Downstream P2098 P2096 - 2014+ Jeep Cherokee Forums
post #1 of 5 (permalink) Old 02-01-2017, 11:39 PM Thread Starter
Hello everyone,
I have a problem with my Jeep Cherokee (2014 Limited), the check engine light is run with my car and I have Downstream P2098 P2096, I go to the maintenance they connected the car by wi-tech software and turn off the check engine light but after three hours it comes back to turn on.
Please is there any idea for the reason?
adelkoki is offline
post #2 of 5 (permalink) Old 02-02-2017, 08:04 AM
Originally Posted by adelkoki View Post
Hello everyone,
Actually there is a problem that they negleted to fix. Many times a error light will clear itself, such as a gas cap left open. But when the problem is a real problem it will come back on.
Run an internet search on those error codes and you will even find some u-tube videos on the subjct.
Try this page:
https://www.autocodes.com/p2096_jeep.html
If you are still in the 3/36 window you should be covered unless its emissions related then its longer.
Good Luck in your resolution.
post #3 of 5 (permalink) Old 02-02-2017, 09:30 AM
Hello everyone,
Hi adelkoki,
It may be beneficial for you to reach back out to your Jeep dealership and have them re-diagnose your vehicle. If you need any assistance setting up an appointment, please let me know.
Kori
Jeep Social Care Specialist
JeepCares is online now
post #4 of 5 (permalink) Old 02-02-2017, 09:36 AM
SS_Syndicate's Avatar
P2098 and P2096 are both for after catalyst fuel trim too lean. One code is for bank 1 and one code is for bank 2. Running lean can cause issues long term so I would get a handle on the issue sooner than later as suggested.
Because it is both banks I doubt it is a bad sensor. Did this happen after you got some gas? If so, how many tanks of gas have you run since? It is possible you got some bad fuel. If you have run through several tanks the troubleshooting will need to get more in depth.
One thing is for sure... just resetting ht code is bad. Your car is telling you something... Don't ignore it.
SS_Syndicate is offline
post #5 of 5 (permalink) Old 03-13-2017, 04:25 AM Thread Starter
Thank you everyone,
My problem had been solved, the bad gas is the reason
adelkoki is offline
