Receiver hitch questions - Page 5 - 2014+ Jeep Cherokee Forums
 38Likes
post #41 of 48 (permalink) Old 10-20-2016, 11:46 AM
Originally Posted by 007 View Post
I agree! Labor should be a LOT less if they're only doing the hitch w/o wiring. From what I've heard, the wiring harness is very time-consuming to install.
The hitch alone can be installed in less than an hour. The body shop that installed mine (the third time) did it very quickly.
007 likes this.
post #42 of 48 (permalink) Old 10-20-2016, 07:43 PM
Originally Posted by firedude View Post
Wow that's weird they didn't include or claimed to know about the harness? You can see in my original post which includes the response from my dealer that they listed the wiring harness, the same one @josh6025 mentions. Mine will be installed Nov 1st.
On your install I have a question. Did they use your stock Latitude bumper? I "believe" they cut out the bumper and there is a facia plate that goes over/around the hitch. This also includes the area of the wiring harness -plug. Can you post a pic of your bumper and the hitch? Would give me a better idea. There was no mention by my dealer of needing a different bumper so I'm curious. Thanks.
Here are the pictures of my install. Hole was cut and bezel installed. @007 @firedude
ID:	139209   Click image for larger version
007 likes this.
CherokeeChief2016 is offline
post #43 of 48 (permalink) Old 10-20-2016, 07:56 PM Thread Starter
firedude's Avatar
Thanks @CherokeeChief2016 it does look nice. I'm happy with my choice if it looks that good. Thanks for the pics! Good luck on your wiring harness issue!
CherokeeChief2016 likes this.
Tony
Retired Fire Captain spending retirement in the Sierra Nevada mountains of Central Calif. Re-energized Jeep fan.
2016 Jeep Latitude 3.2 Liter V6 4x4
OEM Hitch & Wiring Harness
MoPar Slush Mats
firedude is offline
post #44 of 48 (permalink) Old 10-22-2016, 02:13 PM
007
007's Avatar
Yes, thanks for sharing! It looks way better than I thought it would, based on looking at the installation instructions. I may have to have that done at some point.
The BEAST
2014 Cherokee Latitude
Build date: 07/09/2014
In Service Date: 09/02/2014
My purchase date: 7/29/2016
Altitude Pkg
Comfort/Convenience Group
FWD
Uconnect 8.4A
3.2L V6
007 is offline
post #45 of 48 (permalink) Old 11-03-2016, 10:18 AM
kylepezz's Avatar
Actually I use a 10" drop on my 4x8 utility trailer . It could be a little more but once I load, even a moderate load, it levels out.
Every utility trailer depending on tire size etc. will have a different drop.
There are some calculators on line for figuring out the drop that you will need.
On your hitch assembly issue I would just have the dealer install the full OEM hitch and wiring harness so you have the wiring for both brake equipped trailers and non brake equipped trailers.
I would assume being in the mountains trailer brakes might come in handy at some point. Any way its a nice option to have even if you don't need them hauling stuff to the dump.
@Jeepster1 how is the ground clearance with the 10 inch drop?
I've been looking for another Latitude driver without any lifts or anything to ask. I'm starting a Junk Hauling business and have been gearing up. I'm getting this hitch and want to be prepared for the various weights and trailers I'll be hauling.
It seems like there are plenty of guys with 10 inch drops but a lot of those have been TH or AD2 guys.
kylepezz is offline
post #46 of 48 (permalink) Old 11-06-2016, 06:57 AM
Actually I have a AD2 Limited BUT that gives me about 1 inch of extra lift. Take that lift away and the trailer in a non AD2, the trailer is closer to level.
A latitude would be virtually the same except for Tires and AD1/AD2. Again a bit more or less drop.
The ground clearance is fine. The hitch on the Cherokee sits higher, that is positioned higher than my previous Jeeps. For example this Cherokee required a bigger drop for my trailers than the previous '04 Grand Cherokee did. The Hitch sat lower on the Grand. Now one thing to keep in mind is the trailer itself. Depending on tire size you might require a lot less drop.
Drop is relative to the trailer and your road clearance will be that of the trailer axle height. Larger tires generally the more clearance you will have.
Actually that $300 assembly is nice but not needed. You are much better off buying a solid unit with a specific drop, for a specific trailer. Even if you have to have 2 different ones for 2 different trailers. Thats what I have at hundreds less.
As I mentioned loading a trailer with a balanced load is most important. My utility trailer sits a couple inches high empty but when balanced loaded its level. Thats what you want.
kylepezz likes this.
post #47 of 48 (permalink) Old 11-11-2016, 12:33 PM Thread Starter
firedude's Avatar
Just an update... Hitch, wiring harness and bezel installed. Install looks great and looks factory to me. The process was another issue documented in the post below. Two dealers and 3 weeks later it got done. Install was $220. Dealer ate that one big time. All issues were finally resolved and i'm ready to tow my little utility trailer.
Post on the process...
Absolutely love my Jeep, but....
SkipW, Array, Mark_ and 3 others like this.
Tony
MoPar Slush Mats
firedude is offline
post #48 of 48 (permalink) Old 11-11-2016, 05:06 PM
Looks great, glad it all worked out in the end, despite the hassles.
firedude likes this.
OEM Hitch Receiver differences. gravitywell 2014+ Jeep Cherokee General Discussion 14 08-31-2016 09:59 PM
Loose Hitch Receiver SamDoe1 Towing and the Towed 25 01-02-2016 04:08 AM
hitch receiver tent platform CoBound Exterior 7 04-10-2015 06:47 PM
TrailHawk Hitch receiver rstiv4200 Towing and the Towed 3 07-22-2014 10:55 PM
Hitch receiver height off ground SkipW 2014+ Jeep Cherokee General Discussion 3 01-13-2014 12:09 PM
