trailer brake controller - Page 3 - 2014+ Jeep Cherokee Forums
 33Likes
post #21 of 185 (permalink) Old 01-21-2014, 10:38 AM Thread Starter
I was looking at he cables online and think I may be wrong about the one that the Cherokee uses. I need to double check the plug and see. But I think it actually uses the Dodge pigtail and not the Jeep one.
John
Hudsonhawk is offline
post #22 of 185 (permalink) Old 01-21-2014, 11:49 AM
A little variation on the the theme.
I plan to use the Jeep wiring differently. I did this on another vehicle and it worked well.
I have hydraulic surge brakes on the trailer. It has a "backflow solenoid" that allows one to disable the trailer brakes with the solenoid. I hook the backup light lead to the solenoid so when backing up, the surge does not apply the brakes.
I also hook the brake signal wire to the solenoid, via a simple switch under the dash. I use this to manually disable the brakes when going down very long hills using engine braking. If you don't do this, the engine braking applies the surge brakes for a long time and they can overheat.
Its a Colorado thing. :-)
CurtWPk is offline
post #23 of 185 (permalink) Old 01-21-2014, 05:31 PM Thread Starter
Originally Posted by CDNTrailHawk View Post
From Chrysler's wiring diagram database: There is a 4-pin connector in the usual location above the driver's footwell. I haven't personally gone looking for it yet, but according to their info, it's there.
Does your source tell you what each of those pins is for?
John
post #24 of 185 (permalink) Old 01-21-2014, 08:54 PM
Pin /Function/Wire Color
1/ground/black
2/brake lamp switch output/wt-vt
3/electric brake feed/dg
4/fused b+/tn-rd
CDNTrailHawk is offline
post #25 of 185 (permalink) Old 01-21-2014, 09:09 PM Thread Starter
Thank you.
John
post #26 of 185 (permalink) Old 01-21-2014, 10:19 PM
I got a good look and picture of the plug under the dash.
It matches the one on the etrailer web site BUT it is the wrong gender !
http://www.etrailer.com/Accessories-...ady/22294.html
I suppose we could ask why in the world would they do that... but the more important question is... where can we find the right plug of the right gender ? ?
CurtWPk is offline
post #27 of 185 (permalink) Old 01-21-2014, 10:28 PM Thread Starter
I have been talking with tekonsha support. the correct plug would be on the 3021-p cable for the current rams. But the battery and trailer brake wires are swapped on the connector according to the pinouts you provided.
John
post #28 of 185 (permalink) Old 01-21-2014, 10:34 PM Thread Starter
So if we could get aRam pigtail we could splice that into whatever controller you wanted to use.
John
post #29 of 185 (permalink) Old 01-21-2014, 10:41 PM Thread Starter
I have the 3021-p cable on order. I will test the pinouts and see if the wires are swapped.
John
post #30 of 185 (permalink) Old 01-21-2014, 11:07 PM
I have to say... The 3021-p plug sure does not look like it would fit with the plug in the photo I took (above).
I have my fingers crossed that you receive the correct plug.
I am not concerned about the pin assignments - that is easy to change.
CurtWPk is offline
  LinkBacks (?)
LinkBack to this Thread: http://jeepcherokeeclub.com/337-towing-towed/4402-trailer-brake-controller.html
Posted By For Type Date
Trailer Brake Controller 2014 Jeep Grand Cherokee | Free Auto Repair Manuals Download This thread Refback 05-27-2014 09:51 PM
Aftermarket Trailer Hitches and Wiring 14KL Towing and the Towed 29 05-23-2016 08:36 AM
A question for new TrailHawk owners with Cold Weather and Trailer Tow groups... WJM Cherokee Purchasing and Orders 23 07-30-2014 05:16 PM
Trailer Tow Group rowkzz 2014+ Jeep Cherokee General Discussion 25 02-15-2014 12:18 AM
Tales of the Trailhawk - Trailer | Jeep® | Coming August 14th Richie 2014+ Jeep Cherokee General Discussion 21 09-19-2013 09:55 AM
