PTU being replaced - Page 2 - 2014+ Jeep Cherokee Forums
 6Likes
post #11 of 24 (permalink) Old 10-22-2016, 03:51 AM
Pondhopper's Avatar
They did both at the same time on mine
Pondhopper is offline
post #12 of 24 (permalink) Old 10-22-2016, 12:37 PM
SpeedtekTH's Avatar
And believe or not, there are dealerships that don't know it.....the first one they did on mine,they didn't realize.....took another week for a new PTU and a module to arrive.
Funny thing is, I know for a fact the same dealer had replaced a PTU (properly) on my friend's Cherokee many months previous.
SpeedtekTH is offline
post #13 of 24 (permalink) Old 11-01-2016, 02:03 AM Thread Starter
Ampmtnbkr2's Avatar
Got my TH back on Friday. No one to talk to when I picked it up....this was the paperwork. As I understand from a prior call, they had to put in a 2nd PTU (first replacementt was bad), guts for the rearend, and a rear driveline.
Ampmtnbkr2 is offline
post #14 of 24 (permalink) Old 11-03-2016, 02:13 AM Thread Starter
Ampmtnbkr2's Avatar
Went in and talked to my service mgr. I got confirmation to my thoughts and interpreted info. Going by codes, PTU needed replacement. Put it in and test drove it. "Horrible" grinding from rear end. New PTU was bad from factory. They had to do a little convincing to "Star," about receiving bad parts, but came through. Checked rear end and fluid was silver/grey from metal shavings/dust. Replaced guts and driveline. Supposedly better! Time will tell. Kinda scared now. Trusted my vehicle unconditionally. Now leery. What is the name of the best place to get extended protection plans??? Interested in lifetime now....
post #15 of 24 (permalink) Old 11-03-2016, 02:17 AM
What are your thoughts on drivetrain break-in?
post #16 of 24 (permalink) Old 11-03-2016, 09:19 AM
Actually in my opinion for any drive-train replacement/repair part regarding break in, I would follow the original 300 mile one that came with the vehicle.
Personally I would go a little longer as I did when my vehicle was "new". If towing, especially as that puts extra stress/heat on the parts, I would follow the tow break in guide (500 miles) also.
If the trailer is upper end on weight I still would extent that 500 miles out a little longer. I once lost the rear differential on my 2001 Cherokee w/tow and off road package.
Seems the dealer used reg fluid instead of synthetic as what was called for in the owners manual. Tow only required synthetic. The heat broke down the fluid and burned up the gears.
Now a days they all use synthetic, tow or not as far as I know.
If you are with in the 3/36 original warranty, a Max Care Life is a good idea especially if you tow and tow heavy.
I got mine because of the electronics, towing and long time I keep it.
post #17 of 24 (permalink) Old 11-04-2016, 01:28 AM Thread Starter
Ampmtnbkr2's Avatar
I tow and tow pretty heavy. Nothing tough on it now for the rest of fall and winter. Winterized my trailer and put it into storage while using a Hemi-powered Ram while my TH was being worked on.
post #18 of 24 (permalink) Old 11-07-2016, 02:18 AM Thread Starter
Ampmtnbkr2's Avatar
Just looked online....over $4200 for the rear differential and PTU alone....thank god it was still under warranty....
madchemist24 and Renthorin like this.
post #19 of 24 (permalink) Old 12-09-2016, 06:55 PM
My PTU to be replaced next week at 40,000 miles.
3545 is offline
post #20 of 24 (permalink) Old 12-11-2016, 12:49 PM
gone2's Avatar
Mine has been in the shop for 2 weeks for the SVC 4WD light at 21k miles. When they called, the service guy said they were replacing the PTU, but then in the next sentence said PTO. At the time I didn't realize there was a difference and thought he had just mis-spoke. He did say it was a $3000 part.
2015 Trailhawk, 2015 Power Wagon, 2013 Roush RS3
www.clintcookphotography.com
gone2 is offline
PTU needs replacing ReefAngel 2014+ Jeep Cherokee General Discussion 26 08-02-2016 06:12 PM
PTU needing to be replaced hedblad 2014+ Jeep Cherokee General Discussion 10 11-15-2015 06:42 AM
PTU leak??? Amon 2014+ Jeep Cherokee General Discussion 10 09-01-2015 03:44 PM
PTU Replacement cdafrost1@hotmail.com Engine and Technical Discussion 11 04-20-2015 12:25 AM
Trailhawk PTU went caPUT LeBirch Engine and Technical Discussion 20 10-26-2014 06:06 PM
