" (maxing out width and height) tire you can put on without trimming plastic and metal. You can go with a slightly taller tire the same width as the stock tire (245/70R17) without rubbing as well, but if you add the width it won't fit without grinding. Supposedly you can fit upwards of 31" - 32" tires if you remove the plastic wheel liner, grind the metal pinchweld, and (possibly unnecessary) add wheel spacers (different than the spring spacers that lift the vehicle, these would push your wheels out from the hub).
Sorry for such a long answer... I just got forum access back for my computer and remembered how much easier it is to type with 10 digits instead of just thumbs...
"Blu"
Safety Tech Group
Panoramic Sunroof
SOLD
[Closed] [Group Buy] Complete Budget Lift Kit
HazzardSky Cherokee (KL) Parts & Accessories 316 07-27-2016 05:02 PM
Budget Lift Safety Concern myfirstcherokee Wheels, Tires, Brakes, and Suspension 116 03-12-2016 08:05 AM
2" Coil Spacer Budget Boost Jeep TJ LJ ZJ Lift Kit Jeep Cherokee Parts Jeep Cherokee eBay Classifieds 0 12-06-2014 12:50 PM
YELLOW 1" Coil Spring Spacer Budget Boost Jeep TJ LJ ZJ XJ MJ Lift Kit Jeep Cherokee Parts Jeep Cherokee eBay Classifieds 0 12-06-2014 12:50 PM
Lift kit ? THCjeep 2014+ Jeep Cherokee General Discussion 4 03-02-2014 12:14 AM
