2.4L Thermostat Failing - Page 2 - 2014+ Jeep Cherokee Forums
 10Likes
post #11 of 42 (permalink) Old 01-17-2016, 03:46 PM
SoCalCherokee's Avatar
Originally Posted by cobber15 View Post
This is what happens when things break fail early. **** Jeep. If I get a buy back, I'll buy something other than Jeep. I liked my Jeep when I got it. I blacked it all out. Now that it keeps having issues, I want something different that is NOT a 4 banger. Lol.
I don't get the pic? Why is it significant?
What kind of "problems" have you had??
GO RED WINGS!!!
SoCalCherokee is offline
post #12 of 42 (permalink) Old 01-17-2016, 04:12 PM
I was saying that I've liked the jeep. I took the time to black it out. Windows, grills, emblems, rims. To think if I have a buy back or something I'd lose all of that. Oh well I guess.
Problems? Entire new rear end to start at 14k miles. New thermostat. Coolant leak. Burning oil. Transmission likes to hesitate at low speeds at random times.
cobber15 is offline
post #13 of 42 (permalink) Old 01-17-2016, 06:24 PM
What happened to the rear end?? Just went out on you?
GO RED WINGS!!!
post #14 of 42 (permalink) Old 01-17-2016, 06:40 PM
I was looking around underneath and noticed gear oil all around the axle housing. I took her in for service, and they said they had to replace the entire rear axle assembly. I never took it off road.
cobber15 is offline
post #15 of 42 (permalink) Old 01-17-2016, 09:50 PM Thread Starter
I own a 16' but work for enterprise car rental at one of our service centers and so we have mechanics that work on our vehicles and I believe everything that has failed is 14-16'. They said Lat week that thermostats were on national back order and then they weren't but it sounds like they are again.
Nielcoop is offline
post #16 of 42 (permalink) Old 01-18-2016, 11:25 AM
Lol, is there anything but 14-16?
Interested in what typical failure you see. Care to elaborate more on what are the common issues?
flaco is offline
post #17 of 42 (permalink) Old 01-18-2016, 01:49 PM Thread Starter
It could just be affecting the 14's or 15's only. That's why I stated its 14-16'.
Most commonly the vehicle will heat up but will only blow cold air. That's all I know of right now. Haven't been in the office for the last few days.
Nielcoop is offline
post #18 of 42 (permalink) Old 01-19-2016, 03:30 PM
Desoto's Avatar
Stats are available now.
flaco likes this.
Desoto is offline
post #19 of 42 (permalink) Old 01-20-2016, 01:35 PM
osirisdean's Avatar
apologies for the thread jack, but i think i have this problem. heater seems to work fine, but after a while (anything longer than a 20-30 minute drive), it'll start blowing cool air, seemingly regardless of what temperature was set. i understand it's supposed to maintain whatever temperature is set and theoretically that means blowing cold air to regulate ambient temp; but it shouldn't be blowing cold air if i have the cabin temp set to 75degrees and both my wife and i agree that the car was not that warm.
is there a recall or TSB addressing this at all? (i've seen the issue mentioned a couple times in other threads, but couldn't glean much info from them.)
build date: november, 2014
osirisdean is offline
post #20 of 42 (permalink) Old 01-20-2016, 08:19 PM
Desoto's Avatar
You might set the Evic to Coolant temp and take note of it when it is blowing hot, and compare that number to when it is cold. If it's the same, there is a problem in the Climate Control.
osirisdean likes this.
Desoto is offline
Thermostat/Coolant Temp. Steveinmedford Owners' Garage 14 06-01-2015 11:16 PM
Engine failing to start Len1304 Engine and Technical Discussion 14 10-27-2014 04:10 PM
HID kit installed with failing results Dundas Electronics, Audio, and Lighting 14 02-28-2014 11:16 PM
