trailer brake controller - 2014+ Jeep Cherokee Forums
 33Likes
post #1 of 185 (permalink) Old 11-17-2013, 05:52 PM Thread Starter
So this is a little off-topic but I can't think of anywhere else to put it.
Has anyone figured out how to wire a electric brake controller into the Cherokee with the tow package? I figure there are some wires under the dash somewhere, but I have not found them yet.
John
Hudsonhawk is offline
post #2 of 185 (permalink) Old 11-17-2013, 09:16 PM
Banned
I'd be curious to know this too . . . .
Acidsnow is offline
post #3 of 185 (permalink) Old 11-18-2013, 11:03 AM
Erie-Eyes's Avatar
I'm not sure about the answer to your question John as I have surge brakes on my boat trailer. I always understood electrical brakes required the 7 pin connector and did not think anything else was required.
The following is what I discovered in the owners manual - hope it might help.
Towing Requirements – Trailer Lights And Wiring
Whenever you pull a trailer, regardless of the trailer size,
stoplights and turn signals on the trailer are required for
motoring safety.
The Trailer Tow Package may include a four- and sevenpin
wiring harness. Use a factory approved trailer harness
and connector.
NOTE: Do not cut or splice wiring into the vehicles
wiring harness.
The electrical connections are all complete to the vehicle
but you must mate the harness to a trailer connector.
Refer to the following illustrations.
Next illustrations in the manual show 4 & 7 pin connectors and wiring connections.
Bill
2014 Cherokee Trailhawk
White with Brown Interior
3.2 V-6
Trailer Tow
Cold weather
Teck package
Leather Interior
Comfort Convience
Erie-Eyes is offline
post #4 of 185 (permalink) Old 11-18-2013, 12:50 PM Thread Starter
Bill, thank you. but that does not discuss how to wire the brake controller. Normally they would prodvide 4 wires or a plug under the dash to hook the brake controler to. I could not find anything in the owner'a manual about it.
Electric brakes require a controller that actives the brakes on the trailer. This is not normally included on most vehicles.
John
post #5 of 185 (permalink) Old 01-19-2014, 05:32 PM
The grand cherokee has a plug under the dash for a controller. I assume the cherokee does too. I'll see if I can find it and let you know.
CurtWPk is offline
post #6 of 185 (permalink) Old 01-19-2014, 07:56 PM
My 06' Dodge Truck had a 4 wire connection behind the emergency brake. No splicing required. Proper pig tail was only $15.
wcjeep is offline
post #7 of 185 (permalink) Old 01-19-2014, 08:18 PM Thread Starter
Hopefully you will have better eyes than me. I have not been able to find one yet.
John
post #8 of 185 (permalink) Old 01-19-2014, 08:19 PM
From Chrysler's wiring diagram database: There is a 4-pin connector in the usual location above the driver's footwell. I haven't personally gone looking for it yet, but according to their info, it's there.
CDNTrailHawk is offline
post #9 of 185 (permalink) Old 01-19-2014, 08:25 PM Thread Starter
Thank you. That is the first diagram I have seen that pinpointed its location. I guess I need to go back under the dash and look for it again. Looks like it is at the end of the large wiring bundle in the driver footwell.
John
post #10 of 185 (permalink) Old 01-19-2014, 09:16 PM Thread Starter
Thanks to CDNTrailHawk I was able to find the plug for the harness tonight.
It is located behind the plastic kick panel in the drivers foot well.
You remove the screw and carefully pry the tab that is holding the kick panel in place from its bracket. The plug is on the firewall/wheel well behind the wiring. It is the grey plug you can see next to the metal bracket. That wire with the finned covering was in front of it and made it hard to find.
Acidsnow, CDNTrailHawk and eak like this.
John
  LinkBacks (?)
LinkBack to this Thread: http://jeepcherokeeclub.com/337-towing-towed/4402-trailer-brake-controller.html
Posted By For Type Date
Trailer Brake Controller 2014 Jeep Grand Cherokee | Free Auto Repair Manuals Download This thread Refback 05-27-2014 09:51 PM
Aftermarket Trailer Hitches and Wiring 14KL Towing and the Towed 29 05-23-2016 08:36 AM
A question for new TrailHawk owners with Cold Weather and Trailer Tow groups... WJM Cherokee Purchasing and Orders 23 07-30-2014 05:16 PM
Trailer Tow Group rowkzz 2014+ Jeep Cherokee General Discussion 25 02-15-2014 12:18 AM
Tales of the Trailhawk - Trailer | Jeep® | Coming August 14th Richie 2014+ Jeep Cherokee General Discussion 21 09-19-2013 09:55 AM
