Plug - Page 2 - 2014+ Jeep Cherokee Forums
 6Likes
post #11 of 12 (permalink) Old 02-17-2017, 12:44 AM
Out of my wheelhouse with towable travel trailers. My motorhome had four 12-volt deep cycle house batteries. When it came time to replace them I was shocked at the cost for those suckers. Replaced them instead with four Costco 6-volt golf cart batteries at $80 each that had almost the same AH rating. Will say though they do not do well cranking the 10K diesel generator. Sometimes have to start the engine first to get the generator started. Not a big deal for all the bucks I saved though.
Yea, deep cycle batteries typically don't do well starting engines. Newer batteries like the yellow top optima or batteries like mine do really well as dual purpose batteries. But you pay a small fortune for them. If I had the room I likely would have gone 6v myself but due to weight restrictions I went this route.
post #12 of 12 (permalink) Old 02-21-2017, 10:38 AM
.... The nice thing is the battery pin is switched; meaning it is live only when the ignition is on. Don't have to worry about the camper battery being drawn down into the vehicle's battery when the ignition is turned off.
Dang, I'm wrong on this.
Saw another post where @Len1304 stated, "I can confirm the charge line is hot at all times." So I went out with a voltmeter to check and he is correct. This is on a 2015 North American factory installed Trailer Tow Group. The brake lights also work with the ignition off (e.g. the emergency flashers work through to the trailer lights when the ignition is off).
Help! - Lost All Interior Lights - Where's the plug? skybuzz Electronics, Audio, and Lighting 4 12-24-2016 02:05 PM
Plug in Firewall zkmeeks93 Interior 6 04-29-2016 10:38 AM
OEM Hitch Plug Cherryville Electronics, Audio, and Lighting 5 06-24-2014 05:15 PM
7 round plug to 4 flat Wabbit Towing and the Towed 6 06-06-2014 08:03 AM
USB and 115v plug beaton172 2014+ Jeep Cherokee General Discussion 10 03-19-2014 09:47 PM
