Trailer battery charging? - 2014+ Jeep Cherokee Forums
post #1 of 6 (permalink) Old 12-20-2016, 08:39 PM Thread Starter
I think this is a total newb question but I couldn't find a definite answer online.
When my Jeep is connected to my travel trailer with the 7 pin connector and motor running, does it charge the trailer battery? Also when it's connected and motor not running, does it use/can it drain the car's battery?
My assumption is yes to both questions but I want to make sure, thanks!
norbertsz is offline
post #2 of 6 (permalink) Old 12-21-2016, 12:01 AM
exekie's Avatar
One of the pins in the 7 way connector is for a constant 12v supply, that the trailer would use to charge the battery. It should definitely be hot while the vehicle is running, it shouldn't have any power while the vehicle is off, but that could depend on the vehicle and I haven't checked on the cherokee yet, my previous truck only had power there while the engine was running. I'll have to try and remember to throw my test plug in when I get home to be able to give you a full answer.
exekie is offline
post #3 of 6 (permalink) Old 12-21-2016, 01:45 AM
I can confirm the charge line is hot at all times.
post #4 of 6 (permalink) Old 12-22-2016, 01:36 AM Thread Starter
Thank You!
post #5 of 6 (permalink) Old 02-20-2017, 10:29 PM
teo
I wonder why they build cherokees like that. There must be an explanation for it.
teo is offline
post #6 of 6 (permalink) Old 02-21-2017, 12:27 AM
Question
Teo-Teo-Teo... you are outdoing yourself now...
Here's my answer to your question : whaaaaaaat ?????
ESS Not Ready, Battery Charging HazzardSky Engine and Technical Discussion 44 03-17-2017 06:20 PM
was it really a bad battery or charging system? ksm 2014+ Jeep Cherokee General Discussion 10 07-14-2016 06:19 PM
ESS and battery charging.. baymnn Engine and Technical Discussion 13 02-01-2016 09:07 PM
Charging battery teo 2014+ Jeep Cherokee General Discussion 14 01-05-2016 11:05 AM
Battery is always charging now? XtremeModder Engine and Technical Discussion 3 02-28-2015 11:07 AM
