Adding the Tow Package after purchase? - Page 3 - 2014+ Jeep Cherokee Forums
 11Likes
post #21 of 71 (permalink) Old 07-27-2015, 09:10 PM
I'm in the same boat. I bought a Trailhawk last December. Didn't come with a tow package from the factory. Which I wanted but it was the only one I could find with color combo and certain options I wanted/needed. When you build and price it says it adds the auxiliary transmission oil cooler but doesn't the Trailhawk model already come with one? If I add one, can I tow up to 4600 lbs or am I still stuck with 2000 lb towing rating? How can I fix it? I'm really disappointed I couldt find the exact model I wanted but the only Trailhawk model I could find with a tow hitch had a bunch of more crap on it that bumped the price up another $2,500.
brianfl33916 is offline
post #22 of 71 (permalink) Old 07-27-2015, 10:23 PM
You still dont have the Tow ratio gears, your rated limit is 2000 lbs, will it tow 4600 Sure , how long ???? lots of hills?
Hers.
2014 Cherokee Limited Granite
V6 , AD II
Luxury, Tech
Tow, 8.4 Nav, Moon Roof
Alpine 9/AMP
Charge Pad
His,
2013 Redline Durango R/T
AFE, Diablo Trinty, HemiFever Tuned,SRT Reps & SRT Brembos, Drilled & Slotted PowersStops.
DooHauler is offline
post #23 of 71 (permalink) Old 07-28-2015, 02:49 AM
Not a lot of hills I'm in Florida. But I would like to tow a pop up camper or a boat in the near future. Both can get close to 2800 lbs. I have an 06 ram 1500 truck that can certainly tow but it has139000 miles on it now and I'm wanting to get rid of it. Too much gas. Plus it's only 2wd. Is the gearing in the axles? My buddy changed his gears out in his truck not that long ago. Couldn't be that hard.
post #24 of 71 (permalink) Old 07-28-2015, 04:05 AM
From your build sheet what gears did it come with? I thought the Trailhawk had the lower gearing already?
Build sheet here in case you haven't seen the link https://jeep.custhelp.com/app/jeep/e...WGxOMmc2T2w%3D
Mine is the V6 with Tow pack and I have the 3.517 gears acordung to my build sheet.
And I cant see changing them as being easy, they are not standard diffs like a Wrangler.
ptrudel likes this.
post #25 of 71 (permalink) Old 07-28-2015, 09:46 AM
Not sure what my build sheet is. I'll look at it later. Hard to believe that a little bit of gearing goes from 2000 lbs to 4600 lbs of towing. Are the gears in the axle or the tranny? I would think with my V6 I could get it up to at least 3000 lbs if the 4 cylinder that doesn't add gearing with a tow package can tow up to 2000 lbs. The extra cooling is already there in the Trailhawk model.
post #26 of 71 (permalink) Old 07-28-2015, 11:42 AM
Mudman1's Avatar
Not sure what you are trying to argue here. If you are looking at doing this stuff to a vehicle, and you do not know how to do it yourself, take it to the dealer. Open your check book and tell them what you want done. The other option is to buy a vehicle already built to do what you want. This last option is what myself and many others did.
We are not randomly making up the towing specs. These are what Jeep says applies to various situations. You can drag around a flat bed with a Bobcat on it for all we care. It is your conscience that has to rest easy.
Mudman1 is offline
post #27 of 71 (permalink) Old 07-28-2015, 05:00 PM
O|||||||O's Avatar
With 4 of the top gears all overdrive I would say it's okay to pull 4500# on relatively flat ground. The engine cooling capacity (trail hawk) is there so heat rejection shouldn't be an issue.
The real concern I have is at very low speeds like pulling a trailer/boat/camper around where the torque converter is in stall at lot. The trans oil will get hot faster with the taller gearing. To get around this just use 4lo whenever maneuvering a heavy load at really low speed for more then a few minutes.
Also keep,the frontal area of your trailer at or below what is specified in the owners manual.
Watch your trans oil temp and you will be fine (under 230 deg f). The trailer towing capacity is specified at very high ambient temperatures (110deg F) usually so if it hot outside back off on towing loads.
Most people on this forums have no engineering background to support there opinions.
Aka "Krug"
2014 Mango Tango TH
Born on 4/14
Yes, it's been perfect so far
O|||||||O is offline
post #28 of 71 (permalink) Old 07-28-2015, 06:22 PM
Pondhopper's Avatar
The question is what can I tow with no factory installed parts. The parts to include wiring harness to plug into (no effect on tow rating), 2" receiver same with 2,000 lbs and 4,500 (same) if using a class 3 add on still good for all ratings. Engine 2.4 limited to 2,000 lbs in all situations. 3.2 is needed for it to pull 4,500 but with limitations. Aux cooler part of the factory tow package, this is need to handle the extra heat. Now is where factory or dealer comes into an issue with out the cooler you could still pull the 4,500 lbs but you would be responsible for the transmission temps and would possible to void the warranty as your vehicle was not rated for that load. Same is true for the gearing a lower gearing is to take some strain off the transmission so it you pull and break it could void the warranty. So would a Dealer installed tow package work yes, would it be covered by warranty? probably not. Get it in writing from the dealer that they would cover anything the manufacturer would not (bet they won't) the difference is what the manufacturer will cover not what the vehicle can do. The old rule is your max tow is the rating of the weakest part. On a v6 trailhawk with the tow package it is the max vehicle weight 4,500 lbs if you go down in hitch or even the ball then it would be whatever the weakest part is. I hope this breaks it down to the basics.
Pondhopper is offline
post #29 of 71 (permalink) Old 07-28-2015, 08:01 PM
Thanks. This has been a help. I'll check it out with maybe getting a hitch on. I wasn't looking to tow any more than 3000 lbs. just didn't want to be limited to 2000lbs like a 4 cylinder.
post #30 of 71 (permalink) Old 07-28-2015, 08:03 PM
Gator's Avatar
I wouldn't worry about it. Just watch the gauges and don't enter any tractor pull contests!
3.2L
Black Hood Decal
MFG build date 10/13
Gator is offline
Bought a Cherokee today. Dealer "adding" tow package next week Legend 2014+ Jeep Cherokee General Discussion 143 12-04-2016 10:46 AM
Dealer adding sunroof after purchase Jdon 2014+ Jeep Cherokee General Discussion 37 11-24-2016 12:59 AM
Adding front tow hooks Unicorn1 Owners' Garage 18 11-23-2015 09:11 AM
Adding cold weather pkg AFTER purchase dawhitesTH 2014+ Jeep Cherokee General Discussion 7 01-02-2015 03:12 PM
Adding tow hitch to TH? vanawesome Exterior 6 08-18-2014 11:23 PM
