Rear mounted winch? - Page 2 - 2014+ Jeep Cherokee Forums
post #11 of 14 (permalink) Old 04-30-2017, 02:04 PM
Originally Posted by Renthorin View Post
Cool. With a remote...could you run it off a size 31 deep cycle in the hatch area?
Due to the amp draw of a winch you'd likely only get 5 minutes or less of use before the battery would be dead.
Fj4080 likes this.
Len1304 is online now
post #12 of 14 (permalink) Old 04-30-2017, 02:20 PM
Renthorin's Avatar
Ohhh I don't like that at all
Renthorin is offline
post #13 of 14 (permalink) Old 04-30-2017, 02:24 PM
The warn m8000 winch pulls almost 450amps at full pull.
The group 31 battery I have is 100ah, doing the math you'd likely get just over 10 minutes before the voltage dropped to a point of not being able to use it.
My starter battery is the same as everyone else and even with the engine running and idling at 3500rpm I've been able to stall the winch due to low voltage and believe me when I say if the voltage in the jeep drops below about 11.1v a LOT of stuff in the jeep stops working until restarted.
post #14 of 14 (permalink) Old 04-30-2017, 03:27 PM
Renthorin's Avatar
Mine is 115 ah do not much difference. I'll just have to find someone to go with me in case I get overly brave.
Rear Mounted Tire Carrier - Hitchgate Solo by Wilco Offroad RojStock Exterior 4 11-07-2016 05:20 PM
KO2s Mounted Jeep#2 Wheels, Tires, Brakes, and Suspension 9 08-11-2016 11:07 AM
Rear Mounted Tire kian3260 Exterior 12 07-22-2016 11:48 PM
Rear Winch - hitch mounted Warloq Exterior 13 02-27-2016 09:30 AM
