Battery died and is acting up? - Page 5 - 2014+ Jeep Cherokee Forums
 22Likes
post #41 of 50 (permalink) Old 05-10-2017, 09:27 PM
Ok... (drum roll...)
The 27F should fit.
I stuck a piece of 2 x 4 flat under the 94R, so that raised it 1.5". The cables and terminals reach the posts. Barely... but they reach.
The Exide 94R (like our OEM 94R) is 7.5" high and the 27F (Northstar / X2 Power) is 8.75" high, so 1.25" difference. It'll fit height-wise, and there's plenty of room above to clear the hood.
Width : the OEM 94R is 6.875" while the 27F is 6.77". I checked the bottom retainer block and it grabs 3/16" on the 94R's lip, so the 0.1" doesn't matter as far as holding it down, no jerry-rigging necessary I'm sure (it would be super easy to do though).
The cables barely make it up to the posts when the 94R sits 1.5" higher, but they make it. We only have a 1.25" rise with the 27F so I don't see a problem. If it does create a problem for some who try, the cables are secured with plastic clips to the bottom of the battery tray, and I'm sure we can pull a bit more cable upwards if need be...
One last diffrerence : the 27F (Northstar) is 15 lbs heavier than the OEM 94R. The tray looks solid to me and I don't see a problem there either...
I'd say it's a go !
I'd really like to see a dual post option. So my winches and accessories don't have to share the same connection point. Things have gotten VERY crowded. Although the 27F looks like a fantastic alternative for the 94R since I think mine has a dead cell.
post #42 of 50 (permalink) Old 05-10-2017, 09:58 PM
Yeah I did a bit of serching and couldn't find a dual post 27F. Northstar does make the 27M AGM with dual posts, but the positive is on the front left like the regular 27, so no good... I just now found out why they added the "F" to 27 instead of the usual "R" for reversed posts : it's for Ford, who were the first to use a reversed 27, and the letter stuck after that...
You would benefit from a 27F, with all the extra reserve capacity it has over the 94R. But just a heads up : I've looked at other brands who make 27F AGMs and the Northstar really stands out in terms of CCA and RC ratings. Noticeably higher than the competition...
post #43 of 50 (permalink) Old 05-10-2017, 10:07 PM
I've got two 31 agm from batteries plus x2 power ones. They seem to have a 60month warranty where the north star only have a 48 month. But thanks for the 27F into. I'll prolly get one.
post #44 of 50 (permalink) Old 05-10-2017, 10:16 PM
Clark W. Griswold, Jr.'s Avatar
The 27F should fit.
I'd say it's a go !
@Mark_You're the best! I'm ordering right now and plan to pickup/install tomorrow night- I'll take pics when I do!
Mark_ likes this.
2015 Deep Cherry Red Trailhawk V6
Completely loaded (with the exception of hood decal, CD player, and black rims)
Clark W. Griswold, Jr. is offline
post #45 of 50 (permalink) Old 05-10-2017, 10:33 PM
Len ; the X2 Power 27F is a relabelled Northstar, and comes with a 60 month warranty as well :
https://www.batteriesplus.com/produc...ls/sli27fagmdp
post #46 of 50 (permalink) Old 05-10-2017, 10:35 PM
That's what I meant sorry. The 31 batteries I have are in my travel trailer. I'll prolly pick up a 27F in a few days.
Mark_ likes this.
post #47 of 50 (permalink) Old 05-11-2017, 08:42 AM
Well I ordered the battery last night but just got a call from the store that it actually needs to be special ordered in.... so it won't be available until next Friday. Oh well, I guess I'll have to wait- at least I'm not in a pinch!
post #48 of 50 (permalink) Old 05-11-2017, 09:21 AM
Oh no !.. how am I going to be able to sleep for a week ?
One week...
post #49 of 50 (permalink) Old 05-20-2017, 07:36 PM
@Mark_ ... it works! Thanks for your help and insight!
Group 27F battery fits in 2015 3.2!
Mark_ likes this.
post #50 of 50 (permalink) Old 05-21-2017, 05:29 PM
Uh-oh... here it comes...
Great news !
Key Fob acting up jkjhooks Electronics, Audio, and Lighting 17 01-05-2017 03:30 PM
Blue ink on positive battery terminal? Does your jeeps battery have that? XtremeModder Engine and Technical Discussion 12 04-20-2016 10:45 AM
R01 Update Acting Wonky davelja 2014+ Jeep Cherokee General Discussion 106 07-05-2015 02:09 PM
Fob died? (not battery) RockyMtnHawk 2014+ Jeep Cherokee General Discussion 3 05-02-2015 06:20 PM
Engine harness to be replaced--Kee acting crazy! Shorts360 2014+ Jeep Cherokee General Discussion 9 05-03-2014 08:59 PM
