LED front lights with fog lights, ILLEGAL? - 2014+ Jeep Cherokee Forums
 13Likes
post #1 of 20 (permalink) Old 01-17-2015, 12:07 PM Thread Starter
I got pulled over on my way to work this morning for having my fog lights on when i shouldnt have had them on. My mistake, forgot i left them on last night when it was very foggy. Anyway the officer told me i wasnt allowed to run the fog lights, because with the stock LED running lights the Jeep projects 6 forward lights. I have been searching Oregon lighting laws and so far have not been able to find anything that limits the number of lights but i am curious if anyone knows the Candle Power or lumens of the LED lights, because there are some rules about candle power, i would like to legally be able to use the fog lights as we get fog in my area this time of year alot.
crashncam400 is offline
post #2 of 20 (permalink) Old 01-17-2015, 12:15 PM
DZOnline's Avatar
Although time consuming, here in California you can go to court vs paying the ticket. Simply argue the car is legally sold in Oregon and this is a stock vehicle. It's not that you didn't know (ignorance of the law is never an excuse) but the vehicle was purchased legally.
UN4GTBL likes this.
My Overland Journey
Instagram
Facebook
DZOnline is offline
post #3 of 20 (permalink) Old 01-17-2015, 01:45 PM
It's a DOT(Department of Transportation) law about four forward facing headlights. Our Jeeps would not operate with all six lights on if it is in violation of the DOT regulation. My last car had four forward headlights and fog's, physically couldn't have brights+low+fog on at same time and some owners were trying to defeat the mechanics.
You will also see your DDL turning off during the day with turn signal on, another DOT reg.
UN4GTBL, jim_87 and roarkrd like this.
GCWIMMER is offline
post #4 of 20 (permalink) Old 01-17-2015, 02:02 PM
davidevo50's Avatar
An other thing, I noticed the running day lights dim when you turn on the head lights... I guess to keep the light output power down to not disturb oncomming traffic...
White 4 cyl Trailhawk
leather
cold weather group
back up camera
navigation
Mopar rockrails
245/70-17 Destination MTs when in the trails
davidevo50 is offline
post #5 of 20 (permalink) Old 01-17-2015, 02:52 PM
Found this for Washington
http://www.komonews.com/traffic/jam/34276309.html
2014 Latitude Deep Cherry Red.....
3.2L V6 AD1
Towing Group
Uconnect® 8.4A
Backup Camera
Build 5/31/14
chartle is offline
post #6 of 20 (permalink) Old 01-17-2015, 03:04 PM
Originally Posted by chartle View Post
Wow, I never heard of that. I assume that means that some of the other states have similar rules. So Chrysler didn't know that when they designed the lighting on the Cherokee? That's really difficult to believe. There must be more to do with this that we don't know about.
Granite TH Build Date November 2013
All options except hood decal
Cherokeedude59 is offline
post #7 of 20 (permalink) Old 01-17-2015, 03:12 PM
States can regulate beyond Federal, look at CA smog, Cherokee meets Federal standards.
GCWIMMER is offline
post #8 of 20 (permalink) Old 01-17-2015, 03:22 PM
No.
The daytime running lights are regular running lights when the headlights are on.
They are not considered headlamps or fog lamps (as they do not illuminate the road for the driver), so there are only 4 “lights" on at once.
UN4GTBL and BizzyB like this.
ChrisCA is offline
post #9 of 20 (permalink) Old 01-17-2015, 03:27 PM
In PA you can't have your fog lights on with high beams. and this.
(l) Auxiliary driving lamps and fog lamps. Auxiliary driving lamps and fog lamps may be installed on a passenger vehicle or light truck if the lamps comply with the following:
(1) Auxiliary driving lamps shall not be substituted for headlamps. Auxiliary driving lamps may only be used with high headlamp beams.
(2) Fog lamps may not be substituted for headlamps.
(3) Auxiliary driving lamps and fog lamps shall be mounted on the front, spaced at least 20 inches apart from center to center and at height not more than 42 inches above level surface upon which the vehicle stands nor lower than the lowest chassis part. Rear fog lamps, if originally installed or offered as optional equipment, are acceptable.
(4) Auxiliary driving lamps and fog lamps shall be aimed when the vehicle and lamp assembly are in the straight ahead position with the beam not above horizontal centerline of lamp at 25 feet.
(5) A vehicle specified under this subchapter may have only one pair of approved auxiliary driving lamps and fog lamps.
(6) Auxiliary driving lamps and fog lamps shall not be placed in front of a required lamp.
I don't think the DTR are auxiliary driving lights. I think they are talking more about something that would be on a light bar. Which can't be used on the road.
3.2L V6 AD1
Towing Group
Uconnect® 8.4A
Backup Camera
Build 5/31/14
chartle is offline
post #10 of 20 (permalink) Old 01-17-2015, 03:32 PM
Seems like Oregon just has major issues with fog lights.
https://www.google.com/search?q=Oreg...+fog+light+law
Just checking a few links it basically says don't use them period.
3.2L V6 AD1
Towing Group
Uconnect® 8.4A
Backup Camera
Build 5/31/14
chartle is offline
LED Fog Lights Installed CDNTrailHawk Electronics, Audio, and Lighting 458 05-02-2016 08:51 PM
Which LED's are people running for fog lights? JoeTHcherokee Electronics, Audio, and Lighting 16 10-16-2014 07:09 PM
NEW Putco Luminix High Power LED Fog Lights - Available for Wrangler JK & More! XenonDepot XenonDepot 4 07-30-2014 02:50 PM
