Newbie Question - Transmission while braking? - Page 4 - 2014+ Jeep Cherokee Forums
 6Likes
post #31 of 33 (permalink) Old 04-10-2015, 01:26 PM
Pondhopper's Avatar
@Geaux - If you're referring to the 5-4 downshift, then it's the normal rev match the drivetrain does to engage the dog clutch. This article might help --> http://www.thetruthaboutcars.com/201...-on-the-leash/.
That was a great article and explains alot. It reminds me of driving without using a clutch where you match engine and transmission speeds to shift. it is easy to up shift but a lot more tricky to down shift. As speeds match the breaking force of the engine is reduced to engage the gear and then the braking force is reapplied it feels like you are speeding up when it is just a variation of engine braking force. if you experience an actual increase in speed then something is wrong. This also explains the delay in downshift delay for acceleration from a driveway to street traffic.
Array likes this.
Pondhopper is offline
post #32 of 33 (permalink) Old 04-10-2015, 02:04 PM
Originally Posted by Bill P View Post
I have a 2014 Limited with the four cylinder engine. I have the same issue. I put the Jeep into neutral while going down a steep hill. The reves went way up upon entering "N" and the vehicle sped up considerably. When I engaged the transmission by putting it into "D" the revs went up again dramatically and the vehicle slowed down - all without touching the brakes. I should add the Jeep was going 80 kms/h when I tried this - no other traffic present. The car freewheeled about 1 Km when I engaged "D".In all other cars I've had, the car will accelerate while going down a hill in "D", as if you put in the clutch with a standard transmission. The Jeep doesn't. Neither good or bad thing, I guess it is a Jeep thing.
From Owners manual:
CAUTION!
Towing the vehicle, coasting, or driving for any other reason with the transmission in NEUTRAL can cause severe transmission damage.
Most automatic transmissions do not have pumps that cool/lubricate while the trans is in neutral. A few do, like the older Honda CR-V, where it can be moved in neutral below 65 mph and with other provisions. Coasting in neutral with the 9-speed is a big no-no for a number of reasons to include its small form factor and concerns already addressed on this forum about over heating the tranny.
<<I put the Jeep into neutral while going down a steep hill. The reves went way up upon entering "N" and the vehicle sped up considerably.>>
The system is not designed for coasting in neutral. When you put it in neutral, the load was unexpectedly removed from the engine and it revved as a result. The vehicle sped up considerably because it's in neutral. It's called gravity.
<<When I engaged the transmission by putting it into "D" the revs went up again dramatically and the vehicle slowed down - all without touching the brakes.>>
The engine had settled into idle state, and then you engaged the transmission again. The revs went up because the wheels and other parts of the driveline drug it up there. Again, the system is not designed for this. Lord knows what gear it tried to shift into at that speed. Then it slowed down as it should. It's called engine breaking.
It's posts like this that make me wonder if, in some cases (not all), it's the driver that's ruining these transmissions.
NScherry and Pondhopper like this.
post #33 of 33 (permalink) Old 04-10-2015, 06:02 PM
NScherry's Avatar
At 44 yrs, you probably drove a stick somewhere along the way. Did you ever goose the engine when letting the clutch out on a downshift from 3-2 or 2-1 to smooth out the shift?
The first time I saw this rev-match in an automatic is when I drove my son's Infinity. Thought it was cool the computer could goose the engine more precisely than I did with a stick shift.
Yes, did that quite frequently with my 79 TA 6.6, 84 TA 5.0 HO, 5.0 Stang LX, and my Jeep Comanche, all were 5-speed sticks.
Array likes this.
NScherry is offline
Transmission Question - Newbie droo5757 2014+ Jeep Cherokee General Discussion 22 08-06-2015 09:20 PM
Transmission question 68birdls6 Engine and Technical Discussion 7 07-25-2014 03:27 PM
Different Transmission question wwoods 2014+ Jeep Cherokee General Discussion 1 06-23-2014 06:45 PM
Transmission tsb question jsarratt Engine and Technical Discussion 2 06-15-2014 02:48 AM
Transmission Question JRSJEEP Engine and Technical Discussion 1 03-04-2014 06:56 PM
