Battery voltage on EVIC at rest vs whilst Driving - Page 2 - 2014+ Jeep Cherokee Forums
post #11 of 55 (permalink) Old 01-11-2017, 06:29 PM
Originally Posted by DanWA View Post
Are those numbers testing the battery directly using a tool? Or just going off the Battery Voltage EVIC #. My concern was 12v was too low with engine off, but I am going off of the EVIC # alone
I have an external device provide telemetry, independent of the vehicle electronics. Keep in mind that with the ignition "on" (engine not running) there is a pretty significant load with the electronics on.
Rojhan is online now
post #12 of 55 (permalink) Old 01-11-2017, 06:38 PM Thread Starter
Ah okay then. Car is new (100 miles) so i guess 12v with key on is normal then.
DanWA is offline
post #13 of 55 (permalink) Old 01-11-2017, 07:10 PM
Wouldn't go as far as to say normal. Mine reads 12.4V with ignition on and engine not running. However, since your Cherokee is new, it may have been sitting on a lot somewhere and the battery may need additional charging which will be provided as you drive it more; this being longer drives rather than grocery store runs.
Array is online now
post #14 of 55 (permalink) Old 01-11-2017, 07:21 PM Thread Starter
I took a 30 min drive today. Shouldn't that have done the trick?
DanWA is offline
post #15 of 55 (permalink) Old 01-11-2017, 07:37 PM
I'd think so if you were at highway speeds rather than city. These batteries have 6 cells in series at 2.1V each meaning a standalone fully charged battery should come in at 12.6 volts. Put it in a car with the ignition on (a load) and a reading of 12.4 volts makes sense.
My recommendation is to drive it and if you are not experiencing any electrical glitches (electronics not working the way they should) and it still reads 12V after a month, then take it to the dealer for a battery check. It is conceivable there is a weak cell in the battery.
Array is online now
post #16 of 55 (permalink) Old 01-11-2017, 07:56 PM
Curious about a couple things...
1) @DanWA : do you have the normal EVIC or the premium display (DID) ? DID is on Limited, TH and Overland.
I'm asking because on the EVIC, the voltage scale is difficult to read (in my opinion), and you have to be well acquainted with it to read in-between the static numbers. I know I find mine difficult to interpret.
2) When you test with the ignition *ON*, do you have stuff like the heater blower going ? Rear defroster ? Radio ? Interior lights ? Just for fun, try again and turn everything (you can) off. I'm thinking 12 - 12.2V at rest is possible if you have some high draw stuff running...
Array likes this.
post #17 of 55 (permalink) Old 01-11-2017, 08:16 PM Thread Starter
Just the regular I think (Sport). It looks like it's sitting right in between 10 and 14.
When I set the key to run I have everything off. Well except for the screen with radio and stuff in the center which is always on.
DanWA is offline
post #18 of 55 (permalink) Old 01-11-2017, 08:23 PM
Just the regular I think (Sport). It looks like it's sitting right in between 10 and 12.
Yeah you have the EVIC, like mine.
When I take the Jeep out tomorrow I'll have a look. Getting more snow tonight so definitely going out tomorrow
post #19 of 55 (permalink) Old 01-11-2017, 08:43 PM Thread Starter
I'd appreciate that! I have the key in ON without starting the engine and I have all AC off. Snap a pic if you can
DanWA is offline
post #20 of 55 (permalink) Old 01-11-2017, 09:01 PM
One last question : do you mean *ON* as in *RUN* ? Or *ACC* ? I have the regular fob, not the keyless system.
I will take a pic
Annoying beeping whilst driving Jeep12345 2014+ Jeep Cherokee General Discussion 11 07-28-2016 08:40 PM
Battery voltage is low Nielcoop 2014+ Jeep Cherokee General Discussion 5 06-07-2016 04:44 PM
Low Battery Voltage & Car will not start gjdiste 2014+ Jeep Cherokee General Discussion 1 12-30-2015 05:35 PM
Low voltage battery light on TH2014 Electronics, Audio, and Lighting 9 11-26-2015 10:01 AM
Low Battery in EVIC muengineer Electronics, Audio, and Lighting 6 09-04-2014 06:20 PM
