Recommendations - Page 2 - 2014+ Jeep Cherokee Forums
 7Likes
post #11 of 15 (permalink) Old 01-03-2017, 11:17 AM Thread Starter
Not sure what the under bumper hitch you guys get as aftermarket, but this is our "Mopar" hitch - comes out through the lower half of the bumper rather than through the middle. It doesnt really affect departure angle as it is the same position as the exhaust pipes.
Do you know any shops in the Wilmington, NC area who do this? Actually if I can save $200 - $300 and get a reputable OEM install from people who have experience putting in the OEM Trailhawk hitch package, wiring, and know how to do all the computer updates and wiring like its supposed to be done, then I would even head up to Raleigh or go to Myrtle Beach to get it done.
David Perry is offline
post #12 of 15 (permalink) Old 01-03-2017, 11:19 AM Thread Starter
Actually $1k for that hitch is about the going rate for an OEM install. The Wiring harness done correctly is labor intensive from what I understand. Also the dealer will need to flash the software to add the wiring into the system so it works correctly. Since the hitch sits in mid bumper surround that will likely have to be replaced, as it needs the cut outs for the hitch and wiring receptacles.
There are threads on this forum of members that have done the complete job themselves. A search will find that for you.
Also you need to consider that an OEM hitch will be rated by FCA for this vehicle specifically.
I would avoid anything but an OEM install. Two points to remember with a non OEM install. Under the bumper will look just what it is, an after thought. Wiring is the other issue. connecting it to the vehicle wiring directly is bad. It will work but you will have dim trailer lights and potential problems down the road as the lighting is not designed to handle that extra load.
The way I look at it, for $450 more you will have an OEM install that is tied into the the Jeeps electrical system, and flashed software wise. It will look great going forward.
Also you need to consider that this is a Trail Hawk and as such has certain needs. That is clearance going off road.
Now, officially you are limited to 2,000 towing but The Trail Hawk has the Transmission extra cooling and engine extra cooling built in to the TH package I believe. The axle ratio is important to a point but in my opinion it will impact you more at the upper end. The trans cooling is the most important issue when towing upper limits or in my opinion any limits.
But since your demands are not heavy towing the OEM set up is still the perfect option. The key Tow Group options should all ready be on this vehicle, the extra cooling. So exceeding those limits a bit will not hurt anything in my opinion. Also the wiring tied into the specialized tow relays will give you bright lights 100% of the time, that is an important thing.
Have fun with that Trail Hawk
Thanks for all the great info. Definitely think I will go with an OEM install. Better to wait and save another $450 than to get a less than optimal hitch package and/or install put in.
Jeepster1 likes this.
post #13 of 15 (permalink) Old 01-03-2017, 06:50 PM
goobnav's Avatar
Hey Dave,
Hate to say but the dealer is your best bet, if you come up closer to Triangle, advise to use the Leith dealers, Hendrick doesn't have a great reputation for service.
goobnav is offline
post #14 of 15 (permalink) Old 01-06-2017, 11:45 AM Thread Starter
I bought the vehicle from Capital CJD in Gardner. My local dealer is Neuwirth in Wilmington. How are their reputations?
post #15 of 15 (permalink) Old 01-06-2017, 12:53 PM
goobnav's Avatar
Capital CJD is pretty good, haven't heard anything about Neuwirth, definitely don't go to National in Jacksonville. I purchased ours at Leith Auto Park in Cary, they have good service.
goobnav is offline
My Towing Recommendations Len1304 Towing and the Towed 32 07-21-2016 03:15 PM
Tool brand recommendations. gravitywell The JCC Lounge 15 11-20-2015 11:06 PM
Wheel recommendations JohnnyD Wheels, Tires, Brakes, and Suspension 0 05-19-2015 04:40 AM
Trailhawk recommendations Patronus86 2014+ Jeep Cherokee General Discussion 24 11-24-2014 09:09 AM
Recommendations on which one to buy JeepRod Cherokee Purchasing and Orders 14 01-28-2014 05:01 PM
