Cherokee Fog Light LED Bulbs! Several Bulb Options! New XML2 Added! Plug and Play!! - Page 2 - 2014+ Jeep Cherokee Forums
 6Likes
post #11 of 75 (permalink) Old 02-26-2015, 12:26 PM
eak
eak's Avatar
No replacements for Cherokee Halogen headlights
Originally Posted by Diode Dynamics View Post
Here's a link to the direct listing: http://www.diodedynamics.com/store/l.../cherokee.html
Thanks!
Nick C.
You have everything but replacements for the Halogen headlights.
Lake Orion, MI
Granite Crystal Metallic Date ordered: 03/Jan/2014 Delivered: 4/Mar/2014
Granite Crystal Metallic TH KL •|||||||•| 3.2L V6 24V VVT | 27E | 9-Spd 948TE 4WD
TOW |Comfort Convenience | Brown Leather | Technology| Uconnect 8.4AN
Cold Weather | Black Hood Decal | 9 Amplified Speakers w/Subwoofer | CD
eak is offline
post #12 of 75 (permalink) Old 02-26-2015, 04:42 PM Thread Starter
JeepCherokeeClub.com Vendor
Diode Dynamics's Avatar
Originally Posted by eak View Post
Do you have any pictures of these actually installed on a 2014 Cherokee Trailhawk?
Thanks!
Eric
Eric,
That picture was posted to demonstrate the color temperature differences between 4300K / 5000K / 6000K
Here's an example on the Trailhawk we tested:
Feel free to give us a call if you would like more information: (314) 205-3033
Thanks!
Nick C.
Diode Dynamics is offline
post #13 of 75 (permalink) Old 03-09-2015, 08:31 PM
I noticed you have some lights mounted on the bumper in your picture of the Cherokee. What type of mounting did you use?
srkline likes this.
xrubicon is offline
post #14 of 75 (permalink) Old 03-10-2015, 01:23 PM Thread Starter
Those were installed by the owner prior to our testing. He screwed them directly into the bumper
Nick C.
post #15 of 75 (permalink) Old 03-18-2015, 02:46 PM Thread Starter
We are now offering yellow halogen fog lights from Putco!
Nick C.
post #16 of 75 (permalink) Old 04-08-2015, 03:49 PM
My 2015 Jeep has ALL Leds, except headlamps...... and sunvisors.
DudLee Brennfoerder
Jeep Cherokee Latitude
4444 miles in the first 30 days
Add: Chrome trim around all lighting, AMSOIL engine oil, Mopar splash guards, led lighting (interior and all exterior), may add receiver hitch and light kit.
partsmore is offline
post #17 of 75 (permalink) Old 04-08-2015, 06:08 PM Thread Starter
Awesome!
Let us know if you ever decide to upgrade those locations
Nick C.
post #18 of 75 (permalink) Old 05-10-2015, 01:07 PM
Fog Light LED Bulbs
We carry LED bulbs for replacement of your Cherokee's fog lights, in all major sizes. They are available in SMD, HP, XP, and XML styles. This will make your fog lights a nice bright white that closely matches factory HIDs! Just simple plug and play, replace the bulb and you are good to go!
We carry the brightest, highest-quality bulbs at the lowest prices. Your order will ship same day, and we're here if you need us for support and service. And we do not jack up the prices to astronomical levels- We're breaking that market trend, and offering you great, low prices, every day. These LED bulbs are designed by us here in St. Louis, and every bulb carries with it a three-year limited warranty.
Diode Dynamics offers several brightness options so you can choose what fits you best. These options are listed by the design and the lumen output of each bulb, compared to the factory bulb.
SMD18: 91 lumens. Lower brightness than factory, but still provides the crisp white, modern color of LEDs.
HP8: 270 lumens. Slightly lower brightness than factory.
XP80: 510 lumens. Similar brightness to factory.
XML2: 1410 lumens. Much brighter than factory. These are bright!
Please note that most LED fog lights are intended for cosmetic purposes only, and will not project light in the same way that the factory bulbs do. Your car will look great at night, but if you are looking for higher output, we strongly recommend using an HID conversion.
Bulb Design
SMD18: Eighteen three-chip 5050-size Epistar SMDs arranged in 360 degrees. Five radial panels of three chips, and a forward-facing three-chip panel. Main body material is PCB.
HP8: Four side-firing 1.5W-rated Osram LED chips, and one 1.5W-rated chip on top. The bulb is housed in a machined aluminum casing, which provides superior heat diffusion for long life.
XP80: Each of the four sides of this bulb contains three 5W-rated chips, and the top is fitted with four more, under a projector lens. This is the brightest self-contained automotive LED bulb on the market, and is housed in an aluminum casing with a textured finish for maximum heatsinking properties.
XML2: NEW! Two opposing genuine CREE XM-L2 chips, driven at high power by self-contained regulator unit, in an attractive cast-aluminum housing. Fully waterproof, non-polar, modular design.
These bulbs are made up of a quality plastic connector to slide right into the plug, as well as high durability terminals. A load resistor is embedded to prevent blowing the LEDs from voltage surge, and a diode is implanted to protect the LEDs from reverse polarity. The LED is wired for 12V operation, the kind found on all modern vehicles.
Included in your order is TWO BULBS (to fit your vehicle).
All of our products come with a 30-day satisfaction guarantee and a 3-year limited warranty.
Click below for more info or to order:
2014 Cherokee (Non-Trailhawk)
If you have any questions, please don't hesitate to post, PM, email contact@diodedynamics.com or call: (314) 205-3033
*PM us for the free-shipping code* (U.S. forum members only)
Thanks for looking!
Nick C.
Hi if I wanna buy your LED fog lights, can I replace it by myself? Could you pleace introudce how to replace the LED lights?
Getsoy is offline
post #19 of 75 (permalink) Old 05-11-2015, 01:03 PM Thread Starter
@Getsoy please give us a call for more information: (314) 205-3033
Installation is very simple for LED bulbs. You'll simply remove the factory halogen bulb, and install an LED bulb in it's place
Nick C.
post #20 of 75 (permalink) Old 06-24-2015, 06:26 PM Thread Starter
(314) 205-3033
Nick C.
Headlight/Fog Light LED Upgrade??? djack Electronics, Audio, and Lighting 22 05-12-2016 04:28 PM
>> XenonDepot 30W CREE LED Fog Light / DRL Bulbs - SAVE BIG! << XenonDepot XenonDepot 8 09-04-2014 06:20 PM
H8/H11/H16 Philips X-treme Ultinon LED Bulbs Vs Halogen Fog Light Bulbs XenonDepot Electronics, Audio, and Lighting 0 08-21-2014 06:36 PM
>> Introducing new Philips HID Bulbs, Putco LED Fog Lights, and Denso Ballasts << XenonDepot XenonDepot 3 07-21-2014 06:12 PM
Installed LED fog light on Letitude realcaptain Exterior 4 03-02-2014 11:06 AM
