Front Steering Knuckle Replacement - 2014+ Jeep Cherokee Forums
 1Likes
  • 1 Post By josho
post #1 of 4 (permalink) Old 04-13-2017, 05:11 PM Thread Starter
deevemon's Avatar
39K miles
My experience with bad ball joint repair. Noise from underneath the car traced to a bad left ball joint. The repair requires replacement of the whole steering knuckle/balljoint as it's one integral unit.
The steering knuckle was $484 plus $180 labor. Ouch! The repair was by the dealer that I bought the Jeep from.
Afterward I got home, checked the price of the part on Rock Auto; appeared to be about the same price, but I noticed that the part was listed as "out of stock." Hope this doesn't mean there's a design or material problem, since there's another one on the other side!
Dave
White Limited 4x4
Vesuvius Interior
Active Drive I
V6, Tech, Lux, Tow
8.4N, CD, Charge Pad
Bld Date 6/2014
deevemon is offline
post #2 of 4 (permalink) Old 04-13-2017, 05:26 PM
Originally Posted by deevemon View Post
39K miles
Hi there,
Thanks for sharing that.
I had the left side ball joint replaced on mine at 20K miles under warranty (the hole knuckle). Now I'm just over the 25K mark and the right side ball joint is klunking...
BTW, Moog has recently come out with a standalone lower ball joint for the KLs. No one on the forum has reported a successful install yet (edit ; not true, @Desoto has one or two done), though I'm sure it's coming. One member did purchase one, but the shop person told him they couldn't remove the old joint with the knuckle still in place, so he gave up and had the knuckle replaced instead...
Source : Ball joint 20K
Mark_ is online now
post #3 of 4 (permalink) Old 04-13-2017, 06:20 PM Thread Starter
deevemon's Avatar
Thanks, Mark_, for your reply. I went back and read your earlier thread. Now I'm worried about the right one going out. I don't have any extended warrany so the $700+ was out of pocket for me.
I did notice that one reply in that thread mentioned greasing existing ball joints using a needle fitting on the end of a grease gun. I'm thinking of trying this on the right side, although I'm assuming that he's talking about just puncturing the boot with the needle and filling it with grease.
I did bookmark the link for the Moog ball joint, though it may be hard to find a local mechanic that would know how to disassemble the joint from the knuckle and reinstall the new one. Moog may provide instructions, which I'll check on when the right one goes out.
Dave
White Limited 4x4
Vesuvius Interior
Active Drive I
V6, Tech, Lux, Tow
Bld Date 6/2014
deevemon is offline
post #4 of 4 (permalink) Old 04-15-2017, 08:10 AM
Yikes! I recently had to replace both knuckles, along with a bearing that had seized up. Similar mileage, just shy of 40k, I believe (currently at 43).
At that price, expecting the right knuckle to go might be enough to justify buying an extended warranty. My whole repair for both knuckles and the bearing was about $200 thanks to the warranty.
SkipW likes this.
josho is offline
Front Fascia Replacement/Installation cost Jeepinprogress Exterior 6 04-12-2017 04:28 PM
Custom Steel front bumper replacement AGP Exterior 7 11-04-2016 03:15 AM
Front brake and rotor replacement Huxley Jeepcherokeeclub.com How-To's 1 04-22-2016 08:34 AM
Height change with stock knuckle and strut in front? Patrickh616 Wheels, Tires, Brakes, and Suspension 4 04-29-2015 09:31 PM
I've had front axles replaced; steering whl question.. LoriLove13 Engine and Technical Discussion 2 10-30-2014 03:28 PM
