Options - 2014+ Jeep Cherokee Forums
  • 1 Post By Leoconti
  • 1 Post By graphicswizard
post #1 of 9 (permalink) Old 11-25-2016, 10:05 AM Thread Starter
Hi there,
does anyone know if on a Cherokee Limited+ bought in Italy (2nd hand, Feb2015) should I get the heated wheel and the storage room under the passenger's seat? Thanx. Leo
Leoconti is offline
post #2 of 9 (permalink) Old 11-25-2016, 12:05 PM
graphicswizard's Avatar
Originally Posted by Leoconti View Post
Hi there,
We need more information about your Limited, but here are some hints. If your seats are leather and perforated (tiny holes all over), you have ventilated and heated seats. With this feature, there is no storage under the passenger seat, as that space is occupied by heating and ventilation equipment. If you have this feature, you probably have a heated steering wheel.
Do you have the large 8.4 uconnect screen? If so, tap on "Settings" in the bottom tool bar. In the screen that opens, you should see virtual buttons for heated and ventilated seats, plus a button for the heated wheel. On my screen, the heated wheel is on the left at the bottom.
Trailer Towing Package
graphicswizard is offline
post #3 of 9 (permalink) Old 11-26-2016, 07:48 AM
tbrou6229's Avatar
Do you know your vin number?
tbrou6229 is offline
post #4 of 9 (permalink) Old 11-26-2016, 08:47 AM
SJetc's Avatar
I have an export Limited albeit the wrong hemisphere but still an export. My vehicle has a build date of Sept 11 2014.
I have heated seats but not vented seats. In Australia, the vented seats and the heated wheel were an option combined into the 'Lux package' option in the early months subsequent to the launch of the vehicle (July 2014) and was quickly removed within, say 5 months of launch. No vented seats meant the 'flip 'n stow' seat instead - you cannot have both. As GW has already pointed out, the fans that control the vented air are stored below the passenger seat which use up the storage space.
So, Downunder, you had to be very quick and an early adopter to have the option to choose the 'Lux pack'. I ordered my KL in May 2014 but because I chose a CRD, I had to wait. At the time of ordering the Lux pack was available (vented seats, heated wheel) but by the time I took delivery (Nov 2014), that option was no longer available to Aust buyers.
You would need to use the VIN for the build sheet to get a definitive answer for that particular vehicle.
MY15 KL Limited CRD - True Blue ADII, Tech group, Electronics/Conv groups and Pano
MY14 Grand Cherokee Overland CRD - DCR ORAII
MY07 Grand Cherokee Limited 5.7 Hemi - Silver (Sold)
SJetc is offline
post #5 of 9 (permalink) Old 11-28-2016, 09:05 AM Thread Starter
Thanx everybody for your answers...
The VIN number is 1C4PJMDY1FW622146
Since you've been so kind, I have another couple of questions...
- the two lights on the power liftgate do turn on only with headlights on?
- is it normal that with a temp of about 5°C it doesn't open automatically?
and...
is there any (safe) method to test the "forward collision warning"?
Everytime I wonder if it's working... or not!
Thanks again!
Leo
Leoconti is offline
post #6 of 9 (permalink) Old 11-28-2016, 09:46 AM
and...
Thanks again!
Leo
Here's the content of your build sheet:
VIN 1C4PJMDY1FW622146
Vehicle Description 2015 JEEP CHEROKEE LIMITED 4X4 SPORT UTILITY 4-DOOR
STANDARD EQUIPMENT
* Monotone Paint
* 160 Amp Alternator
* Battery Run Down Protection
* Brake Stability Control
* Rr 60/40 Folding Split Recline Seat
* Vinyl Door Trim Panel
* 6-Way Manual Passenger Seat Adjust
* Front Seat Active Headrests
* Front Height Adjust Shoulder Belts
* Child Seat Anchor System-LATCH Ready
* Next Generation Front Air Bags**
* Drvr Inflatable Knee-Bolster Air Bag
* Jeep Rack Kit
* Supplemental Frt Seat Side Air Bags
* Supp. Side Curtain Frt/Rr Air Bags
* Cargo Net
* 8 Cargo Tie Down Loops
* Front & Rear Floor Mats
* Jeep Rack Cargo Management Sys
* Tonneau Cover
* Three Rear Seat Head Restraints
* Driver Seat Back Pocket
* Rr Seat Armrest w/Cupholder
* 3 Passenger Assist Handles
* Full Length Floor Console
* Media Center Electronics Storage
* Leather Wrapped Shift Knob
* Illuminated Front Cupholders
* Elec. Steering Column Shaft Lock
* 3.734 Final Drive Ratio
* Conventional Differential Rear Axle
* Rear Window Defroster
* Sliding Sun Visors w/Illum Mirrors
* RR View Auto Dim Mirror w/Microphone
* Keyless Entry
* Engine Immobilizer
* Air Cond ATC w/Dual Zone Control
* Cluster 7.0" TFT Color Display
* 240 KPH Primary Speedometer
* Tachometer
* Rear Window Wiper/Washer
* 12V Auxiliary Power Outlet
* 12V Cargo Power Outlet
* Locking Glove Box w/Damped Door
* Air Filtering
* Speed Sensitive Power Locks
* Heated Front Seats
* Power 8-Way Driver Seat
* Pwr Front Windows, 1-Touch,Up & Down
* Power Liftgate
* Illuminated Entry
* Front Passenger Seat Belt Alert
* LED Tail Lamps
* Vehicle Information Center
* 2 Frt O/Head Incandescent Map Lamps
* Rear Reading/Courtesy Lamps
* Ambient LED Interior Lighting
* Cargo Compartment Lamp
* Headlamp Off Time Delay
* LED Daytime Running Headlamps
* Fog and Cornering Lamps
* Rear Fog Lamps
* E-Marked Exterior Lighting
* Enhanced Accident Response System
* Accent/Body Color Fascias
* Black Headlamp Bezels
* Black Lower Dr Cladding
* Bright Day Light Opening Moldings
* Body Color Door Handles
* Body Color License Plate Brow
* Limited Badge
* Jeep Badge
* 4X4 Badge
* Bright Side Roof Rails
* Chrome Grille Surrounds
* Cherokee Badge
* Export Emissions
* 15.8 Gallons Fuel Tank
* Granite Crystal Met. Clear Coat
* Steering Wheel Mounted Audio Controls
* Body Color Shark Fin Antenna
* Electric Power Steering
* Leather Wrapped Steering Wheel
* Euro Suspension
* Tilt/Telescope Steering Column
* Delete Spare Tire
* 18X7.0 Polished Aluminum Wheels
* Selec-Terrain (TM) System
* ParkView(TM) Rear Back-up Camera
* Electric Park Brake
* Unique Export Fuel Tank
* Recovery/Ocean Tie-Down Eyes
* Front/Rear Climate Control Outlets
* Tire Pressure Monitoring Display
* Rear Seat Heat Ducts
* Power Locking Fuel Filler Door
* Premium Interior Accents
* Underbody Aerodynamic Treatment
* Steering Column Cover Parts Module
* Rear Spring Parts Module
* Rear Brake & Knuckle Parts Module
* Center Console Parts Module
* Front Fascias Parts Module
* Front Brake & Knuckle Parts Module
* Headliner Parts Module
* Seat Parts Module
* Instrument Panel Parts Module
* Door Parts Module
* Front End Parts Module
* Tire & Wheel Parts Module
* Front Suspension Damper Parts Module
* Build To Export Mkt. Specifications
* GVW Rating - 5500#
* EMEA Region ROW
* Zone 06-Export
* KL/5753 Vehicle Family
* Four Wheel Drive (4WD)/(4X4)
* Left Hand Drive (LHD)
* 2015 Vehicle Specifications
* Vehicle Order Tracking
OPTIONAL EQUIPMENT
* Premium Leather Trimmed Bucket Seats
* Black
* European Equipment Group
* Technology Group
* Electronics Convenience Group
* Luxury Group
* 2.0L Diesel Robustness Pkg Delete
* Smoker's Group
* 700 Amp Maintenance Free Battery
* Advanced Brake Assist
* Hill Start Assist
* All Speed Traction Control
* Electronic Roll Mitigation
* Trailer Sway Damping
* Anti-Lock 4-Wheel Disc HD Brakes
* Ventilated Front Seats
* Frt Pass Forward Fold Flat Seat
* Removable Ash Tray
* Overhead Console
* Lock On Sync Tire Press Sensor
* All Automatic Transmissions
* Electronic Range Select
* 9-Spd 948TE FWD/AWD Auto Trans (Make
* Jeep Active Drive I
* 2.0L I4 Turbo Diesel Engine
* Acoustic Windshield
* Acoustic Laminated Front Door Glass
* Deep Tint Sunscreen Glass
* Power Multi-Function F/Away Mirrors
* Full Sunroof, Pwr Frt, Fixed Rear
* Remote Proximity Keyless Entry
* Passive Entry / Keyless Go
* Premium Insulation Group
* Temperature & Compass Gauge
* Rain Sensitive Windshield Wipers
* Headlamp Washer
* Cigar Lighter
* Automatic Headlamp Leveling System
* 230V/50Hz Auxiliary Power Outlet
* GPS Navigation
* GPS Antenna Input
* Premium Air Filter
* Power 4-Way Driver Lumbar Adjust
* Lane Departure Warning Plus
* Rear Passenger Seat Belt Alert
* Adaptive Rear Brake Lights
* Glove Box Lamp
* Ext. Mirrors w/Supplemental Signals
* Exterior Mirrors Courtesy Lamps
* Exterior Mirrors w/Memory
* Body Color Exterior Mirrors
* Power-Folding Mirrors
* Radio/Drvr Seat/Ext Mirrors Memory
* Accessory Switch Bank Module
* Automatic Headlamps
* Bi-Xenon HID Headlamps
* Auto High Beam Headlamp Control
* Security Alarm
* Full Speed Fwd Collision Warn Plus
* Front License Plate Bracket
* Diesel Badge
* Euro Stage 5 Emissions w/EOBD 5
* Dual Bright Exhaust Tips
* Auxiliary Transmission Oil Cooler
* Exterior Mirrors w/Heating Element
* Passive Speed Limiting Device
* Adaptive Cruise Control w/Stop & Go
* 170HP Diesel Power Rating
* All Radio Equipped Vehicles
* 9 Amplified Speakers w/Subwoofer
* Phase Diversity Antenna
* 8.4" Touchscreen Display
* Wireless Charging Pad
* Uconnect 8.4 NAV
* Harman Radio Manufacturer
* Single Disc Remote CD Player
* Audio Jack Input for Mobile Devices
* Remote USB Port
* Remote SD Card Slot
* USB Port in Media Center
* Digital Audio Broadcasting
* All VP4 Radios
* 225/55R18 BSW 3-Season Tires
* Michelin Brand Tires
* All Aluminum Wheels
* Blind Spot and Cross Path Detection
* Tip Start
* Stop-Start Multiple VSM System
* Diesel Particulate Filter (DPF)
* R1234YF A/C Refrigerant
* Tire Service Kit
* Parallel & Perp Park Assist w/Stop
* Jeep Call Assistance Label
* ECE Specifications
* Passive Pedestrian Protection
* Italian Language
* Integrated Voice Command w/Bluetooth
* Humidity Sensor
* All Parksense Systems
* 2 Additional Gallons of Diesel Fuel
* Spring - Left Rear
* Spring - Left Front
* Spring - Right Rear
* Spring - Right Front
* FAM: KL TRACKING: 40620S04 MY:2015
* Customer Preferred Package 2TG
* Customer Preferred Package 28G
* Intl. Price Protection B
* Coso Wt. & D.M.
* Market Homologation
* Export Ocean Freight
* Export Insurance
* FIAT Alignment ISP Tracking
* 1NTL 37 DAY SCHEDULE
* FIAT Warranty Tracking
* Sold Vehicle
* Special Scheduling Condition III
* Delete Domestic Warranty Manual
* Export Option Requirements
* Certificate of Conformance
* European E Mark Label
* Manufacturer Body Plate
* Italy Country Code
* FIAT EMEA Distribution Tracking
* Western Europe Region Group
* EMEA Region (Europe)
post #7 of 9 (permalink) Old 12-01-2016, 06:52 AM Thread Starter
Great! Thank you!
Leoconti is offline
post #8 of 9 (permalink) Old 12-05-2016, 10:16 AM
tbrou6229's Avatar
Hi there,
There has been a post here to find your build sheet; here is a website to find your window sticker. Maybe this will be useful.
http://researchmaniacs.com/VIN-Numbe...cker/Jeep.html
Put in your VIN, click lookup, then scroll down near the bottom and it will be there in a PDF Form
~Mods List~ (In Progress!)
The First Family Member...
See HERE for Mod List!
post #9 of 9 (permalink) Old 01-04-2017, 10:54 AM
Softsand's Avatar
BTW. We didn't get the heated steering wheel in Australia. I did order the Luxury package (and waited some time for it !) for the seats.
It wasn't publicised but it did also include dipping exterior mirrors on reverse (use this daily !) as well as memory seats so that was a win.
MY15 Cherokee Limited ADII Auto Diesel with factory Trailer, Park Assist, Safety, Security and Comfort Groups. Added options of Tech, Electronic Convenience and Luxury Groups. Jeep cargo mat. Mods of XXR530 18x7.5 Black Chrome wheels with 235/55 KL15 tyres, front tint and Blackvue dashcam - Delivered February 2015.
Photos: https://www.flickr.com/photos/130331123@N08/
Softsand is offline
Options you wish you had! Options you wish you didn't have! Duke2015 2014+ Jeep Cherokee General Discussion 78 12-03-2016 03:33 PM
What options do you wish you had? tjarget 2014+ Jeep Cherokee General Discussion 41 10-21-2015 06:32 AM
Safety options help gorgon 2014+ Jeep Cherokee General Discussion 0 05-13-2015 04:21 PM
Tire Options joe1823 Wheels, Tires, Brakes, and Suspension 17 05-14-2014 11:45 PM
Headlight Options? Aggie Sheepdog 2014+ Jeep Cherokee General Discussion 14 10-22-2013 09:43 PM
