Odd whine when travelling at speed - Page 2 - 2014+ Jeep Cherokee Forums
 1Likes
post #11 of 36 (permalink) Old 12-10-2014, 07:32 PM
Let me know if it sounds like the following MP3 from my Dropbox. About 3.3mb download
https://www.dropbox.com/s/iodf46gnhe...0only.mp3?dl=0
wcjeep is offline
post #12 of 36 (permalink) Old 12-10-2014, 08:20 PM Thread Starter
Not 100% sure but I think it sounded like that. It hasn't been that long you'd think the sound would have stayed in my memory.
2014 Cherokee North
Billet Silver
3.2L V6 AD1
Comfort and Convenience, Cold Weather
Foog is online now
post #13 of 36 (permalink) Old 12-10-2014, 08:28 PM
There was some shuffling noise in the mp3. That is me moving cell phone around. This was originally video I converted to mp3. The problem was the intermittent nature of the noise. This makes it difficult for the dealer to diagnose. First fix was lots of sound proof tape. This changed the pitch and duration of the problem. Mp3 I posted is the original sound before sound proof tape. Ours would most commonly make the sound while gently rolling through 35mph on a flat surface.
Here is a list of parts needed for the repair
68223036AA :Housing: A/C and Heater
68223040AA :Evaporato: Air Conditioning
68223042AA :Seal Kit: A/C and Heater Uni
68223046AA :Housing: A/C and Heater Lowe
1WG18DX9AD :Panel: Cowl Side Trim
1UD18DX9AC :Plate: Scuff
68163848AA :Antifreeze: Coolant
68223045AA oor: Filter Access
Replaced A/C Evaporater Core and Cover and upper Heater Box Half
wcjeep is offline
post #14 of 36 (permalink) Old 12-10-2014, 11:01 PM
Same as me!!! when 15MPH there is a whine sound like WUuuuuuuuuu.... When speed change, sound just gone.
2014 Cherokee 2.4L SPORT Silver 4*4
Ljeffyoung is offline
post #15 of 36 (permalink) Old 12-10-2014, 11:07 PM
After going to the dealer a few times I took video. Uploaded the video to a private YouTube account for the dealer. Then converted to mp3. Placed both the video mp4 and audio mp3 on a memory stick for dealer tech to review/compare. After replacing the parts previously listed the vehicle is now quiet. I also played the video for the check in person on my phone.
wcjeep is offline
post #16 of 36 (permalink) Old 12-14-2014, 12:17 PM
I have the same whistle type noise as well. Only happens in more extreme cold temps(-20...-40F)and goes away after driving around for a while. Its not the motor being cold as I can let the jeep warm up all the way to normal operating temp and it's still starts when driving,it's in the drive end of things in my opinion. It's rather annoying and bothers me in the fact that I think something's wrong with my new vehicle. I live in northern Manitoba so it remains these temps all winter long so it's a daily occurrence for me. I've tried to tell my dealer here this is what they tell me "many strange things happen to vehicles in cold temps" "would you like to move at 50km hr in -20...-40F" "that's just the way it is"
So I am glad to see other dealers trying to help you guys.
If I'm reading things correctly after those parts were swapped, the noise is gone? wcjeep?
V6 Trailhawk
Granite, tow, cold weather, comfort, hood decal, cloth, Alpine upgrade, 8.4AN NAV, back-up cam, black wheels
Order date: April 03 2014
Waiting....
Mehndawg is offline
post #17 of 36 (permalink) Old 12-14-2014, 12:20 PM
Correct. Zero noise. Problem was the noise was intermittent. Took awhile for dealer to verify the noise.
wcjeep is offline
post #18 of 36 (permalink) Old 01-08-2015, 07:17 PM
A new TSB was posted today to correct this: http://www.wk2jeeps.com/tsb/tsb_wk2_0700215.pdf
RojStock likes this.
JRSJEEP is offline
post #19 of 36 (permalink) Old 01-08-2015, 08:26 PM
Our noise was definitely not the Idler pulley. Ours was Hvac. When they finally replaced most of the dash hvac the noise went away.
wcjeep is offline
post #20 of 36 (permalink) Old 01-08-2015, 08:45 PM
jamie1's Avatar
I don't think the noise being described is the idler pulley. Mine has started making the noise too. Vehicle has to be cold with the outside temp generally colder than -15C. Jeep has to be moving. I know with mine, as the Jeep warms up, you have to go faster before the noise starts up and eventually stops. The noise will go away when coasting, but is there on accel and while cruising. To me it sounds like it coming from the frt end, possible in the transfer case. Been crazy busy at work this week, but hopefully I will be able to sneak it in Friday and put it up on the hoist and take a peek.
jamie1 is offline
Whine, alternating, from under hood, engine off... 14SDJeep Engine and Technical Discussion 26 12-19-2014 10:42 AM
Odd notification alert SGilbert Electronics, Audio, and Lighting 3 11-14-2014 08:14 PM
Something ODD with RPMs madchemist24 Engine and Technical Discussion 9 05-19-2014 03:28 PM
Strange faint Whine under th hood when parked today Gumby357 2014+ Jeep Cherokee General Discussion 5 04-16-2014 08:21 AM
Engine compartment whine mtudb24 Engine and Technical Discussion 2 02-28-2014 10:18 PM
