Get more power with K&N Intake Systems - Page 3 - 2014+ Jeep Cherokee Forums
 4Likes
post #21 of 24 (permalink) Old 11-03-2015, 03:24 PM
JKL
Torque is lower too, right when you need it the most, off the line between 2500 and 3000 RPM.
I always try to redline it when I pull away from the stoplights. I love hearing the screams coming from the engine bay on my I4.
JKL is offline
post #22 of 24 (permalink) Old 11-03-2015, 06:16 PM
'05Train's Avatar
Originally Posted by Tyler-98-W68 View Post
OK so then can someone please explain to me why my mileage went up AFTER my intake..............it didn't go down and it didn't stay the same.........so something must have happened. Probably magic
I just explained it. Twice. You've added air that your engine doesn't need and that the ECM can't compensate for, so you're running leaner than you should and leaner than can be compensated for. So you're seeing better mileage at the cost of power. It probably isn't lean enough to hurt anything.
Without a controlled test you can't isolate the intake as the cause of your improved mileage, but if you want to "credit" the intake, what I've described is the only way possible.
2015 Trailhawk - Mango Tango, V6, Nav, Vented Seats, Big Honkin' Sunroof
Miss you too Montanan......
'05Train is offline
post #23 of 24 (permalink) Old 11-03-2015, 07:35 PM
Tyler-98-W68's Avatar
Fair enough, I run heavier than stock tires, weigh more, yet i'm getting better mileage than when I was stock, so something is at play.
2016 Cherokee Trailhawk V6
Rhino
AFE Intake
Flowmaster Super 10 Muffler
Noco Onboard Charger
Trailer Tow
Sunroof
Nav & 9 Amplified Speakers
White
RPM Motorsports Torque Tube
TH Wheels
Trailer Tow
Luxury Package
Technology Package
Sunroof
LED Fog Lights
Tyler-98-W68 is offline
post #24 of 24 (permalink) Old 11-03-2015, 07:53 PM
'05Train's Avatar
BTW, if you're not hand-calculating your mileage (or using an app like Fuelly), you don't have a good picture of what your mileage is. Using the dash display is like playing darts in the dark. My Fuelly mileage has been both over and under what's displayed, and there's no consistent difference in the gauge and the actual mileage.
'05Train is offline
Let's talk about exhaust systems CARiD Engine and Technical Discussion 21 06-04-2016 11:31 AM
K&N intake & filters finally chanco Southern California 9 06-30-2015 10:35 AM
aFe Power 2014 Jeep Cherokee V6-3.2L Stage-2 Air Intake System Install (54-12462) citation10337 Engine and Technical Discussion 10 10-22-2014 05:45 PM
NEW Putco Luminix High Power LED Fog Lights - Available for Wrangler JK & More! XenonDepot XenonDepot 4 07-30-2014 02:50 PM
