MAKE STICKY: ALLPAR Cherokee Flash Page - 2014+ Jeep Cherokee Forums
 12Likes
post #1 of 34 (permalink) Old 05-19-2014, 10:09 AM Thread Starter
eak
eak's Avatar
http://www.allpar.com/news/index.php...-flash-details
Posted on May 16th, 2014 • by David Zatz
Chrysler has issued a service bulletin that clarifies the “flash” upgrade, which updates the transmission control software on Jeep Cherokees built before May 5, 2014.
Bulletin number 21-018-14 points out that the software helps overall shift quality and throttle response, with specific improvements to:
Shifting out of park
Automatic downshifts while coasting
Prevention of “busy shifting”
Prevention of “transmission confusion” when drivers go into heavy acceleration, then suddenly lift their foot “change mind shift”
In addition, it can address conditions that cause the computer to record these errors:
P072F (stuck in fourth gear)
P076F (incorrect ration in seventh)
P0810 (clutch position control error)
P1CC9 (unable to engage gear)
P0734 (fourth gear incorrect ratio)
P071B (torque calculation performance error)
Sometimes, powertrain computers have been known to falsely record errors, and we do not know whether the issues above were caused by actual problems, solved by the software, or by false alarms.
The correct procedure should take around two hours, nearly all of which is a drive designed to train and test the transmission. Actually updating the flash should take around five to ten minutes, but the “adaptive drive learn,” which must be done by a skilled employee, takes much more time, and customers may want to observe the process to make sure this part is being done.
Customers are to be informed when the update is fully prepared, reportedly sometime in mid to late May.
Firmware updates for powertrain computers are not unusual, and can be issued long after a car is on the road. As transmissions have become more complex and have gained additional gears — from four to nine in less than a decade — programming has become an ever-greater challenge for automakers. The ZF transmissions have the ability to handle dozens of shift maps, depending on conditions; for Cherokee, the situation is complicated by the addition of all wheel drive, as well.
UN4GTBL, Jeepster1, Swede and 4 others like this.
Lake Orion, MI
Granite Crystal Metallic Date ordered: 03/Jan/2014 Delivered: 4/Mar/2014
Granite Crystal Metallic TH KL •|||||||•| 3.2L V6 24V VVT | 27E | 9-Spd 948TE 4WD
TOW |Comfort Convenience | Brown Leather | Technology| Uconnect 8.4AN
Cold Weather | Black Hood Decal | 9 Amplified Speakers w/Subwoofer | CD
eak is offline
post #2 of 34 (permalink) Old 05-19-2014, 10:49 AM
dawhitesTH's Avatar
Awesome find @eak. Just in time for my second oil change
dawhitesTH is offline
post #3 of 34 (permalink) Old 05-19-2014, 11:47 AM
70GT6's Avatar
Only thing the adaptive relearn does not have to be performed on all.
Specifics are listed in the actual TSB.
Jeepster1 likes this.
o | | | | | | | o
Bright Wht TH, Decal,
V6, Brn Leather, Tow,
Cold Weather, 8.4AN
70GT6 is offline
post #4 of 34 (permalink) Old 05-19-2014, 11:49 AM
I noticed that when reading the TSB. If you had teh december TSB done then you don't need to have the relearn process done. So it will be quick.
John
Hudsonhawk is offline
post #5 of 34 (permalink) Old 05-19-2014, 12:11 PM
dawhitesTH's Avatar
@70GT6 i always learn something new everyday. thanks.
post #6 of 34 (permalink) Old 05-19-2014, 12:23 PM
spicedham's Avatar
If you haven't had the December TSB done, does this mean you would need to do the relearn after the May flash? Or Would have to have the December TSB and then this Flash done? Or is all that's needed is the latest May flash?
Current: 2015 Limited Grand Cherokee | Offroad Adventure 1, Towing, Nav & Sunroof | Tech & Luxury
Previous: 2014 Limited Cherokee V6 | AD2 | Tech Package | Built 12/13/13
spicedham is online now
post #7 of 34 (permalink) Old 05-19-2014, 12:49 PM
Dynarider's Avatar
Thanks for the info eak. Just got back from the dealer and car is going in tomorrow morning for oil change and TSB. Wonder what the shifting out of park correction is for. Happened Friday and again on Saturday. Shifting from park to reverse to back out of a parking space and transmission appeared to be in neutral as the car wouldn't move till I returned to park and then back to reverse.
Dynarider is offline
post #8 of 34 (permalink) Old 05-19-2014, 02:39 PM
There are actually 2 TCM software pins that do not need AL TSB 21-13-13.
They are 682235$$AN or 682354$$AN. $$ are wild cards for any number.
Any other update software must follow TSB 21-13-13 or undesirable shifting can result.
Your dealer will know.
post #9 of 34 (permalink) Old 05-19-2014, 03:16 PM
HA_HA_HA_HA_HA_HA_HA_HA!!!!
You're kidding, right?
Sounds like some of the dealers don't even know the KL has been released...
Acidsnow, zzjdzz and minibeast like this.
post #10 of 34 (permalink) Old 05-19-2014, 03:24 PM
spicedham's Avatar
Thanks for the info!
Official JEEP Renegade page jkolker The Car Lounge 40 05-14-2015 03:11 PM
Post Trans Flash update - please discuss results after the TSB's have been performed jeevy81 Engine and Technical Discussion 126 04-25-2014 09:28 PM
On Hold - Adaptive Cruise Flash?? Macinator Cherokee Purchasing and Orders 1 04-16-2014 04:32 AM
New Facebook Page soulfish The Car Lounge 9 01-18-2014 08:54 PM
Just about time for a wheel and/or tire thread sticky? bruceg Wheels, Tires, Brakes, and Suspension 3 01-15-2014 10:48 AM
