TMC (Traffic Message Channel) - 2014+ Jeep Cherokee Forums
  • 1 Post By Array
  • 1 Post By Toy
post #1 of 5 (permalink) Old 04-19-2015, 04:36 PM Thread Starter
How To Use TMC in Uconnect
The purpose of this thread is to provide a place for members to describe how TMC actually works in Uconnect. Members that use TMC a lot and experiment in congested areas will probably be able to contribute the most. My (this) post will cover what I’ve found so far. For those that don't want to read this whole post, here is a description from someone that uses it; BlckWK2 from Metro Detroit posted this on Jeep Forum in February 2015:
You can adjust how the traffic will be alerted/routed when an incident occurs. It is in the NAVIGATION MAIN MENU --> SETTINGS --> MAP GUIDANCE --> TMC ROUTE -->
Options include:
– Automatic: No black pop up window, reroutes automatically
– By Delay Time: Setup specific delay time on main route. If set at 5 min, your route is rerouted if traffic issues cause more than a 5 min delay (automatically)
– Manual: Black pop up window and lets user decide what to do
– Off: No rerouting due to traffic incidents
I have a long commute to work and mainly highway through the Metro Detroit area. Lots of different traffic issues so I use my NAV a lot! I usually keep it on automatic. If you do this make sure you have the navigation guidance volume turned on. There were plenty times where I have the guidance volume off and totally don't see the new route if it automatically changed.
The thread starts at: http://www.jeepforum.com/forum/f309/.../#post28166609
What is TMC?
Traffic Message Channel (TMC) is a technology for delivering traffic and travel information to motor vehicle drivers. It is digitally coded and carried via conventional FM radio broadcasts, transmitted on Digital Audio Broadcasting, or satellite radio. In the United States of America, XM Satellite Radio and Sirius Satellite Radio provide TMC service all over the US. Navteq provides traffic data to both providers. Sources of traffic information typically include police, traffic control centers, camera systems, traffic speed detectors, floating car data, winter driving reports and roadwork reports.
Each traffic incident is encoded and sent as a TMC message. Each message consists of an event code, location code, expected incident duration, affected extent and other details. The message contains a list of up to 2048 event phrases that can be translated by the receiver into the user's language. Some phrases describe individual situations such as a crash, while others cover combinations of events such as construction causing long delays.
More info at http://en.wikipedia.org/wiki/Traffic_message_channel
Uconnect Help – No Help
The Uconnect manual does not describe how TMC settings affect routing, other than what can be derived from the option names such as: Automatic, By Delay Time, Manual, and Off. Called Uconnect and they said to call Sirius XM. Called Sirius XM and they said to call Uconnect because all that SXM does is transmit the data provided by Navteq. Sent an email to Uconnect and in it also asked if there was a contact at Garmin I could communicate with since Garmin provides the navigation routing software used in Uconnect. Uconnect refused to provide any further information other than repeating to call SXM or talk to the dealer.
TMC Settings in Uconnect
TMC Incidents – From the Nav Home Screen: Settings/Map Setup/TMC Incidents
Press this button on the touchscreen to show Traffic
Message Channel (TMC) Incidents while in Map View.
Speed and Flow – (8.4AN only) From the Nav Home Screen: Settings/Map Setup/Speed and Flow
Press this button on the touchscreen to show the Speed
and Flow of traffic while in Map View.
Play Voice Guidance Prompts - From the Nav Home Screen: Settings/Map Setup/ Play Voice Guidance Prompts
Press this button on the touchscreen to enable Voice
Guidance Prompts during route guidance.
TMC Route Mode - From the Nav Home Screen: Settings/Map Setup/TMC Route Mode
Press this button on the touchscreen to change how the
Traffic Message Channel (TMC) Route Mode functions
- Automatic
- By Delay Time
- Manual
- Off
TMC Avoidance Types - From the Nav Home Screen: Settings/Map Setup/TMC Avoidance Types
Press this button on the touchscreen to display the
available TMC Avoidance Types you would like displayed while in route guidance.
- Traffic Flow
- Accident
- Closures
- Lane Restriction
- Other
How To View Traffic Events in a List
From the Nav Home Screen: Information/Traffic
Lists traffic events in the surrounding area. During route guidance, touch the ROUTE tab to see only events along the route.
How To View Traffic Events in Map View - Make sure TMC Incidents is turned on
Touch a traffic icon (typically a diamond shaped caution sign) when it appears on the map in Map View. Touch the note icon that appears in the upper right of the screen. A black screen pops up with a description of the traffic event. Select the Info tab for more information about that traffic event.
shemmar360 likes this.
post #2 of 5 (permalink) Old 05-01-2015, 04:14 PM
Toy
Toy's Avatar
One more thing about TMC on uConnect, but I don't know, if it's relevant for USA/Kanada.
UConnect only supports free basic TMC. Here in Europe, we also have a more reliable and faster TMCpro service, which is likely standard on most European cars with GPS-Navigation. TMCpro is not free, GPS/Nav manufacturers have to buy a license for every single unit they make. But, as I said, uConnect does not support TMCpro.
Array likes this.
German Cherokee KL and Renegade BU Forum
http://www.new-jeep-forum.de
Toy is offline
post #3 of 5 (permalink) Old 05-22-2015, 06:03 PM
@Array, My impression of TMC in the 8.4AN is that it uses the SiriusXM NavTraffic information as "TMC" rather than the FM data channel. Does the 8.4a have such a feature?
ekmeister is offline
post #4 of 5 (permalink) Old 06-14-2015, 09:56 PM Thread Starter
Must have missed the notification you posted to this thread in May. I was probably on the road at the time.
I believe your impression is correct from what I've read and heard. When I called SiriusXM, they said they get the traffic data from Navteq and SiriusXM broadcasts it across the US.
According to the user manual, one of the distinguishing features between the 8.4AN and the 8.4A is traffic data.
The 8.4AN sets itself apart by offering these unique
features:
• HD Radio
• Navigation Standard
• One-shot destination entry
• 3D content (Select this option and zoom to an appropriate
level. Not all “tall” buildings are in 3D)
• Enhanced Digital Terrain Model (DTM)
• SiriusXM Traffic
• SiriusXM Travel Link
post #5 of 5 (permalink) Old 08-05-2016, 03:35 PM
Thumbs down Totally Useless for Canadians
I have a Garmin Nuvi that I bought for about $100.00. It has some great features that include traffic avoidance. This feature suggests alternate routes if there are traffic or construction issues on my planned route. This feature was just part of the package.
Enter my 8.4 Garmin Uconnect Nav that I paid almost $700.00 for. You would think that since the $100.00 Garmin has the traffic avoidances as part of the product, something that you pay $700.00 for would have it as well.
If that is what you think, especially if you live in Canada, you are mistaken. In order to get the traffic avoidance feature working on your 8.4 Garmin Uconnect, you need a Sirius XM subscription. This subscription somehow allows you to recieve traffic and weather reports so that you can plan your route accordingly . . . but only in the US.
Who the heck though of this brilliant plan? Why not include the traffic avoidance feature in with the Garmin?
Is this a hard thing for the folks at MOPAR to make happen?
I for one am dissapointed that I paid so much for so little.
Iwanttrafficavoidance is offline
What should the TMC setting be? Cherryville 2014+ Jeep Cherokee General Discussion 11 04-05-2015 02:19 PM
Sirius XM Channel 147 - Holiday Traditions atl_runner 2014+ Jeep Cherokee General Discussion 7 01-19-2015 08:30 PM
Ra3 8.4a NAV traffic?? bjdjr Electronics, Audio, and Lighting 7 12-01-2014 08:53 PM
How do you turn off traffic warnings?! codywater Electronics, Audio, and Lighting 7 10-02-2014 07:40 AM
Flashed by oncoming traffic toledo91 Electronics, Audio, and Lighting 43 09-21-2014 12:44 AM
