Dissolve/Remove Pine Sap? - Page 3 - 2014+ Jeep Cherokee Forums
 13Likes
post #21 of 26 (permalink) Old 05-02-2016, 01:50 PM
Originally Posted by grandpadoc View Post
I tried everything including razar blading it off the clearcoat on my truck.. It worked, but found a simpler way...acetone ! These new clearcoats seem to be very durable, even took off pinstriping on my Bushtec pull behind motorcycle trailer with Original Easy Off oven cleaner. Hey I was desperate, so "at your own risk".
Acetone is a great glue/goo/sticky stuff remover. Possibly the best. But... it melts plastic, so beware
post #22 of 26 (permalink) Old 05-02-2016, 05:07 PM
siggyd's Avatar
Rubbing alcohol is the answer , also called "isopropyl alcohol". Walmart should have it. I have used it many times, let it soak a bit.
Siggy
2015 Cherokee Ltd, Active Drive II, Billet Silver, 4x4, V6, 8.4 AN, Trailer Pkg., Pwr.Liftgate, Sunroof,
9 Spkrs., ACC, Roadmaster Towing brackets
installed for RVing..
siggyd is offline
post #23 of 26 (permalink) Old 05-02-2016, 05:28 PM
jeff215267's Avatar
sap remover is some sort of alcohol,ardexwax.com sells it,luckly i have a bottle on hand and it works great.
jeff215267 is offline
post #24 of 26 (permalink) Old 05-02-2016, 10:35 PM
Dab a rag into some gas and rub off the sap. You don't want gas on paint everyday but it's the best at dissolving tar I've found. I can only assume it will solve your sap issue. On a side note the paintless dent repair is awesome on minor/medium hail damage. I had 3 vehicles repaired last year and you can't even see a ripple.
Dirtymutt is offline
post #25 of 26 (permalink) Old 01-04-2017, 02:51 AM
tbrou6229's Avatar
Hello, I know this thread is kinda old, but I'm enjoying looking through older threads and commenting.
Ive found that hand sanitizer on a Clorox Cleanup wipe works wonders. They don't work separately, but combined the San basically wiped off. Put a bit of sanitizer on the sap, then clean it with the Clorox wipes.
~Mods List~ (In Progress!)
The First Family Member...
See HERE for Mod List!
tbrou6229 is offline
post #26 of 26 (permalink) Old 01-04-2017, 08:53 AM
I've found parking my ride in a garage each night eliminates the issues above entirely.
mowcowbell is offline
How do I safely remove the badges? Donkeydonkdonk 2014+ Jeep Cherokee General Discussion 13 08-07-2015 10:42 AM
Remove Front Fascia thebigler Jeepcherokeeclub.com How-To's 0 06-23-2015 03:01 PM
How to remove floor of trunk ? XtremeModder Interior 3 05-24-2015 12:01 PM
Any body knows how to remove this? Bonin Exterior 2 04-24-2015 02:22 PM
Wheeling in the Pine Barrens of NJ RexKL14 Owners' Garage 13 07-21-2014 02:52 PM
