ESS Not Ready, Battery Charging - Page 3 - 2014+ Jeep Cherokee Forums
 13Likes
post #21 of 49 (permalink) Old 10-22-2015, 11:08 PM
COJeep303's Avatar
Agreed, that's not what they always tell us "operating as designed", unless the battery is indeed dead (which sounds unlikely based on your post). My ESS has always worked since I got it. I have a never-changing light about 1 minute from leaving the garage on my way to work, and it'll usually do it's thing (unless it's bitterly cold or I have climate on full blast).
The voltage sensor is a good hypothesis. I'm sure it's easy enough to try to fix but I'm with @Gersh. Take it in and see what's up.
2015 Trailhawk | V6 | Cold Weather | Towing | 8.4A w/ Nav | Brilliant Black | Black Interior | Built: 10/2014
2003 Acura 3.2 TL Type-S | V6 | Nav | 5 speed auto | Pearl White | Brown Leather
COJeep303 is offline
post #22 of 49 (permalink) Old 10-23-2015, 12:23 AM
All the other items that can stop ESS working are not really relevant to the OP as the system tells you why it wont engage and his is telling him its the battery!
I start mine at work after it sitting for 8 hours and drive 500m to the next intersection (with aircon off amd in warmish weather) and ESS kicks in straight away.
post #23 of 49 (permalink) Old 10-23-2015, 07:13 AM Thread Starter
HazzardSky's Avatar
Well, it looks like it did have to do with the battery. On the trip home last night I happened to flip the display over to the ESS status, and it said Ready!. On my commute this morning it did kick in at the right times (took about 2 miles of driving after starting for it to be ready again), and worked well. Based on the discussion so far, i'd say it was likely due to how long the jeep sat on the lot without being driven that caused the big delay. Battery voltage now stays around 14-14.2, and heck, even my gas milage went up significantly this morning (i'm guessing since the alternator isn't trying to condition the battery the whole time.)
Either way, problem solved for now. I'll keep an eye on it if it stops working for any reason, but I'm not going to make a trip to the dealer at this point as long as it keeps working.
Thanks again for the input.
Cheers
UN4GTBL, Array, COJeep303 and 3 others like this.
2015 Trailhawk
Baltimore, MD
HazzardSky is offline
post #24 of 49 (permalink) Old 10-23-2015, 07:33 AM
Sounds like you might be right. Just hope the battery has some longevity if it has taken this long to bring it up to spec again.
post #25 of 49 (permalink) Old 10-23-2015, 10:54 AM
ptram's Avatar
I usually turn my ESS off but normally after it shuts down the first time as I forget. I hadn't driven my TH for a week or so and I had to drive it about 50 miles or more before the ESS started to work again. I intentionally did that to see how long it would take to get the battery charged up enough for the ESS to operate.
ptram is offline
post #26 of 49 (permalink) Old 10-23-2015, 09:40 PM
I have the same issue on my 15 Aussie model. Taken it back to the dealer twice and each time they replaced the battery sensor which they say is a common fault. However I still get the battery charging status until I drive for at least 30 minutes. I find if I drive the car every day this trip time is shorted before ess activates. If I leave the car for more than a day It will only ever engage after a long drive. So annoying it's not as seamless but will bring it up again at next service.
Sent from my SM-G925I using Tapatalk
crazyfreerider is offline
post #27 of 49 (permalink) Old 02-20-2017, 08:50 AM
I can probably shed some light on a few of those points :
- When it's hot outside, there are a few parameters that can and will disable ESS;
Cabin temperature is monitored closely. This would be the most frequent cause of short or no engine stopping in hot climates.
Extreme outside temperature (we've guessed around 94F to be the trip point) will disengage ESS.
Battery status of course, if the HVAC fan is blowing full blast for example.
- If you ever get low enough on fuel to get the Low fuel light, ESS will be disengaged. We've discussed this as being weird, especially since ESS is supposed to be a fuel saver, but what can you do... haha.
Have a 2015 Jeep Trailhawk, this problem with battery charging on start and stop is a issue back to the dealer 3 times, they have not clue. Next step to call Jeep hotline. Any one with this issue have it corrected?
Brian 1944 is offline
post #28 of 49 (permalink) Old 02-21-2017, 05:58 PM
Hi Brian--are you in the US? Did you call our Customer Care department and get a case number?
Kori
Jeep Social Care Specialist
JeepCares is online now
post #29 of 49 (permalink) Old 02-23-2017, 03:30 PM
You may have an issue. ESS does not take much charging to be operational. I've rarely had mine NOT be available. It wouldn't hard to have it checked out at the dealer.
post #30 of 49 (permalink) Old 02-24-2017, 07:47 AM
BurtonRW's Avatar
When I had this problem, it turned out to be a defective battery, but the dealer couldn't (or wouldn't) diagnose it until I had FCA open a star case.
The AGM batteries work a little differently than traditional wet cell types. It's not enough that the voltage checks out.
-Rob
BurtonRW is offline
Anyone knows how to disable the ESS Taegee2 2014+ Jeep Cherokee General Discussion 205 05-21-2017 03:08 PM
Battery is always charging now? XtremeModder Engine and Technical Discussion 3 02-28-2015 11:07 AM
Ess Rubyredfox 2014+ Jeep Cherokee General Discussion 5 12-03-2014 07:35 PM
An ESS Tip or Two Dodgeboy 2014+ Jeep Cherokee General Discussion 4 11-23-2014 09:49 PM
Issue with the ESS on '15 TH jdlewh Engine and Technical Discussion 4 11-17-2014 08:53 PM
