Oil Pressure Sensor Replaced - 2014+ Jeep Cherokee Forums
 1Likes
  • 1 Post By sanghill
post #1 of 4 (permalink) Old 03-11-2017, 10:43 AM Thread Starter
deevemon's Avatar
just a FYI note - check engine light came on at around 38k miles. Back to dealer who replaced the oil pressure sensor. Not covered under powertrain warranty. Now that it's out of warranty, I worry about all these electronic gadgets starting to fail. Anyone else experienced this?
Dave
White Limited 4x4
Vesuvius Interior
Active Drive I
V6, Tech, Lux, Tow
8.4N, CD, Charge Pad
Bld Date 6/2014
deevemon is offline
post #2 of 4 (permalink) Old 03-11-2017, 12:25 PM
sanghill's Avatar
Mine failed at 18900 miles. Build date Jan 2014. V6 engine.
Had to remove the upper and lower intake manifolds to get to the sensor. Replaced manifold gaskets.
My sensor did not leak, just set code P0520.
The new sensor is the same part number as the one that failed so that isn't very encouraging.
Refer to TSB 18-034-14 Rev A for more info.
Haven't had any more problems with the new sensor.
Guess FCA just buys from the lowest bidder.
007 likes this.
sanghill is offline
post #3 of 4 (permalink) Old 03-12-2017, 07:54 PM Thread Starter
deevemon's Avatar
Thanks, Sanghill. I'll check out the TSB.
Dave
White Limited 4x4
Vesuvius Interior
Active Drive I
V6, Tech, Lux, Tow
Bld Date 6/2014
deevemon is offline
post #4 of 4 (permalink) Old 03-12-2017, 08:01 PM
Desoto's Avatar
Some Dealers will choose to replace the Oil Cooler on early builds. That would be covered under powertrain.
Desoto is offline
Intelligent Battery Sensor being replaced? XtremeModder Electronics, Audio, and Lighting 7 02-21-2017 01:18 PM
Where is the Oil Pressure Sensor pocopine Engine and Technical Discussion 5 10-22-2016 10:06 AM
Oil Pressure Sensor agent Engine and Technical Discussion 5 04-18-2016 10:35 AM
Latest Update To TSB 18-034-14 (Oil Pressure Sensor) -- Dated July 15, 2014 fdegree Engine and Technical Discussion 11 09-23-2015 10:22 AM
Oil Pressure Reading 14SDJeep Engine and Technical Discussion 12 10-05-2014 03:46 PM
