Odd whine when travelling at speed - Page 3 - 2014+ Jeep Cherokee Forums
 1Likes
post #21 of 36 (permalink) Old 01-08-2015, 08:49 PM
Well thanks I'll have to go back to the dealer with this info... How long did it take till you got your jeep back from the shop? wcjeep
V6 Trailhawk
Granite, tow, cold weather, comfort, hood decal, cloth, Alpine upgrade, 8.4AN NAV, back-up cam, black wheels
Order date: April 03 2014
Waiting....
Mehndawg is offline
post #22 of 36 (permalink) Old 01-08-2015, 08:49 PM
Take video of the noise before going to the dealer. Play the video for the service rep. Mechanic if possible. It's so intermittent it's difficult to isolate. Ours would most likely make the noise as we gently pressed on the gas pedal. Most of the time it would make the sound as we gently accelerated past 34/35mph.
wcjeep is offline
post #23 of 36 (permalink) Old 01-08-2015, 08:52 PM
Not sure how many times. We had a bad driver rear knuckle too. It took a few times in the shop to sorta fix it with sound deadening tape. It wasn't until replacing most of the Hvac system did the sound go away.
Now the vehicle has a mystery cooling system leak. Seeking lemon law protection.
wcjeep is offline
post #24 of 36 (permalink) Old 01-08-2015, 08:53 PM
Alright thanks although mine is constant when driving 25-70 km an hr and last for a long time till things kinda loosen up
V6 Trailhawk
Waiting....
Mehndawg is offline
post #25 of 36 (permalink) Old 01-08-2015, 09:28 PM
jamie1's Avatar
wcjeep, I listened to your dropbox. For sure mine is different.
jamie1 is offline
post #26 of 36 (permalink) Old 01-08-2015, 10:05 PM
Hello,
I have also spotted the sound earlier this morning on my 2014 Limited model. When this occurred I noticed that my rear camera which was clean present a dark image on my display. My windshield water jets (cleaners) were either frozen or didn't work. This is kind of strange and wondered who else has this problem. Will need to bring it to the shop.
PS: my MPG on my V6 isn't that great either, somewhere 19-20 (same as my old Nissan Juke).
Maybe I should have waited for the smaller Jeep Renegade with the lighter body and smaller engine.
Evan M is offline
post #27 of 36 (permalink) Old 01-08-2015, 10:42 PM
noise when cold
My Sport developed a whirring type noise a week ago on a 125 mile trip home in -25c weather. Noticed it when we started slowing down, less road noise. Sounds like driveline noise, specifically a Torrington bearing type noise. Definitely not an idler as it's not engine speed related. Normally the car is in a heated garage so it has to run in the cold for a while before the noise will audible.
Metalbender is offline
post #28 of 36 (permalink) Old 01-09-2015, 01:02 AM
I just noticed the howl/whiny noise last night. We have had snow lately. I stopped got out and looked at the rear wheels, that is where the noise seemed to be coming from. There was snow packed between the splash guard and tire, also a LOT packed in the wheel well. I kicked the plastic between the splash guard and wheel well, and more came out than I thought would.. when I started moving again the noise was gone. Today after driving around again for a while in the snow it started again. I pulled over again but there wasn't that much snow between the splash guard and the tire. I still kicked between the guard and wheel well and couldn't believe how much snow came out again, and once again the noise was gone. I figured it had something to do with all the snow packed in the wheel wells.....now I'm not sure sure.
TnTZing is offline
post #29 of 36 (permalink) Old 01-09-2015, 04:10 AM
Tyler-98-W68's Avatar
My wifes 2014 ADII Limited V6 started with the faint whining sound that others have described here.
It happens when the vehicle has been outside in cold weather and then driven. Most times it's parked in a heated garage, but I've had my jeep inside for the last few days work on it. So with it being cold all the way through the problem is happening.
At the same time I have noticed the brakes seem very touchy, almost like the braking force is greater on the rear than it should be (almost more of a rear bias)
I went out for a drive with the vehicle making the noise, and came back and the back brakes felt warm (fronts were cold) so I'm thinking my issue might be sticking breaks or the e-brake cable out of adjustment.
Haven't taken it in to the dealer yet.
2016 Cherokee Trailhawk V6
Rhino
AFE Intake
Flowmaster Super 10 Muffler
Noco Onboard Charger
Trailer Tow
Sunroof
Nav & 9 Amplified Speakers
White
RPM Motorsports Torque Tube
TH Wheels
Trailer Tow
Luxury Package
Technology Package
Sunroof
LED Fog Lights
Tyler-98-W68 is offline
post #30 of 36 (permalink) Old 01-16-2015, 12:10 PM
ib516's Avatar
Originally Posted by saltwatercowboy View Post
Hey, I am on Alberta too. Mine does the same thing when the cold is extreme. I think it come from the metal in the hub area spinning. It goes away all spring summer and fall. and then when we get into the -30c area it returns. I never seen an ill effects from it. learned to live with. Goes away when the car warms up.
Same here - and I'm in Saskatchewan. Only shows up when really cold out, and only for the first few miles driven. Sounds like a rear end noise.
2014 Trailhawk V6
  • White exterior
  • Brown leather interior
  • Every option except tow pkg and CD player
  • Ordered: Nov 9, 2013
  • Delivered: Jan 16, 2014
ib516 is offline
Whine, alternating, from under hood, engine off... 14SDJeep Engine and Technical Discussion 26 12-19-2014 10:42 AM
Odd notification alert SGilbert Electronics, Audio, and Lighting 3 11-14-2014 08:14 PM
Something ODD with RPMs madchemist24 Engine and Technical Discussion 9 05-19-2014 03:28 PM
Strange faint Whine under th hood when parked today Gumby357 2014+ Jeep Cherokee General Discussion 5 04-16-2014 08:21 AM
Engine compartment whine mtudb24 Engine and Technical Discussion 2 02-28-2014 10:18 PM
