Adding the Tow Package after purchase? - Page 6 - 2014+ Jeep Cherokee Forums
 9Likes
post #51 of 60 (permalink) Old 08-02-2015, 10:42 AM
'05Train's Avatar
I've hit 9th a couple of times, but not cruising. At legal highway speeds I'm in 8th., as is everyone else. At 70mph in 8th, a KL with the Tow Package will be running at a higher RPM than a KL without the Tow Package. This is not an opinion, it's a simple mathematic formula.
2015 Trailhawk - Mango Tango, V6, Nav, Vented Seats, Big Honkin' Sunroof
Miss you too Montanan......
'05Train is offline
post #52 of 60 (permalink) Old 08-02-2015, 11:18 AM
Your math is... math. Equal speed in same gear = higher rpm for shorter final drive = less fuel economy.
Real world : we drive at different speeds all the time, unless you like to *cruise it* at the exact same speed all of the time because, well, it's very important to you, has special meaning or something...
Real world driving with a 9 speed not hitting top speed(edit > gear) kinda makes the math less... interesting, and brings physics to the forefront.
Looking at members' mpg numbers on these forums, it's hard to tell which is tall and which is short gearing, to me anyway. Statisitics are math, kinda. More data needed for accuracy of course, but it's fun to do quick observations.
If my KL is in 8th at, say, 56mph and a taller geared KL is in 7th, then... which is getting better mileage ? If the shorter geared KL can keep 8th with a slight head wind at 76mph and the taller geared can't... which one gets home with more gas left in the tank ? But yeah, if both need to go 80 and both stay in 8th gear, then the taller guy wins because that's the math.
David_Baker likes this.
Last edited by Mark_; 08-02-2015 at 11:32 AM. Reason: edited speed to gear somewhere in there..
post #53 of 60 (permalink) Old 04-09-2017, 07:41 PM
Wheyman's Avatar
I almost hate to revive this thread, and maybe it's answered elsewhere but, if you get the aftermarket factory wiring harness installed and flashed, does it come with the trailer brake controller? Curious because I've read other members adding an aftermarket controller to their KL' and also read they having it flashed you get the controller. I have added the OEM hitch and looking to add the wiring harness but want to figure in the controller in my budget if it isn't included in the harness.
Wheyman is offline
post #54 of 60 (permalink) Old 04-09-2017, 07:48 PM
No. The brake controller will have to be hardwired in. Only the factory system has the plug for a brake controller.
Not that it should matter because without the factory tow package you shouldn't be towing anything heavy enough to need a brake controller.
post #55 of 60 (permalink) Old 04-09-2017, 07:58 PM
Wheyman's Avatar
Normally I would say that's true, but after this trip to Moab and going over the passes with long step downgrades, I wouldn't want to tow even 2000 pounds without one.
Sent from my SM-T800 using Tapatalk
Wheyman is offline
post #56 of 60 (permalink) Old 04-09-2017, 08:02 PM
Towed my 3500lb travel trailer through there. Wasn't until a few months ago I realized the brakes on my travel trailer are bad. Which may have contributed to the early failure of my factory rotors. I'm not against adding a brake controller for something lighter. Just understand it'll have to be hardwired in.
post #57 of 60 (permalink) Old 04-09-2017, 08:14 PM
Wheyman's Avatar
Maybe it's just the trucker in me but I would rather have it and not need it than need it and not have it.
Wheyman is offline
post #58 of 60 (permalink) Old 04-10-2017, 06:52 AM
Having trailer brakes on even a loaded 1000lb trailer if available is a good thing.
Safety is improved. Also the wear on your vehicles brakes are reduced.
Its a win win with trailer brakes. The only downside is increased maintenance on the trailer.
post #59 of 60 (permalink) Old 04-10-2017, 07:36 AM
The problem is, trailers that lite often don't have brakes. So unless the trailer is custom it's not needed.
post #60 of 60 (permalink) Old 04-10-2017, 07:38 AM
I was a trucker too. That's why I can handle my rig without brakes. I don't drive like an idiot when I'm towing. But I also have slotted and cross drilled brakes now and believe me, they get a work out. The brakes on my trailer are just out of adjustment and since I live in an apartment i don't have a space to pull the drums off and adjust them.
Wheyman likes this.
Bought a Cherokee today. Dealer "adding" tow package next week Legend 2014+ Jeep Cherokee General Discussion 143 12-04-2016 10:46 AM
Dealer adding sunroof after purchase Jdon 2014+ Jeep Cherokee General Discussion 37 11-24-2016 12:59 AM
Adding front tow hooks Unicorn1 Owners' Garage 18 11-23-2015 09:11 AM
Adding cold weather pkg AFTER purchase dawhitesTH 2014+ Jeep Cherokee General Discussion 7 01-02-2015 03:12 PM
Adding tow hitch to TH? vanawesome Exterior 6 08-18-2014 11:23 PM
