Differential Fluids? - Page 3 - 2014+ Jeep Cherokee Forums
 15Likes
post #21 of 31 (permalink) Old 10-16-2015, 11:25 PM Thread Starter
Mudman1's Avatar
Originally Posted by jamie1 View Post
I haven't forgotten about you mudman1. We just haven't had any Cherokees come in for service.
Thanks. Tomorrow, assuming the world does not crash and burn, I am going to put the Jeep up on ramps and see if I can't knock out the fluid changes. I will document and post accordingly.
fusseli and ptrudel like this.
Mudman1 is offline
post #22 of 31 (permalink) Old 10-18-2015, 10:54 PM Thread Starter
Mudman1's Avatar
Good evening all. Did my third oil change today and threw in a new Mopar filter. I used AMSOIL Signature 5W-20. Then I looked high and low for the PTU drain / fill. I did not want to drop skid plates as I had lots of other projects to tackle. I could not find it so I said screw it. I bought the lifetime warranty, it is on Mopar if they decided service of components is not important.
For the rear diff, I did pull the plugs. It is odd because with the right and left plugs out, oil will run out of the left but not the right. My Mityvac tube will not go down into the right hole, but it did in the left. I was able to suck out a couple of ounces and that is all. So I burned through one of the two quarts I bought by flushing. So once I sucked out what I could from the left hole, I used my hand pump to just flood both holes. Then I let it drip so it was not overfull. The oil did not look too bad and the metal shavings were reasonable. I have 14,400 miles on the clock.
FYI, I am not sure if it was the factory's fault or the dealer's when they did my drive shaft replacement in the spring, but both holes were a little low. Not scary low, but not level with the bottom.
ID:	90282   Click image for larger version
ID:	90290   Click image for larger version
ID:	90298   Click image for larger version
ID:	90306   Click image for larger version
Mudman1 is offline
post #23 of 31 (permalink) Old 10-19-2015, 12:39 AM
fusseli's Avatar
Thanks for sharing! Any pics of the dirty diff oil? What did you refill with? And this was with significant 4x4ing with only 15k? Just curious
Mudman1 likes this.
fusseli is offline
post #24 of 31 (permalink) Old 10-20-2015, 12:36 PM Thread Starter
Mudman1's Avatar
Did you look at my pictures? The second from the last picture shows the oil I extracted from the rear diff.
Mudman1 is offline
post #25 of 31 (permalink) Old 10-21-2015, 04:22 PM
JKL
Don't get me wrong, I agree with you. I hate these "sealed for life" units. Who's life??
The life of the sealed unit of course!
Mudman1 likes this.
JKL is offline
post #26 of 31 (permalink) Old 10-22-2016, 11:21 AM
Hey guys... this threads a little dated. I've had a few jeeps and done the DIF /Trans myself in the past.
I have a new 2014 Jeep Cherokee but don't do any off road and minimal towing. I'm not sure I'm buying this good for LIFE crap either - how often would you recommend PTU/Diff change?
ice651 is offline
post #27 of 31 (permalink) Old 02-13-2017, 05:40 PM
Seriously considering running royal purple 75-90 in transfer and rear. Any opinions on that? Very close viscosity and a superior product. Thoughts?
Thedurden01 is offline
post #28 of 31 (permalink) Old 03-09-2017, 11:46 AM
29PalmsMark's Avatar
The skid plate has to come off, correct? My unit has a slow leak and I would rather not have it grenade before the dealer can schedule another appointment to replace the PTU.
Yep, it was leaking from the day I drove it off the lot :-(
29PalmsMark is offline
post #29 of 31 (permalink) Old 03-09-2017, 03:49 PM
Did you need any help getting an appointment set? Please let us know, we're happy to help!
Kori
Jeep Social Care Specialist
Mark_ likes this.
JeepCares is online now
post #30 of 31 (permalink) Old 03-09-2017, 07:22 PM Thread Starter
Mudman1's Avatar
To treat the front, yes they would have to. Not for the rear, there is not one there.
Mudman1 is offline
Jeep : Cherokee Trailhawk Trailhawk SUV 3.2L 4X4 Locking/Limited Slip Differential Po Jeep Cherokee Parts Jeep Cherokee eBay Classifieds 0 07-19-2015 08:40 PM
Jeep : Cherokee Trailhawk Trailhawk SUV 3.2L 4X4 Locking/Limited Slip Differential Po Jeep Cherokee Parts Jeep Cherokee eBay Classifieds 0 07-12-2015 06:30 PM
How a Differential Works Array Engine and Technical Discussion 14 02-03-2015 10:43 PM
Audible tone from sensor differential whm 2014+ Jeep Cherokee General Discussion 7 08-07-2014 05:04 PM
Fluids, Lubricants and Genuine Parts - Reference Post Cherokee Steve Engine and Technical Discussion 1 02-09-2014 07:19 PM
