MOPAR vs. K&N Oil Filter Comparison - Page 2 - 2014+ Jeep Cherokee Forums
 20Likes
post #11 of 30 (permalink) Old 03-08-2015, 01:02 AM Thread Starter
fusseli's Avatar
That must be where the factories are that make the cartridge filters...
fusseli is offline
post #12 of 30 (permalink) Old 03-09-2015, 12:16 AM
Jaro360's Avatar
Cool! I'll be switching over to K&N for the oil filter at my next oil change! Interesting on their pleat count more pleats usually means more flow, but you can't compare surface area and flow rates unless you compare the properties of the filter media itself. Makes me curious about if the flow rate could actually change the efficiencies of our motor given it already has a variable displacement oil pump.
I have their engine air filter and now I can only hope they release a re-usable in cabin air filter for the cherokee's.
Yep I bet cartridge filters require special plastic injection molding etc. since there is no old style metal can to support the media. Like you said must be where their factories are with those capabilities.
__________________
Trailhawk
Bright White
Hood Decal
3.2 V6
Trailer Tow Pkg
Comfort/Convenience Group
Jaro360 is offline
post #13 of 30 (permalink) Old 03-28-2015, 04:34 PM Thread Starter
fusseli's Avatar
Thumbs up Mopar-K&N-Fram comparison
We can scratch that theory
I picked up a Fram CH11665 for the 3.2L Jeep at Walmart today for about $6. It has pleat count of 60 (same as MOPAR) and is of a third/different type of construction. The Fram is glued/molded at the ends like the K&N (48 pleat), and says made in USA unlike the other two. The filter media is similar in appearance but possibly different than MOPAR, notice the folds in the pleats look slightly thicker. The seam where the ends of the media meet have a wide gap on the Fram.
ID:	54697   Click image for larger version
ID:	54705   Click image for larger version
Mudman1, Duke2015 and Snowhawk2015 like this.
fusseli is offline
post #14 of 30 (permalink) Old 03-28-2015, 04:39 PM Thread Starter
fusseli's Avatar
There was discussion on BITOG that the Fram was "the same" as the Chrysler, and a Fram rep saying it was, that is not the case but they are very similar.
fusseli is offline
post #15 of 30 (permalink) Old 11-25-2015, 09:00 AM
Just to update anyone still looking for the K&N PS-7026 Oil Filter... it's available for $8.66/each at Amazon.
fusseli and Duke2015 like this.
mowcowbell is offline
post #16 of 30 (permalink) Old 09-20-2016, 10:10 PM Thread Starter
fusseli's Avatar
Interesting note, there is a new part out for the oil filter, revised 68191349AA is now 68191349AB. I will pick up a few for comparison.
fusseli is offline
post #17 of 30 (permalink) Old 09-25-2016, 04:41 PM Thread Starter
fusseli's Avatar
I'm counting 62 pleats on the new 68191349AB (Package still says Mopar M0-349), this is up from 60 I counted on the original AA. Otherwise construction is visibly the same at the older Mopar (but different than Fram and the K&N).
ID:	137313   Click image for larger version
ID:	137321   Click image for larger version
fusseli is offline
post #18 of 30 (permalink) Old 11-29-2016, 01:47 AM Thread Starter
fusseli's Avatar
It could be a coincidence, but now that I am running the AB version I don't notice rattle at startup as often as with the older AA filter. I'm not sure how the cartridge could have an impact on that though.
007 likes this.
fusseli is offline
post #19 of 30 (permalink) Old 11-29-2016, 06:11 AM
007
007's Avatar
Hmmm... I'm intrigued. I just ordered a couple of the ABs, because I hate that startup rattle. I'll let you know if it makes a difference with my engine. I'm using a K&N right now.
The BEAST
2014 Cherokee Latitude
Build date: 07/09/2014
In Service Date: 09/02/2014
My purchase date: 7/29/2016
Altitude Pkg
FWD
Uconnect 8.4A
3.2L V6
007 is offline
post #20 of 30 (permalink) Old 11-29-2016, 07:29 AM
Also check e-bay for price. Picked up 3 Mopar filters the AB type for just under $5 inc shipping from a Jeep dealer on the East Coast.
These boxes also state, only for 2014 and later engines. Avoids the confusion of using an identical 2013 filter. That will produce lower oil pressure from what I understand.
The pricing for these filters are all over the board.
I just give the filter to the lube shop when I get my change. Avoids the $15 upcharge for the Mopar filter.
fusseli and 007 like this.
Oil in air filter Len1304 Engine and Technical Discussion 10 09-16-2016 05:57 PM
3.2L Oil Filter NHPatriot Engine and Technical Discussion 70 11-25-2015 08:56 AM
Oil Filter question indytrucker 2014+ Jeep Cherokee General Discussion 2 12-13-2014 03:13 AM
3.2 V6 oil filter ZNY67 Engine and Technical Discussion 12 02-24-2014 02:10 PM
Mopar catalog lists diesel engine oil filter... Superjoe Engine and Technical Discussion 7 11-05-2013 05:29 PM
