ESS Not Ready, Battery Charging - Page 5 - 2014+ Jeep Cherokee Forums
 11Likes
post #41 of 45 (permalink) Old 03-16-2017, 06:29 PM
Ok I missed that... oopsy.
So we still don't know which of those flashes did something. In one thread a member posted pdfs for 5 of those 6 flashes and only one seems like a possible fit, and it's this one :
http://www.wk2jeeps.com/Misc/Cheroke...08_024_16b.pdf
(unprovoked power to the instrument cluster).
Refernce : Just got 7 software flashes today -- what do they address?
There was BCM or PCM flash in the group and the comment on the ESS service items was that one of them fixed it. I don't think I have the paperwork to verify which one though.
Rojhan is offline
post #42 of 45 (permalink) Old 03-17-2017, 09:22 AM
Thanks.
I've looked at the descriptions for both of those, and nothing even hints at whatever could be causing this problem. One of those mystery fixes I guess...
Well let's keep this *ticket* open and hope for a concrete answer (from FCA) at some point. Could help a bunch of KL owners.
post #43 of 45 (permalink) Old 03-17-2017, 11:09 AM
HawkeyeKL's Avatar
didn't work this morning. 46*F. working fine now 65*F. I think my battery is ready to go bad. Temp is definitely affecting it. fortunately we will not see any temps below 60*F for the next 10 months at least... we'll see.
HawkeyeKL is offline
post #44 of 45 (permalink) Old 03-17-2017, 11:57 AM
Hmmm. Somehow I don't think it's temperature here. Like I said before, batteries do well above freezing, so 40s and 60s are quite similar.
I think *morning* might be more of an indication, as in after many hours of inactivity. I'm thinking you may have a parasitic draw in there somewhere, causing the battery to be slightly drained overnight. Once you have driven for a while, if my theory holds any water, the battery would then regain full charge status and ESS good to go.
Or your battery is defective and slowly dying. It's possible.
post #45 of 45 (permalink) Old 03-17-2017, 06:20 PM
One of the inhibitors for ESS is climate-controls active.
One of the other inhibitors in if the engine is turned off. (I posted a pic somwhere of the EVIC message to the effect of "ESS disabled. Engine is off." )
Rojhan is offline
Anyone knows how to disable the ESS Taegee2 2014+ Jeep Cherokee General Discussion 179 03-02-2017 11:00 PM
Battery is always charging now? XtremeModder Engine and Technical Discussion 3 02-28-2015 11:07 AM
Ess Rubyredfox 2014+ Jeep Cherokee General Discussion 5 12-03-2014 07:35 PM
An ESS Tip or Two Dodgeboy 2014+ Jeep Cherokee General Discussion 4 11-23-2014 09:49 PM
Issue with the ESS on '15 TH jdlewh Engine and Technical Discussion 4 11-17-2014 08:53 PM
