My Towing Recommendations - Page 2 - 2014+ Jeep Cherokee Forums
 15Likes
post #11 of 33 (permalink) Old 06-29-2016, 12:03 PM
@Mark_It's all a matter of towing properly and within the limits of someone's ability.
And the limits of tow vehicle, towed vehicle, road/traffic conditions, etc.
Or, to put it more succinctly; "There's a helluva lot more to towing than just hooking up and go(w)ing."
Rojhan is online now
post #12 of 33 (permalink) Old 06-29-2016, 12:03 PM Thread Starter
Yup
Len1304 is online now
post #13 of 33 (permalink) Old 06-29-2016, 12:11 PM
I was barely able to control bodily functions at this point, it is one of the most unreal/scary thing I have ever faced as a driver...
Been there, done that. Both as "another vehicle on the road" and while towing with a combination of wind, road irregularity, and mechanical failure.
Hopefully the voice of experience between yourself, @Len1304, myself, etc. will help others avoid being part of the chorus.
Mark_ likes this.
post #14 of 33 (permalink) Old 06-29-2016, 12:57 PM
Ok, maybe answered elsewhere but may be worthy to add it to this thread..... I was glad to see the Cherokee's provide ready access to powertrain temperatures. So when towing, is there any guidance regarding elevated oil and transmission temperatures?
gonekljeepn is offline
post #15 of 33 (permalink) Old 06-29-2016, 01:00 PM Thread Starter
The Cherokee is equipped with a ton of warning lights and safety systems. If it's not giving you any warnings you should be fine. But understand if you are starting to hit a limit and you have the ac on the Cherokee will turn off the AC so that may be an early warning system of sorts. I have almost 6000 miles towing my trailer all over the US now and have not had a single problem. Even down here in Texas with a winch up front blocking part of the radiator.
post #16 of 33 (permalink) Old 06-29-2016, 01:02 PM Thread Starter
Oh, the Cherokee doesn't take kindly to towing a trailer 800 miles in the snow even at 15 degree outdoor temps I managed to overheat my 4wd. But I'm fairly certain I was pushing it beyond its design limits.
post #17 of 33 (permalink) Old 06-29-2016, 01:09 PM
Interesting.
Which Mode were you in : Auto ? Snow ?
Having 4WD engaged while towing a heavy trailer may cause overheating even in the summer as well (guessing).
Was it deep snow or just hard pack ?
post #18 of 33 (permalink) Old 06-29-2016, 01:14 PM Thread Starter
It was a mix of both, if the ground was white I was in snow mode because the traction control and stability control systems are more aggressive if it appeared dry I was in auto. My 4wd overheated JUST as I got to Moab and the roads cleared up. Within prolly 30 minutes it was back to working normally and I didn't have a problem again the rest of the 3200 miles. It was hard pack snow and ice. Tricky to tow the trailer through but nothing I couldn't handle. Wyoming on the other hand with 65 mph cross winds and blowing -30 was interesting but the anti sway system in the Cherokee and the anti sway on the trailer worked like a champ. But I was traveling at only 35 mph or so for nearly 200 miles to get through the storm on highway 80. Nasty stretch of road.
post #19 of 33 (permalink) Old 06-29-2016, 01:34 PM
Yikes, quite of mix of conditions there.
We,ve had one or two members report 4WD overheating while driving around in deep snow, no trailer behind. I guess you just have to play it by ear and rest it, when needed.
post #20 of 33 (permalink) Old 06-29-2016, 01:37 PM Thread Starter
The 2016 4wd when it overheats doesn't fully shutdown like it did on the 2014. It severely limits it but doesn't completely turn it off like it did on my 2014. https://youtu.be/qo1QAViZWY0
Mark_ and RenterRabbit like this.
SD Card Recommendations from Uconnect Array Electronics, Audio, and Lighting 53 11-23-2015 08:19 PM
Tool brand recommendations. gravitywell The JCC Lounge 15 11-20-2015 11:06 PM
Wheel recommendations JohnnyD Wheels, Tires, Brakes, and Suspension 0 05-19-2015 04:40 AM
Trailhawk recommendations Patronus86 2014+ Jeep Cherokee General Discussion 24 11-24-2014 09:09 AM
Recommendations on which one to buy JeepRod Cherokee Purchasing and Orders 14 01-28-2014 05:01 PM
