Trail Hawk Detail - 2014+ Jeep Cherokee Forums
 23Likes
post #1 of 38 (permalink) Old 05-26-2015, 08:29 AM Thread Starter
Trail Hawk Detail
Anyone who has followed my posts knows I am a big fan of the Gtechnig products. I find the coatings easy to apply, super hydrophobic and nice and slick. I get about 18 months of solid performance after which time the protection is still there but the crazy beading has significantly fallen off. I opted to use the EXO on the new Jeep because it is a proven product in my opinion and I will re-apply in 18 months. In the meantime the self cleaning aspects of the EXO and the size of the vehicle make it a good fit for me.
A thank you to Vega for posting the PSA on the Werner platform. I picked one up have never had an easier time polishing the roof. Just needed to pull it out of the garage to get room next to the car.
Process was the same as usual:
Interior vacuumed
Glass Cleaned with Stoners invisible glass & glass MF towel
Seats wiped down with distilled water and then coated with Geyon Leather coat.
All fabric was treated with the Wolfs fabric guard. (This little bottle has lasted forever)
Screens wiped down with a euro shag and a ONR
Wheels
Wheels cleaned with sonax wheel cleaner plus
Various sizes of wheel woolies and other brushes.
Side walls scrubbed with TAW and stiff brush
Body
Wash with TAW to remove any dealer applied LSP.
Decon with Iron X
Follow up with yellow clay and ONR as Lube (did not get much-Jeep has 600 Miles on the clock)
re wash Lusso oro shampoo
Blown dry with a master blaster
Drips dried with an Uber drying towel.
Trim and decal taped up with Kamikaze tape
Polishing stage
Polished the whole car using my 3" Rupes with a yellow polishing pad and Rupes Yellow Polish.
Spot areas corrected with the Green Rupes pad with green polish,
Car was wiped down with IPA 15%
Correction cheked with RUpes Light
Spot areas polished with Rupes Green Pad and M100 followed with Yellow pad and yellow polish
Car was wiped again with IPA 15% and rechecked.
LSP Paint
I applied 2 coats of EXO v2
Used included applicator (liked the best of any I have used so far)
LSP trim
Geyon Trim
Before:
Cleaning up the wheels & Tires
Wheel bucket at the end -YUCK
I was rushing thru the wash process because the sun was getting pretty hot and I did not want to deal with water spots so I skipped the extensive pictures of the wash.
Found some left over adhesive on the B pillars that was easily removed with a 15% IPA mix and a all purpose MF towel
Clay tools getting ready to go:
After the car was dried and pulled into the garage, I taped up all the trim. This car has more trim that I have ever dealt with (or want to deal with) It took 1.5 rolls of the tape to cover the sensitive areas.
I hate taping and I stink at it. Not the prettiest job, but it worked for me.
Polishing the car I prepared for a 5 inch polish pad and a 3 inch pad. Dispite the large panels I opted to use the 3" for the entire detail because of the abundance of trim and the different ridges on most panels. I felt like the larger pad would have been a detriment.
Polishing done!
Tape off
Wiped with 15% in prep for inspection and coating
Onto the Coating
Sorry, I did not get pics of the applicator before I started.
This (included with the EXO coating) is by far the best, easiest applicator for applying coating that I have used.
After applying 2 coats of EXO it was plates off to get the trim across the whole back and around the Wheel wells and rockers of the Jeep.
Coated all trim with Geyon Trim, I love this stuff. Spreads easily and looks great.
Wheels were coated with Opticoat Gloss Coat for Durability and Tires were treated the following day with Geyon Tire
Good shot of Geyon tire against clean untreated section. I can never get the last bit on the bottom without rolling the car back so I left a swipe to show the difference.
Left to cure over night
At the end this is the amount used for the Jeep. This is a 50 ML bottle as I was afraid to run short. I will be using the balance on my Infiniti shortly.
Areas covered were All the paint, decal, door jambs, paint under the hood.
Pulled out the next day:
Later in the day
Thanks for looking, feedback/comments and question always appreciated.
UN4GTBL, madchemist24, eak and 7 others like this.
jsf721 is offline
post #2 of 38 (permalink) Old 05-26-2015, 09:33 AM
So....what time can I drop mine off!? That looks amazing.
zzjdzz, eak and cedricmordrin like this.
Iron9s is offline
post #3 of 38 (permalink) Old 05-26-2015, 09:34 AM
ptrudel's Avatar
x2 lol...You've got tons more patience than I do, but that looks awesome!
zzjdzz likes this.
ptrudel is offline
post #4 of 38 (permalink) Old 05-26-2015, 09:40 AM
zzjdzz's Avatar
zzjdzz is offline
post #5 of 38 (permalink) Old 05-26-2015, 09:57 AM
eak
eak's Avatar
Member of the month!
Later in the day
You should submit these for member of the month!
EAK
zzjdzz likes this.
Lake Orion, MI
Granite Crystal Metallic Date ordered: 03/Jan/2014 Delivered: 4/Mar/2014
Granite Crystal Metallic TH KL •|||||||•| 3.2L V6 24V VVT | 27E | 9-Spd 948TE 4WD
TOW |Comfort Convenience | Brown Leather | Technology| Uconnect 8.4AN
Cold Weather | Black Hood Decal | 9 Amplified Speakers w/Subwoofer | CD
eak is offline
post #6 of 38 (permalink) Old 05-26-2015, 12:11 PM
Kevin@kamloops's Avatar
Looks like it just came out of the showroom , Probably better than some showrooms Now you need to take it off roading and you can start all over again Lol Seriously though , Its all part of pride of ownership , You did a great job .
UN4GTBL and zzjdzz like this.
Kevin@kamloops is offline
post #7 of 38 (permalink) Old 05-26-2015, 12:48 PM
Mudman1's Avatar
That shines like a diamond in a goat's ass man! Awesome job. I did mine about a month ago, when we had a nice weather brake up here. I washed it twice then used the Clay Bar kit on it twice, then waxed with Eagle One. It still beads and looks good (minus the pollen) but the wax I use does not last 18 months...more like 4 months.
Thanks for sharing. Like others said, go and get it dirty now. No sense in joining the 4x4 mall crawler community.
zzjdzz and Migero like this.
Mudman1 is offline
post #8 of 38 (permalink) Old 05-26-2015, 03:09 PM Thread Starter
Thanks, its the better part of day affair, but now I am done for almost 2 years. The rain will remove 99% of the junk and washing is so easy.
jsf721 is offline
post #9 of 38 (permalink) Old 05-26-2015, 03:10 PM Thread Starter
I just like a clean car.
I have little patients for things that don't interest me.
jsf721 is offline
post #10 of 38 (permalink) Old 05-26-2015, 03:11 PM Thread Starter
Its a glass coating.
its amazing technology.
jsf721 is offline
New Trail Hawk jsf721 2014+ Jeep Cherokee General Discussion 15 06-28-2015 06:57 AM
New Trail Hawk madchemist24 2014+ Jeep Cherokee General Discussion 12 04-18-2015 12:17 AM
Trail hawk YKtotheB 2014+ Jeep Cherokee General Discussion 4 02-20-2014 09:40 PM
new Trail Hawk TrailHawkSF Owners' Garage 8 01-26-2014 04:38 PM
trail hawk Carol24 Cherokee Purchasing and Orders 9 11-10-2013 10:21 AM
