<GUIDE w/ PICTURES> OEM Trailer Hitch + Bezel Install - 2014+ Jeep Cherokee Forums
 11Likes
post #1 of 18 (permalink) Old 10-29-2016, 08:38 PM Thread Starter
AGP
AGP's Avatar
Thumbs up <GUIDE w/ PICTURES> OEM Trailer Hitch + Bezel Install
(GUIDE IN PROGRESS) Here will be a guide on installing the OEM Class III Trailer hitch and bezel. Pictures comming asap.
COST: $396 CAD (with ~$75 discounted from the cool guy I talked to at my preferred Jeep dealership)
TOOLS: T-30 Torx, 10MM socket, 11MM Socket, 21MM socket (more I am missing)
TIME: So far 2 hours (also learning how to do it as i haven't found any guide yet)
Progress: Hitch installed, still need to cut out hole in bumper for bezel
Step 1: Remove the 2 bolts (T-30 Torx) at the bottem left and right of the top of the bumper on the outside of the tailgate weatherstripping (tailgate must be open to see them)
Step 2: Remove the 4 bolts ((T-30 Torx)(2 from each side)) from the rear taillights
Step 3: Remove the 2 bolts, 4 if trailhawk?? ((10MM Socket)(1 from each side)) from the rear inside of the wheel well
PICTURE COMING SOON
Step 4: Remove the rear most plastic fender flair ((USE CAUTION, THE CLIPS WILL EASILY BRAKE)(No bolts))
PICTURE COMING SOON
Step 5: Remove the 2 bolts ((T-30 Torx)(1 from each side)) from where the plastic fender flair was
PICTURE COMING SOON
Step 6: Remove the 4 bolts (10MM? Socket) from under the bumper
PICTURE COMING SOON
Step 7: Remove the bumper assembly (Bumper and 2 rear painted parts) You will need to give them a good tug as the clips hold it well
Step 8: Remove the aluminum bumper (6x 14mm? Nuts IF NON-TRAILHAWK ... 6x 14mm? Nuts + 6x 21MM Bolts IF TRAILHAWK?)
Step 9: Install the new hitch with new hardware by sliding it into the frame (6x 21MM Bolts torqued to 122 FT-LBS or 165NM and the 6x 14MM? nuts torqued to 21FT-LBS or 28NM) There is some wiggle room when the bolts are in but not yet tightend, it's a good idea to either pull back or push the hitch into the frame to make sure it's square to the frame (I personally chose to pull the hitch towards the back then torqued the bolts)
BEZEL INSTALL: COMING TOMORROW
----- Silver 2015 Cherokee North 2.4L i4 4x4 AD1 -----
-80,000 KM (50,000 Miles)
-0W-20 Quakerstate Full Syth + K&N Filter
-1 1/8" Suspension Lift
-245/70R17 GENERAL GRABBER AT2 Tires
-Resonator Delete + Thrush Glasspack Muffler + 3.5" Chrome Tip
-Custom Roof rails and Rack w/ Tire mount & Fairing
-4x 6" PILOT Halogen Lights
-2x 4" Light Bars
-2x 10,000LB custom Tow Hooks
-Black Plasti-Dip'd Badges and Window trim
-1500W K40 4' CB antenna + Uniden Pro505
-Custom Ladder
AGP is offline
post #2 of 18 (permalink) Old 10-29-2016, 09:36 PM
Nice to see a write-up coming, it will be in demand often I'm sure. Interesting to see, even with the amount of dirt on the outside, how clean it is behind the panels.
AGP likes this.
SkipW is online now
post #3 of 18 (permalink) Old 10-30-2016, 10:33 PM Thread Starter
AGP
AGP's Avatar
BEZEL INSTALL:
Step1: Cut out the two rectangles in on the first template and place it on the BACK of the bumper then drill the 4 holes with a 1/4" drillbit
Step2: Cutout and align the 2nd set of template on the FRONT of the bumper using the plastic rivets supplied, the trace the template with a fine sharpie
Step3:Cut out the plastic required, I used a jigsaw (the template was not accurate at all. I spent about 1.5 hours cutting out the hole for the bezel, making sure i didnt cut out too much and i almost did.)
Step4: Drill 1/8 or 3/16" holes for the studs on the back of the bezel and use the supplied hardware to install (there is no template for the studs so you need to eyeball it)
END PROCUCT
Jeepster1, SkipW, Duke2015 and 1 others like this.
-2x 4" Light Bars
-Custom Ladder
AGP is offline
post #4 of 18 (permalink) Old 11-02-2016, 09:26 PM
ChefDan's Avatar
Step 4: Remove the rear most plastic fender flair ((USE CAUTION, THE CLIPS WILL EASILY BRAKE)(No bolts)).....what did you use to get the clips through, I can't get mine to budge.
2016 Jeep Cherokee High Altitude
red white and blue tattooed and just don't care!
ChefDan is offline
post #5 of 18 (permalink) Old 11-02-2016, 09:51 PM Thread Starter
AGP
AGP's Avatar
You need to kind of bend the tab with your hand one way while pulling the flair outwords then push the tab the other way. I'll probably make a video for that as it's hard to explain.
ChefDan likes this.
-2x 4" Light Bars
-Custom Ladder
AGP is offline
post #6 of 18 (permalink) Old 11-03-2016, 04:05 AM
tbrou6229's Avatar
I did this a while back and this guide would have been great! Instead I had to go off of random threads and the *absolutely wonderful* Mopar install documents. Great write up!
Tmugz88 likes this.
tbrou6229 is offline
post #7 of 18 (permalink) Old 11-03-2016, 07:54 AM
ChefDan's Avatar
Those Mopar install docs suck! Thanks for the help, I might work on it tonight since I want to get the hitch on so I can get a basket so I don't have to toss a dead deer in my trunk
ChefDan is offline
post #8 of 18 (permalink) Old 01-04-2017, 08:29 PM
gphinney's Avatar
Bezel on Trailhawk
Did you install the bezel on your TH?
gphinney is offline
post #9 of 18 (permalink) Old 01-04-2017, 08:30 PM
tbrou6229's Avatar
No, it was on my previous KL. A '15 Latitude.
~Mods List~ (In Progress!)
The First Family Member...
See HERE for Mod List!
post #10 of 18 (permalink) Old 02-22-2017, 03:35 PM
Awesome writeup! I will probably be using this if I don't just take it to the dealership to instal.
I am guessing you never ran wiring? If you did was it hard to do so? I don't really want to overpay for the dealership to run wiring but it might have to be the only way to do it without a lot of hassle.
b_boden is offline
After market OEM hitch install comparison pics cspaced Towing and the Towed 3 06-02-2016 04:47 PM
Considering OEM Hitch/Wiring/Bezel jmwgomz Owners' Garage 6 12-14-2015 10:48 AM
New OEM hitch install bamamojo Exterior 48 11-06-2015 10:11 PM
what's OEM trailer hitch look like? Gator Exterior 48 03-25-2015 10:43 PM
OEM Hitch Install ?? pricha00 Ontario 0 06-24-2014 06:01 PM
