Throttle position sensor: Check engine light - 2014+ Jeep Cherokee Forums
post #1 of 13 (permalink) Old 08-31-2014, 06:36 PM Thread Starter
WyoKid's Avatar
I took my TH in on friday for a aftermarket sound system installed. After they got it all put back together and started it, it started revving high in idle and check engine light came on. Transmission code, throttle sensor. They had it towed it to dealership. Waiting till weds before they look at it...bumming big time. Labor day weekend. Does anyone think this might be a big issue?? Thanks... new to the forums. Hope Im posting in the right area! Feed back is appreciated
WyoKid is offline
post #2 of 13 (permalink) Old 08-31-2014, 07:02 PM
Bucky's Avatar
Guessing they messed up the wiring or a fuse somehow. Messing with the uconnect system aka radio and not sure what your doing could really open up a can of worms. Keep your fingers crossed that's all that happens
2014 mango tango Trailhawk , v6 , leather , cold weather pkg ,nav
Bucky is offline
post #3 of 13 (permalink) Old 08-31-2014, 07:47 PM Thread Starter
WyoKid's Avatar
Thanks for your response Bucky...They are not messing (i hope) with the Uconnect system...just connecting a http://www.crutchfield.com/S-m5aJKQ0...-1.html?tp=115 and a http://www.kenwood.com/usa/car/excelon/p-xw1000b/ ....Thanks again
WyoKid is offline
post #4 of 13 (permalink) Old 08-31-2014, 07:50 PM Thread Starter
WyoKid's Avatar
BTW....I love that Mango Tango color!!!!!!
WyoKid is offline
post #5 of 13 (permalink) Old 08-31-2014, 07:54 PM
Bucky's Avatar
Let's see a pic of your th ! Aren't they a pleasure to drive ?
Bucky is offline
post #6 of 13 (permalink) Old 08-31-2014, 08:16 PM Thread Starter
WyoKid's Avatar
Attachment 30314
Yes!! They are a blast to drive!! Love it!!
WyoKid is offline
post #7 of 13 (permalink) Old 08-31-2014, 08:24 PM
Bucky's Avatar
Sweet !.....the lady and the Trailhawk !, Lol
Bucky is offline
post #8 of 13 (permalink) Old 09-01-2014, 02:02 AM
Could be bad splice? Did they disrupt the stereo to computer communications? My 06' Dodge diesel has a twisted pair computer communications cable throughout the vehicle. Touch that pair at ones own demise.
This repair might not be covered by Chrysler warranty.
wcjeep is offline
post #9 of 13 (permalink) Old 09-01-2014, 01:46 PM Thread Starter
WyoKid's Avatar
Its at the dealership right now but I dont think they disrupted anything with the Uconnect system or the stereo system. I had them add an amp and sub woofer. I did some research on the throttle sensor and found out they are very sensitive to being grounded out. Thats where I think the problem lies...I hope. But they are paying for tow and to get it fixed...unless it is covered under the warranty. Ill find out Weds. Its sucks being w/o it.
WyoKid is offline
post #10 of 13 (permalink) Old 09-01-2014, 02:05 PM
scarpi's Avatar
If the stereo shop damaged some wiring, Chrysler probably won't cover the repair. As a side note, my Cherokee had the MIL (check engine light) on and the electronic throttle control warning light on and it turned out to be a bad connection between the coolant temperature sensor and the PCM (engine computer). My dealer repaired the connection and no more warning lights. Good luck and hopefully it had nothing to do with the stereo install so it will be covered by your vehicle warranty.
2014 Cherokee Latitude 4x4
3.2L V6, Active Drive II
Off Road Suspension
Billet Silver
Morocco Black interior
Comfort/Convenience group, power lift gate,
keyless ignition, power driver seat, Uconnect 8.4A
scarpi is offline
Check engine light.....again scarpi Engine and Technical Discussion 58 12-27-2015 11:24 PM
Check engine light --- again mikbob38 Engine and Technical Discussion 49 05-11-2015 01:28 PM
Check Engine Light .....again scarpi Engine and Technical Discussion 26 02-24-2015 07:54 PM
Check Engine Light AutobahnCherokeeTrailhawk Electronics, Audio, and Lighting 3 05-28-2014 07:52 PM
Check Engine Light while not running Patrick25 Engine and Technical Discussion 15 05-17-2014 03:58 AM
