heater not maintaining temp (my story so far) - Page 3 - 2014+ Jeep Cherokee Forums
 34Likes
post #21 of 71 (permalink) Old 02-25-2016, 06:53 PM Thread Starter
osirisdean's Avatar
disappointing update: i am back to square one. replacing the AC Control Head DOES NOT WORK. details:
car parked outside all day
57 degrees outside
hopped in car to commute home, set temp to 70
car pumped warm air
after a while, air started getting cold again
even cranking up to 78 degrees and fan on speed 4, still pumping out cool/cold air
all interstate driving, very little change in speed, for what it's worth
here's a weird thing i noticed, though: when i exited the interstate and stopped at a light, the auto-turn-the-engine-off feature turned the car off. and *immediately* the heat kicked on. had me sweating in seconds. (still set to 78, no changes done by me.) it's as if cycling power to the car reset the temperature gauge or something.
ugh. im pretty disappointed im going to have to reopen this star case. thermostats are *not* that complicated, so i have no idea why chrysler cant get it right.
Array likes this.
build date: november, 2014
osirisdean is offline
post #22 of 71 (permalink) Old 02-25-2016, 08:47 PM
And here I thought it was just me. I have pretty much resigned myself to the fact that the transmission will NEVER be fixed, and now this. I'm only noticing mine because normally my work commute was 5 minutes at the most. I have a new job and the commute is now 45 minutes...that makes a lot of difference when the outside temp is below freezing and your vehicle thinks you've set your temp to 72 for the **** of it. Cranking it to 76 or above usually only helps for a short time, and then here comes the ice cold air again. How hard is it for engineers to get their crap together? We pay too much for these vehicles for them to not work properly. My previous vehicle was a 2008 Camry SE, so apparently I have a knack for this and wish I didn't.
osirisdean likes this.
paluma0268 is offline
post #23 of 71 (permalink) Old 02-25-2016, 10:57 PM
Originally Posted by osirisdean View Post
disappointing update: i am back to square one. replacing the AC Control Head DOES NOT WORK. .... im pretty disappointed im going to have to reopen this star case. thermostats are *not* that complicated, so i have no idea why chrysler cant get it right.
Thanks for the feedback. There is definitely something wrong. Appreciate you reopening the star case. With your persistence maybe FCA will figure out what's wrong and we'll all benefit through a TSB.
post #24 of 71 (permalink) Old 02-25-2016, 11:01 PM Thread Starter
osirisdean's Avatar
my wife confirmed it when we went out to dinner this evening. set to 73, it blew hot for about 10 minutes before starting to blow cooler air again. i am not a happy camper.
yeah, tomorrow i plan on reopening the case. there's no excuse for this, and i say that as an engineer. my wife's 10 year old ford edge can maintain temperature (with the same type of numerical temperature settings), there's no reason a year old car with brand new parts shouldn't be able to.
post #25 of 71 (permalink) Old 02-26-2016, 01:29 AM
Something's screwy about it. Cold outside and the temp is set to 72° F and then the AC comes on with zero heat mixed in??? Happens to us all the time. I'm guessing it's a program bug. You know, what worries me is it's cold in Auburn Hills, Michigan and there are tons of these KLs running around headquarters. Wouldn't you think by now that some upper management types would be mad and have it fixed by now?
post #26 of 71 (permalink) Old 02-26-2016, 09:02 AM Thread Starter
osirisdean's Avatar
generally speaking, when i first get in and turn it on (and have the temp set somewhere between 70 and 73), the jeep will crank warm air. it'll start as warm, then once I hit the interstate (less than a mile from my house), it'll get a little warmer.
then, 15~20 minutes of interstate driving later, it is pumping out very noticeably cooler air. sometimes lukewarm, often cool, sometimes wtf-it's-50-outside-and-my-heat-is-cranked-to-75-why-am-i-shivering-in-my-car cool air.
i agree, it has to be either a programming bug or a problem with the cabin thermometer. (and i don't think it's the latter, but i cant articulate my reasoning well just yet..)
post #27 of 71 (permalink) Old 02-26-2016, 09:19 AM Thread Starter
osirisdean's Avatar
previous case (#28641983, for what it's worth) hadn't been closed, i guess since it's only been a couple weeks. so they are going to escalate it to case management again, and i'll be contacted within the next couple business days.
here we go again. :/
(at least Chrysler seems interested in helping, i will give them that.)
post #28 of 71 (permalink) Old 02-26-2016, 10:54 AM
Another thing...
Don't know if yours is the same, but mine works fine when it's warm out. This is the second winter it's been doing this. So it is a problem that existed from the start.
SDBio likes this.
post #29 of 71 (permalink) Old 02-27-2016, 10:53 AM Thread Starter
osirisdean's Avatar
Another thing...
yeah, i dont recall ever being annoyed with it in the summer, seems to pump cold air just fine.
post #30 of 71 (permalink) Old 03-01-2016, 02:50 PM Thread Starter
osirisdean's Avatar
minor update: spoke with new case manager, who told me to take the jeep back to the dealership for more troubleshooting. i asked if there was anything Chrysler could research on their end without a trip to the dealership (not that i don't want to bring it back; i just don't know what they'll find that they couldn't find the first time around), but he said all they can do is have me bring it in and tool around on it some more.
jeep returns to the dealership tomorrow afternoon.
at least he (star case manager) agreed that Chrysler will cover the cost of my rental again.
A heartwarming story Craigman TH 2014+ Jeep Cherokee General Discussion 9 11-19-2015 11:45 PM
An All-Too-Familiar Story SoCal Bob Transmission Discussion 3 03-29-2015 02:07 PM
Tranny Temp and Coolant temp not showing up on guage JTBOkee 2014+ Jeep Cherokee General Discussion 1 01-22-2015 01:46 PM
Great Story Here zzjdzz The JCC Lounge 6 06-11-2014 01:52 PM
Funny Story NorthCoastie 2014+ Jeep Cherokee General Discussion 2 02-27-2014 08:51 PM
