Moving: Trailer vs Truck - Page 2 - 2014+ Jeep Cherokee Forums
 3Likes
post #11 of 11 (permalink) Old 03-07-2017, 09:07 AM
Actually the trailer itself is 900 lbs. That leaves you 1100 allowable load which is not much considering you can easily over load your Cherokee.
With the cost of renting the truck and towing your Cherokee it might not be worth it. Dolly towing with all four wheels off the pavement or flat towing it, which flat tow would require a dealer installed harness for the flat tow.
Many movers combine loads in order to fill the truck for long moves. If you are not in a hurry to receive your goods then a mover is the way to go.
Good luck
Moving to So Cal techguy505 Southern California 2 12-28-2016 11:40 AM
What goes down stairs (moving) Rojhan The JCC Lounge 2 12-03-2016 07:53 AM
Moving from LA to Denver EOTW TheTrailhawk Rocky Mountain 17 09-18-2016 07:45 AM
Moving On... WAHAWK 2014+ Jeep Cherokee General Discussion 13 05-20-2015 02:31 PM
Moving from CJ to trailhawk S2Scout New Member Introductions 4 08-17-2014 10:43 AM
