Solid Red Battery Light When Key in Run Position - 2014+ Jeep Cherokee Forums
post #1 of 8 (permalink) Old 01-10-2017, 07:32 PM Thread Starter
2016 Jeep Cherokee -
When I turn the key to the run position i get the solid red battery light come on after a few seconds. It stays on until I start the engine, and then it goes away.
Is this normal? Or is it a sign that something is wrong?
DanWA is offline
post #2 of 8 (permalink) Old 01-10-2017, 08:12 PM
its normal. indicates that the battery is not charging. Since the vehicle is not running it cant charge. Its all good
GOERES is offline
post #3 of 8 (permalink) Old 01-10-2017, 08:25 PM Thread Starter
Thanks! There is a lot of info on the dash that I am not used to so it's hard to know what is normal... like battery voltage, when it set to run it goes below 10 and then when the engine is started it stays around 14 or a little bit over.
Is that also normal range?
DanWA is offline
post #4 of 8 (permalink) Old 01-10-2017, 08:32 PM
Normandy's Avatar
mine sits at 14.2 most of the time.. though sometimes it dips for 13.8 on a hot day, I suspect its the air con and fans running... like most things... all is good unless a light comes on and stays on or a chime indicates...
Victorian Highlands Australia
Normandy is offline
post #5 of 8 (permalink) Old 01-10-2017, 08:44 PM Thread Starter
Well like I said in the original post, when i turn the key to run it chimes with the battery light, then when the engine is started it goes away...
DanWA is offline
post #6 of 8 (permalink) Old 01-10-2017, 10:53 PM Thread Starter
Is it normal that there is a chime accompanying the light when it comes on?
DanWA is offline
post #7 of 8 (permalink) Old 01-11-2017, 03:40 PM
yes this is normal. Its all good
GOERES is offline
post #8 of 8 (permalink) Old 01-17-2017, 01:05 AM
I honestly wouldn't be too worried about the battery light unless it says on after the car starts running. It figures that all these small things don't get noticed until after we've brought the car home and started using it though, hey? It would make our lives a lot easier if we were allowed to spend more time with the vehicles when we're test driving them especially when we're new to the car.
webbrowan is offline
may be replacing one key fob battery rumrunner Electronics, Audio, and Lighting 19 01-15-2017 12:03 AM
Battery light reginaalear 2014+ Jeep Cherokee General Discussion 2 07-09-2016 01:08 AM
Check engine light now on after battery replace audiobob Engine and Technical Discussion 3 03-22-2016 12:29 AM
Low voltage battery light on TH2014 Electronics, Audio, and Lighting 9 11-26-2015 11:01 AM
Throttle position sensor: Check engine light WyoKid Engine and Technical Discussion 12 09-11-2014 10:48 PM
