Differential Fluids? - 2014+ Jeep Cherokee Forums
 15Likes
post #1 of 32 (permalink) Old 09-01-2015, 11:23 AM Thread Starter
Mudman1's Avatar
Good Morning Gents,
Has anyone found out what fluids we need to put in our differentials and transfer case / PTU? AMSOIL has no fluids recommended. Chilton online manuals has no 2015 available, but a 2014 is. I do not know if they changed anything? I do not want to pay $30 and be wrong.
I ask because I have done a lot of towing and I know it would be good to change out the fluids. But paying dealer prices is not on my to-do list. Any suggestions? I might swing by my dealer today and see if they can tell me what they use and what it costs. If I do, I will post.
Mudman1 is offline
post #2 of 32 (permalink) Old 09-01-2015, 12:07 PM
ptrudel's Avatar
I don't know, but I'm following this thread for the right answer.
ptrudel is offline
post #3 of 32 (permalink) Old 09-01-2015, 02:20 PM
jamie1's Avatar
PTU takes 75W-90 gear oil. The rear diff takes 70W-80 meeting MS 2395 and hydraulic fluid meeting MS-2155
jamie1 is offline
post #4 of 32 (permalink) Old 09-01-2015, 03:54 PM Thread Starter
Mudman1's Avatar
PTU: 68210057AA for $16.50 each
Rear Diff: 68227765AA for $15.00 each
Okay, I did this part. Now I need someone to go get the torque specs for the drain plugs. I did not have time to wait for the guy to go get the numbers from service as I had to leave. I am a busy guy . IIRC the rear diff takes 1.6 or so quarts and the front takes just shy of one. I always end up spilling some so I got a second, just in case.
These are for MY VIN. There are two different rear diff fluids, one for the Trailhawk and one for the ADII, from what the guy was telling me.
ID:	81377   Click image for larger version
ID:	81385   Click image for larger version
ID:	81393   Click image for larger version
ID:	81401   Click image for larger version
Mudman1 is offline
post #5 of 32 (permalink) Old 09-01-2015, 03:58 PM
Amon's Avatar
Send a message via Skype™ to Amon
How often you usually change?
Enviado desde mi iPhone utilizando Tapatalk
Amon
Amon is offline
post #6 of 32 (permalink) Old 09-02-2015, 10:54 AM Thread Starter
Mudman1's Avatar
I have never changed them, but I will in the next month or two. I have done a lot of 4LO and towing time, so after my 2,900 trip coming up I am going to put fresh fluids in and see what stuff looks like.
No one else able to get the torque specs?
Mudman1 is offline
post #7 of 32 (permalink) Old 09-02-2015, 11:57 PM Thread Starter
Mudman1's Avatar
Rear Differential Fill Plug: 26 Ft. Lbs.
PTU Fill Plug: 30 Ft. Lbs.
PTU Heat Shield: 10 Ft. Lbs.
My dealer provided these to me today when I picked up my new Mopar wiper blades.
fusseli likes this.
Mudman1 is offline
post #8 of 32 (permalink) Old 10-04-2015, 07:12 PM Thread Starter
Mudman1's Avatar
Guys, I need to rely on our network here. Does someone either work at a dealer or have a better relationship than I do with one? I need the instructions for draining the rear diff and the PTU. I looked around yesterday under the Jeep. It looks like for the rear diff there are two fill plugs, one on each side. But I cannot find any drain plug. For the PTU, it is covered by the skid plates and could not find anything. I am pretty sure I did find the drain plug for the transmission, but not the fill plug.
Can someone help us out and pull the directions for fluid changes in the transmission, PTU and rear diff? Thanks!!
Mudman1 is offline
post #9 of 32 (permalink) Old 10-04-2015, 10:00 PM
jamie1's Avatar
Just looked on Techconnect. There is no reference to drain plugs on either unit. They also only state one fill plug for the diff. I personally have never looked for a drain plug, so I really couldn't say if there is one or not. Chrysler also has no specified service interval for them. If I notice one in the air in the shop tomorrow, I will take a look and let you know.
fusseli, homac and Mudman1 like this.
jamie1 is offline
post #10 of 32 (permalink) Old 10-04-2015, 10:26 PM Thread Starter
Mudman1's Avatar
Thanks brother! That is odd. I could see if I had no knowledge of this stuff, but having owned over a dozen trucks with specific fluid change intervals for severe service and heavy towing, it is surprising that the Jeep does not have such a thing. And having no instruction is odd. I know Ram did for my 2500, meaning front and rear diffs, transfer case and so on. So they are supposed to be sealed and good for life? No matter how good the parts are, there will be wear and shavings. One might think they should be flushed out? What if the vehicle is submersed in water?
Mudman1 is offline
Jeep : Cherokee Trailhawk Trailhawk SUV 3.2L 4X4 Locking/Limited Slip Differential Po Jeep Cherokee Parts Jeep Cherokee eBay Classifieds 0 07-19-2015 08:40 PM
Jeep : Cherokee Trailhawk Trailhawk SUV 3.2L 4X4 Locking/Limited Slip Differential Po Jeep Cherokee Parts Jeep Cherokee eBay Classifieds 0 07-12-2015 06:30 PM
How a Differential Works Array Engine and Technical Discussion 14 02-03-2015 10:43 PM
Audible tone from sensor differential whm 2014+ Jeep Cherokee General Discussion 7 08-07-2014 05:04 PM
Fluids, Lubricants and Genuine Parts - Reference Post Cherokee Steve Engine and Technical Discussion 1 02-09-2014 07:19 PM
